I’m working on a custom board based on TX2-4GB, and I’m struggling to configure TLV320aic34 audio codec.
I’m using this post as a reference (https://devtalk.nvidia.com/default/topic/1053652/jetson-tx2/tlv320aic3x-on-tx2-only-noise-while-playback/1) since I’m using the same codec driver (TLV320aic34 is actually seen as two sapareted TLV320aic3106). Unfortunately my problem seems a little bit different because when I try to play a sound the aplay command ends immediately and nothing is played on the output lines.
This is my codec node:
i2c@3180000 {
aic34_a: tlv320aic34_a@1a {
staus = "okay";
compatible = "ti,tlv320aic3106";
reg = <0x1a>;
clocks = <&tegra_car TEGRA186_CLK_AUD_MCLK>;
clock-names = "aud_mclk";
/* Regulators */
AVDD-supply = <&spmic_ldo2>; //3.3
DRVDD-supply = <&spmic_ldo2>; //v3.3
IOVDD-supply = <&spmic_sd2>; //v 1.8
DVDD-supply = <&spmic_sd2>; //v1.8
aic34_b: tlv320aic34_b@1b {
staus = "okay";
reg = <0x1b>;
/* Regulators */
Please note that the reset is done with an external FPGA.
The codec driver probe functions are called during system startup: first aic3x_i2c_probe and then aic3x_probe without any errors.
My sound node looks like this:
tegra_sound: sound {
compatible = "nvidia,tegra-audio-t186ref-mobile-rt565x";
nvidia,model = "tegra-sound";
nvidia,num-codec-link = <2>;
nvidia,num-clk = <8>;
nvidia,clk-rates = < 270950400 /* PLLA_x11025_RATE */
11289600 /* AUD_MCLK_x11025_RATE */
45158400 /* PLLA_OUT0_x11025_RATE */
45158400 /* AHUB_x11025_RATE */
245760000 /* PLLA_x8000_RATE */
12288000 /* AUD_MCLK_x8000_RATE */
49152000 /* PLLA_OUT0_x8000_RATE */
49152000 >;/* AHUB_x8000_RATE */
clocks = <&tegra_car TEGRA186_CLK_PLLP_OUT0>,
<&tegra_car TEGRA186_CLK_PLLA>,
<&tegra_car TEGRA186_CLK_PLL_A_OUT0>,
<&tegra_car TEGRA186_CLK_AHUB>,
<&tegra_car TEGRA186_CLK_CLK_M>,
clock-names = "pll_p_out1", "pll_a", "pll_a_out0", "ahub",
"clk_m", "extern1";
resets = <&tegra_car TEGRA186_RESET_AUD_MCLK>;
reset-names = "extern1_rst";
status = "okay";
nvidia,audio-routing =
"a LINE1L", "a Mic",
"a LINE2L", "a Mic",
"a Headphone", "a HPLOUT",
"a Headphone", "a HPROUT",
"b LINE1L", "b Mic",
"b LINE2L", "b Mic",
"b Headphone", "b HPLOUT",
"b Headphone", "b HPROUT";
nvidia,xbar = <&tegra_axbar>;
nvidia,dai-link-1 {
link-name = "ti-playback-a";
status = "okay";
cpu-dai = <&tegra_i2s1>;
codec-dai = <&aic34_a>;
cpu-dai-name = "I2S1";
codec-dai-name = "tlv320aic3x-hifi";
tx-mask = <0xFF>;
rx-mask = <0xFF>;
format = "i2s";
bitclock-slave;
frame-slave;
bitclock-noninversion;
frame-noninversion;
bit-format = "s16_le";
bclk_ratio = <0>;
srate = <48000>;
num-channel = <4>; /* max 2 input/ 2 output */
name-prefix = "a";
nvidia,dai-link-2 {
link-name = "ti-playback-b";
status = "okay";
cpu-dai = <&tegra_i2s2>;
codec-dai = <&aic34_b>;
cpu-dai-name = "I2S2";
tx-mask = <0xFF>;
rx-mask = <0xFF>;
format = "i2s";
bitclock-slave;
frame-slave;
frame-noninversion;
bclk_ratio = <0>;
srate = <48000>;
num-channel = <4>; /* max 2 input/ 4 output */
name-prefix = "b";
The additional sound card is listed in the ALSA devices, and the codec widgets are listed correctly.
