Hi ,
I am using PTP synchronize time between tow xavier nx device (with one xavier NX device as master and another xavier nx device as slave) . I took the refernce commands from the
forum ( Time sensitive networking [TSN] on NX - #10 by carolyuu )
Master side
ifconfig eth0 down
ifconfig eth0 up
ifconfig eth0 0.0.0.0
ip addr add 10.0.0.1/24 dev eth0
ip link set dev eth0 up
timedatectl set-ntp false
date 010100002018
phc_ctl /dev/ptp0 set
phc_ctl /dev/ptp0 get
ptp4l -f gPTP.cfg -i eth0 -p /dev/ptp0 -m
slave side
ifconfig eth0 down
ifconfig eth0 up
ip addr add 10.0.0.2/24 dev eth0
ptp4l -f gPTP.cfg -i eth0 -p /dev/ptp0 -s -m
I have checked the time using both “date” command and “phc_ctl /dev/ptp0 get” command.The date and time I sent in the master device is not reflected in the slave device.
Any help is appreciated
hello tegra_user,
could you please try again to execute below commands on both of your master/slave device.
for example,
$ systemctl stop ptp4l
$ systemctl disable ptp4l
$ systemctl reboot
Hi @JerryChang ,
I tried executing these commands in both master and slave ,and then I tried the commands I mentioned above. But still I am not able to synchronize the slave clock to master clock.
hello tegra_user,
may I know what’s JetPack release version of your master and slave devices?
you may check release tag, $ cat /etc/nv_tegra_release for reference,
thanks
what is in the file gPTP.cfg ?
Hi Andrey,
I have taken the gPTP.cfg from the link I specified above( Time sensitive networking [TSN] on NX - #10 by carolyuu ).
[global]
Default Data Set
twoStepFlag 1
gmCapable 1
priority1 248
priority2 248
domainNumber 0
clockClass 248
clockAccuracy 0xFE
offsetScaledLogVariance 0xFFFF
free_running 0
freq_est_interval 1
Port Data Set
logAnnounceInterval 1
logSyncInterval -3
logMinPdelayReqInterval 0
announceReceiptTimeout 3
syncReceiptTimeout 3
delayAsymmetry 0
fault_reset_interval 4
neighborPropDelayThresh 800
min_neighbor_prop_delay -20000000
Run time options
assume_two_step 1
logging_level 6
path_trace_enabled 1
follow_up_info 1
hybrid_e2e 0
tx_timestamp_timeout 1
use_syslog 1
verbose 0
summary_interval 0
kernel_leap 1
check_fup_sync 0
Servo options
pi_proportional_const 0.0
pi_integral_const 0.0
pi_proportional_scale 0.0
pi_proportional_exponent -0.3
pi_proportional_norm_max 0.7
pi_integral_scale 0.0
pi_integral_exponent 0.4
pi_integral_norm_max 0.3
step_threshold 0.0
first_step_threshold 0.00002
max_frequency 900000000
clock_servo pi
sanity_freq_limit 200000000
ntpshm_segment 0
Transport options
transportSpecific 0x1
ptp_dst_mac 01:80:C2:00:00:0E
p2p_dst_mac 01:80:C2:00:00:0E
uds_address /var/run/ptp4l
Default interface options
network_transport L2
delay_mechanism P2P
time_stamping hardware
tsproc_mode filter
delay_filter moving_median
delay_filter_length 10
egressLatency 0
ingressLatency 0
boundary_clock_jbod 0
Hi @JerryChang , We are using 32.5.1 SD card image downloaded from jetson download centre.
R32 (release), REVISION: 5.1, GCID: 26202423, BOARD: t186ref, EABI: aarch64, DATE: Fri Feb 19 16:50:29 UTC 2021
do you connect two devices by direct copper wire cable?
Hi @Andrey1984 ,
I connect two devices with a ethernet cable .
