Thanks DaneLLL I am able to install and run hlssink.
Going back to my original topic of timeshift, I am looking to encode from camera, write in a file , and then read it back to decode.
Is there a way command line like this can work ?
gst-launch-1.0 -e nvcamerasrc fpsRange="30.0 30.0" ! 'video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)I420, framerate=(fraction)30/1' ! omxh265enc ! 'video/x-h265, stream-format=(string)byte-stream' ! h265parse ! matroskamux ! filesink location=/home/ubuntu/junk.mkv filesrc location=/home/ubuntu/junk.mkv ! decodebin ! nvoverlaysink -e
When I tried encode followed by decode without file - it seems to work - although with lots of jerks/frame drops …
gst-launch-1.0 -e nvcamerasrc fpsRange="30.0 30.0" ! 'video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)I420, framerate=(fraction)30/1' ! omxh265enc ! 'video/x-h265, stream-format=(string)byte-stream' ! h265parse ! matroskamux ! decodebin ! nvoverlaysink -e
With aforesaid command line I see frame drops and following messages …
ubuntu@tegra-ubuntu:~$ gst-launch-1.0 -e nvcamerasrc fpsRange="30.0 30.0" ! 'video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)I420, framerate=(fraction)30/1' ! omxh265enc ! 'video/x-h265, stream-format=(string)byte-stream' ! h265parse ! matroskamux ! decodebin ! nvoverlaysink -e
Setting pipeline to PAUSED ...
Available Sensor modes :
3864 x 2174 FR=60.000000 CF=0x1009208a10 SensorModeType=4 CSIPixelBitDepth=10 DynPixelBitDepth=10
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
NvCameraSrc: Trying To Set Default Camera Resolution. Selected sensorModeIndex = 0 WxH = 3864x2174 FrameRate = 60.000000 ...
New clock: GstSystemClock
Framerate set to : 30 at NvxVideoEncoderSetParameterNvMMLiteOpen : Block : BlockType = 8
===== MSENC =====
NvMMLiteBlockCreate : Block : BlockType = 8
===== NVENC blits (mode: 1) into block linear surfaces =====
NvMMLiteOpen : Block : BlockType = 279
TVMR: NvMMLiteTVMRDecBlockOpen: 7907: NvMMLiteBlockOpen
NvMMLiteBlockCreate : Block : BlockType = 279
TVMR: cbBeginSequence: 1223: BeginSequence 1920x1088, bVPR = 0
TVMR: LowCorner Frequency = 180000
TVMR: cbBeginSequence: 1622: DecodeBuffers = 3, pnvsi->eCodec = 10, codec = 9
TVMR: cbBeginSequence: 1693: Display Resolution : (1920x1080)
TVMR: cbBeginSequence: 1694: Display Aspect Ratio : (1920x1080)
TVMR: cbBeginSequence: 1762: ColorFormat : 5
TVMR: cbBeginSequence:1776 ColorSpace = NvColorSpace_YCbCr601
TVMR: cbBeginSequence: 1904: SurfaceLayout = 3
TVMR: cbBeginSequence: 2005: NumOfSurfaces = 10, InteraceStream = 0, InterlaceEnabled = 0, bSecure = 0, MVC = 0 Semiplanar = 1, bReinit = 1, BitDepthForSurface = 8 LumaBitDepth = 8, ChromaBitDepth = 8, ChromaFormat = 5
TVMR: cbBeginSequence: 2007: BeginSequence ColorPrimaries = 2, TransferCharacteristics = 2, MatrixCoefficients = 2
Allocating new output: 1920x1088 (x 10), ThumbnailMode = 0
OPENMAX: HandleNewStreamFormat: 3464: Send OMX_EventPortSettingsChanged : nFrameWidth = 1920, nFrameHeight = 1088
TVMR: FrameRate = 1000
TVMR: NVDEC LowCorner Freq = (576000 * 1024)
WARNING: from element /GstPipeline:pipeline0/GstNvOverlaySink-nvoverlaysink:nvoverlaysink-nvoverlaysink0: A lot of buffers are being dropped.
Additional debug info:
gstbasesink.c(2854): gst_base_sink_is_too_late (): /GstPipeline:pipeline0/GstNvOverlaySink-nvoverlaysink:nvoverlaysink-nvoverlaysink0:
There may be a timestamping problem, or this computer is too slow.
---> TVMR: Video-conferencing detected !!!!!!!!!
^Chandling interrupt.
Interrupt: Stopping pipeline ...
EOS on shutdown enabled -- Forcing EOS on the pipeline
Waiting for EOS...
TVMR: NvMMLiteTVMRDecDoWork: 6768: NVMMLITE_TVMR: EOS detected
TVMR: TVMRBufferProcessing: 5723: Processing of EOS
TVMR: TVMRBufferProcessing: 5800: Processing of EOS Done
Got EOS from element "pipeline0".
EOS received - stopping pipeline...
Execution ended after 0:00:04.030194830
Setting pipeline to READY ...
TVMR: TVMRFrameStatusReporting: 6369: Closing TVMR Frame Status Thread -------------
TVMR: TVMRVPRFloorSizeSettingThread: 6179: Closing TVMRVPRFloorSizeSettingThread -------------
TVMR: TVMRFrameDelivery: 6219: Closing TVMR Frame Delivery Thread -------------
TVMR: NvMMLiteTVMRDecBlockClose: 8105: Done
Setting pipeline to NULL ...
Freeing pipeline ...
What would be right way to encode → to a file → read from the same file → decode → feed to opencv pipe using code given by you here …
https://devtalk.nvidia.com/default/topic/1011376/jetson-tx1/gstreamer-decode-live-video-stream-with-the-delay-difference-between-gst-launch-1-0-command-and-appsink-callback/post/5160929/#5160929
Thanks,