The tegra machine driver has been patched to generate a MLCK of 12Mhz:
diff --git a/tegra_machine_driver_mobile.c.ori b/tegra_machine_driver_mobile.c
old mode 100644
new mode 100755
index 048007f..3500ccf
--- a/tegra_machine_driver_mobile.c.ori
+++ b/tegra_machine_driver_mobile.c
@@ -97,7 +97,8 @@ static int tegra_machine_driver_remove(struct platform_device *);
static int tegra_machine_driver_probe(struct platform_device *);
static void dai_link_setup(struct platform_device *);
static int tegra_machine_sfc_init(struct snd_soc_pcm_runtime *);
-static int tegra_machine_rt565x_init(struct snd_soc_pcm_runtime *);
+//static int tegra_machine_rt565x_init(struct snd_soc_pcm_runtime *);
+static int tegra_machine_t186ref_init(struct snd_soc_pcm_runtime *);
#if IS_ENABLED(CONFIG_SND_SOC_TEGRA210_ADSP_ALT)
static int tegra_machine_compr_set_params(struct snd_compr_stream *);
@@ -527,7 +528,7 @@ static int tegra_machine_dai_init(struct snd_soc_pcm_runtime *runtime,
if (machine->soc_data->is_clk_rate_via_dt)
clk_out_rate = machine->audio_clock.set_clk_out_rate;
- pr_debug("pll_a_out0 = %d Hz, aud_mclk = %d Hz, codec rate = %d Hz\n",
+ printk(KERN_ERR "pll_a_out0 = %d Hz, aud_mclk = %d Hz, codec rate = %d Hz\n",
machine->audio_clock.set_mclk,
machine->audio_clock.set_clk_out_rate, clk_rate);
@@ -535,8 +536,9 @@ static int tegra_machine_dai_init(struct snd_soc_pcm_runtime *runtime,
err = tegra_machine_set_params(card, machine, rate, channels, formats);
if (err < 0)
return err;
- rtd = snd_soc_get_pcm_runtime(card, "rt565x-playback");
+ rtd = snd_soc_get_pcm_runtime(card, "ti-playback-a");
+ printk(KERN_ERR "SOUND tegra_machine_dai_init:====ti-playback-a I2S1 =====\n");
if (rtd) {
dai_params =
(struct snd_soc_pcm_stream *)rtd->dai_link->params;
@@ -547,15 +549,16 @@ static int tegra_machine_dai_init(struct snd_soc_pcm_runtime *runtime,
if (machine->is_hs_supported) {
err = snd_soc_dai_set_sysclk(rtd->codec_dai,
- RT5659_SCLK_S_MCLK, clk_out_rate, SND_SOC_CLOCK_IN);
+ 0, 12000000, SND_SOC_CLOCK_IN);
if (err < 0) {
dev_err(card->dev, "codec_dai clock not set\n");
return err;
- rtd = snd_soc_get_pcm_runtime(card, "rt565x-codec-sysclk-bclk1");
+ rtd = snd_soc_get_pcm_runtime(card, "ti-playback-b");
+ printk(KERN_ERR "SOUND tegra_machine_dai_init:====ti-playback-b I2S2 =====\n");
if (rtd) {
dai_params =
@@ -564,78 +567,9 @@ static int tegra_machine_dai_init(struct snd_soc_pcm_runtime *runtime,
dai_params->formats = (machine->fmt_via_kcontrol == 2) ?