Where should I connect the copper wire cable?
this should work for you
Host side
ifconfig eth0 down
ifconfig eth0 up
date 010100002018
DUT side
ifconfig eth0 down
ifconfig eth0 up
what is the output of phc_ctl /dev/ptp0 get at the client side?
Hi @Andrey1984 ,
I have tried the above commands, but I coudn’t get the time synchronized on my slave device.The below is is the phc_ctl /dev/ptp0 output on my device.
phc_ctl[235.617]:
capabilities:
62500000 maximum frequency adjustment (ppb)
0 programable alarms
0 external time stamp channels
0 programmable periodic signals
doesn’t have pulse per second support
the command should be exactly
with the get at the end
Hi @Andrey1984 ,
Sorry I missed out the get .I have added the result for the command below.
$ sudo phc_ctl /dev/ptp0 get
phc_ctl[255.518]: clock time is 1625919201.249458848 or Sat Jul 10 17:43:21 2021
yes but you would have to execute the whole thing again
Host side
ifconfig eth0 down
ifconfig eth0 up
date 010100002018
DUT side
ifconfig eth0 down
ifconfig eth0 up
execute both sides from root user, not sudo
are both devices jetson NX’es?
also you may paste both outputs of executing of
ethtool -T eth0
for linuxptp I would use
git clone git://git.code.sf.net/p/linuxptp/code linuxptp
cd linuxptp/
make -j6
sudo make install
Hi @Andrey1984 ,
I have tried using the linuxptp command from the site you have specified, but couldn’t find any improvements.
Also I have pasted below teh output of ethtool -T eth0.
Time stamping parameters for eth0:
Capabilities:
hardware-transmit (SOF_TIMESTAMPING_TX_HARDWARE)
software-transmit (SOF_TIMESTAMPING_TX_SOFTWARE)
hardware-receive (SOF_TIMESTAMPING_RX_HARDWARE)
software-receive (SOF_TIMESTAMPING_RX_SOFTWARE)
software-system-clock (SOF_TIMESTAMPING_SOFTWARE)
hardware-raw-clock (SOF_TIMESTAMPING_RAW_HARDWARE)
PTP Hardware Clock: 0
Hardware Transmit Timestamp Modes:
off (HWTSTAMP_TX_OFF)
on (HWTSTAMP_TX_ON)
Hardware Receive Filter Modes:
none (HWTSTAMP_FILTER_NONE)
ptpv1-l4-sync (HWTSTAMP_FILTER_PTP_V1_L4_SYNC)
ptpv1-l4-delay-req (HWTSTAMP_FILTER_PTP_V1_L4_DELAY_REQ)
ptpv2-l4-sync (HWTSTAMP_FILTER_PTP_V2_L4_SYNC)
ptpv2-l4-delay-req (HWTSTAMP_FILTER_PTP_V2_L4_DELAY_REQ)
ptpv2-l2-sync (HWTSTAMP_FILTER_PTP_V2_L2_SYNC)
ptpv2-l2-delay-req (HWTSTAMP_FILTER_PTP_V2_L2_DELAY_REQ)
ptpv2-event (HWTSTAMP_FILTER_PTP_V2_EVENT)
should return the host device time at the client side if you repeat steps from root user
Hi @Andrey1984 ,
I have run the commands from the root terminal, but “phc_ctl /dev/ptp0 get” on client side doesn’t return the time on the host side.
Where as I am able to get the host device side time on client side when I run the ptpd command specified by you on this link ( Implementation of Precise Time Synchronization between two Xaviers over WLAN )
Host side:
sudo ptpd -M -V -i eth0
Device side:
sudo ptpd -s -V -i eth0
I wonder , why does the ptp4l command doesn’t work for me.
ptpd and linux ptp [ptp4l] are two differnt projects
also what is the output of ethtool -T eth0 at the second device?
Hi @Andrey1984 ,
Do you have any suggestions why running the above commands(host and device side commands for ptp4l) doesn’t work for me ?