(1ULL << SNDRV_PCM_FORMAT_S32_LE) : formats;
- err = rt565x_manage_codec_sysclk(dai_params, rtd->codec_dai,
- RT5659_PLL1_S_BCLK1);
- if (err < 0) {
- dev_err(card->dev, "codec_dai clock not set\n");
- return err;
- /* TODO: remove below spdif links if clk_rate is passed
- * in tegra_machine_set_params
- rtd = snd_soc_get_pcm_runtime(card, "spdif-dit-1");
- if (rtd) {
- dai_params =
- (struct snd_soc_pcm_stream *)rtd->dai_link->params;
- dai_params->rate_min = clk_rate;
- /* set clk rate for i2s3 dai link*/
- rtd = snd_soc_get_pcm_runtime(card, "spdif-dit-2");
- if (rtd) {
- dai_params =
- rtd = snd_soc_get_pcm_runtime(card, "spdif-dit-3");
- if (rtd) {
- dai_params =
- rtd = snd_soc_get_pcm_runtime(card, "spdif-dit-5");
- if (rtd) {
- dai_params =
- /* update link_param to update hw_param for DAPM */
- dai_params->channels_min = channels;
- dai_params->formats = formats;
- rtd = snd_soc_get_pcm_runtime(card, "dspk-playback-r");
- if (rtd) {
- dai_params =
- if (!strcmp(rtd->codec_dai->name, "tas2552-amplifier")) {
- err = snd_soc_dai_set_sysclk(rtd->codec_dai,
- TAS2552_PDM_CLK_IVCLKIN, clk_out_rate,
- SND_SOC_CLOCK_IN);
- if (err < 0) {
- return err;
- rtd = snd_soc_get_pcm_runtime(card, "dspk-playback-l");
- if (rtd) {
- dai_params =
+ if (machine->is_hs_supported) {
if (err < 0) {
return err;
@@ -643,16 +577,7 @@ static int tegra_machine_dai_init(struct snd_soc_pcm_runtime *runtime,
- rtd = snd_soc_get_pcm_runtime(card, "fe-pi-audio-z-v2");
- if (rtd) {
- dai_params =
+ printk(KERN_ERR "SOUND tegra_machine_dai_init:==== OK =====\n");
return 0;
@@ -810,6 +735,22 @@ static int tegra_machine_fepi_init(struct snd_soc_pcm_runtime *rtd)
return 0;
+static int tegra_machine_t186ref_init(struct snd_soc_pcm_runtime *rtd)
+ struct snd_soc_card *card = rtd->card;
+ struct tegra_machine *machine = snd_soc_card_get_drvdata(card);
+ int err;
+ err = tegra_alt_asoc_utils_set_extern_parent(&machine->audio_clock,
+ "pll_a_out0");
+ if (err < 0) {
+ dev_err(card->dev, "Failed to set extern clk parent\n");
+ return err;
+ return 0;
+#if 0
static int tegra_machine_rt565x_init(struct snd_soc_pcm_runtime *rtd)
@@ -859,7 +800,7 @@ static int tegra_machine_rt565x_init(struct snd_soc_pcm_runtime *rtd)
return 0;
+#endif
static int tegra_machine_sfc_init(struct snd_soc_pcm_runtime *rtd)
struct snd_soc_dai *codec_dai = rtd->codec_dai;
@@ -899,9 +840,9 @@ static void dai_link_setup(struct platform_device *pdev)
for (i = 0; i < machine->num_codec_links; i++) {
if (tegra_machine_codec_links[i].name) {
if (strstr(tegra_machine_codec_links[i].name,
- "rt565x-playback") ||
+ "ti-playback-a") ||
- "rt565x-codec-sysclk-bclk1")) {
+ "ti-playback-b")) {
codec_dai_name =
tegra_machine_codec_links[i].codec_dai_name;
if (!strcmp("dit-hifi", codec_dai_name)) {
@@ -910,7 +851,7 @@ static void dai_link_setup(struct platform_device *pdev)
} else {
machine->is_hs_supported = true;
tegra_machine_codec_links[i].init =
- tegra_machine_rt565x_init;
+ tegra_machine_t186ref_init;
} else if (strstr(tegra_machine_codec_links[i].name,
"dspk-playback-r")) {
@@ -1107,6 +1048,13 @@ static int tegra_machine_driver_probe(struct platform_device *pdev)
if (ret)
goto err_alloc_dai_link;
+ ret = tegra_alt_asoc_utils_set_parent(&machine->audio_clock,false);
+ if (ret){
+ dev_err(&pdev->dev, "tegra_alt_asoc_utils_set_parent failed (%d)\n",
+ ret);
+ goto err_alloc_dai_link;
ret = snd_soc_register_card(card);
if (ret) {
dev_err(&pdev->dev, "snd_soc_register_card failed (%d)\n",
diff --git a/tegra_asoc_utils_alt.c.ori b/tegra_asoc_utils_alt.c
old mode 100644
new mode 100755
index f18c24b..e02c86f
--- a/tegra_asoc_utils_alt.c.ori
+++ b/tegra_asoc_utils_alt.c
@@ -135,12 +135,12 @@ int tegra_alt_asoc_utils_set_rate(struct tegra_asoc_audio_clock_info *data,
- err = clk_set_rate(data->clk_cdev1, clk_out_rate);
+ err = clk_set_rate(data->clk_cdev1, 12000000);
if (err) {
dev_err(data->dev, "Can't set clk_cdev1 rate: %d\n", err);
return err;
data->set_baseclock = new_baseclock;
data->set_mclk = mclk;
data->set_clk_out_rate = clk_out_rate;
@@ -212,6 +212,13 @@ int tegra_alt_asoc_utils_init(struct tegra_asoc_audio_clock_info *data,
goto err;
+ data->clk_pll_p_out1 = devm_clk_get(dev, "pll_p_out1");
+ if (IS_ERR(data->clk_pll_p_out1)) {
+ dev_err(data->dev, "Can't retrieve clk pll_p_out1\n");
+ ret = PTR_ERR(data->clk_pll_p_out1);
+ goto err;
data->clk_pll_a = devm_clk_get(dev, "pll_a");
if (IS_ERR(data->clk_pll_a)) {
dev_err(data->dev, "Can't retrieve clk pll_a\n");
@@ -275,19 +282,21 @@ int tegra_alt_asoc_utils_set_parent(struct tegra_asoc_audio_clock_info *data,
int ret = -ENODEV;
if (is_i2s_master) {
- ret = clk_set_parent(data->clk_cdev1, data->clk_pll_a_out0);
+ ret = clk_set_parent(data->clk_cdev1, data->clk_pll_p_out1);
if (ret) {
dev_err(data->dev, "Can't set clk cdev1/extern1 parent");
return ret;
} else {
- ret = clk_set_parent(data->clk_cdev1, data->clk_m);
if (ret) {
return ret;
- ret = clk_set_rate(data->clk_cdev1, 13000000);
+// ret = clk_set_rate(data->clk_cdev1, 13000000);
+ printk(KERN_ERR "SOUND MACHINE DRIVER Set master clock 12Mhz\n");
+ ret = clk_set_rate(data->clk_cdev1, 12000000);
if (ret) {
dev_err(data->dev, "Can't set clk rate");
return ret;
@@ -317,7 +326,15 @@ int tegra_alt_asoc_utils_set_extern_parent(
return err;
- err = clk_set_rate(data->clk_cdev1, rate);
+ err = clk_set_parent(data->clk_cdev1, data->clk_pll_p_out1);
+ if (err) {
+ dev_err(data->dev, "Can't set clk cdev1/extern1 parent");
+ return err;
+ //err = clk_set_rate(data->clk_cdev1, rate);
if (err) {
return err;
But unfortunately I’ve never seen the aic3x_hw_params been called.
When I try to play a sound I use the following script:
#!/bin/bash
amixer -c tegrasound sset 'ADMAIF3 Mux' 'I2S1'
amixer -c tegrasound sset 'I2S1 Mux' 'ADMAIF3'
amixer -c tegrasound cset name='MVC1 Mute' 0
amixer -c tegrasound cset name='MVC2 Mute' 0
amixer -c tegrasound cset name='a HPCOM Playback Switch' 1
amixer -c tegrasound cset name='a Line Playback Switch' 1
amixer -c tegrasound cset name='a HP Playback Switch' 1
amixer -c tegrasound cset name='a PCM Playback Volume' 95%
amixer -c tegrasound cset name='a HP DAC Playback Volume' 95%
amixer -c tegrasound cset name='a HPCOM DAC Playback Volume' 80%
amixer -c tegrasound cset name='a Left HP Mixer DACR1 Playback Volume' 90%
amixer -c tegrasound cset name='a Left HPCOM Mixer DACR1 Playback Volume' 90%
amixer -c tegrasound sset 'ADMAIF4 Mux' 'I2S2'
amixer -c tegrasound sset 'I2S2 Mux' 'ADMAIF4'
amixer -c tegrasound cset name='b HPCOM Playback Switch' 1
amixer -c tegrasound cset name='b Line Playback Switch' 1
amixer -c tegrasound cset name='b HP Playback Switch' 1
amixer -c tegrasound cset name='b PCM Playback Volume' 95%
amixer -c tegrasound cset name='b HP DAC Playback Volume' 95%
amixer -c tegrasound cset name='b HPCOM DAC Playback Volume' 80%
amixer -c tegrasound cset name='b Left HP Mixer DACR1 Playback Volume' 90%
amixer -c tegrasound cset name='b Left HPCOM Mixer DACR1 Playback Volume' 90%
aplay -D hw:tegrasound,10 ../Music/piano2.wav
aplay -D hw:tegrasound,11 ../Music/piano2.wav
this is the command output:
Simple mixer control 'ADMAIF3 Mux',0
Capabilities: enum
Items: 'None' 'ADMAIF1' 'ADMAIF2' 'ADMAIF3' 'ADMAIF4' 'ADMAIF5' 'ADMAIF6' 'ADMAIF7' 'ADMAIF8' 'ADMAIF9' 'ADMAIF10' 'ADMAIF11' 'ADMAIF12' 'ADMAIF13' 'ADMAIF14' 'ADMAIF15' 'ADMAIF16' 'I2S1' 'I2S2' 'I2S3' 'I2S4' 'I2S5' 'I2S6' 'SFC1' 'SFC2' 'SFC3' 'SFC4' 'MIXER1-1' 'MIXER1-2' 'MIXER1-3' 'MIXER1-4' 'MIXER1-5' 'AMX1' 'AMX2' 'AMX3' 'AMX4' 'ARAD1' 'AFC1' 'AFC2' 'AFC3' 'AFC4' 'AFC5' 'AFC6' 'OPE1' 'SPKPROT1' 'MVC1' 'MVC2' 'IQC1-1' 'IQC1-2' 'IQC2-1' 'IQC2-2' 'DMIC1' 'DMIC2' 'DMIC3' 'DMIC4' 'ADX1-1' 'ADX1-2' 'ADX1-3' 'ADX1-4' 'ADX2-1' 'ADX2-2' 'ADX2-3' 'ADX2-4' 'ADX3-1' 'ADX3-2' 'ADX3-3' 'ADX3-4' 'ADX4-1' 'ADX4-2' 'ADX4-3' 'ADX4-4' 'ADMAIF17' 'ADMAIF18' 'ADMAIF19' 'ADMAIF20' 'ASRC1-1' 'ASRC1-2' 'ASRC1-3' 'ASRC1-4' 'ASRC1-5' 'ASRC1-6'
Item0: 'I2S1'
Simple mixer control 'I2S1 Mux',0
Capabilities: enum
Item0: 'ADMAIF3'
numid=683,iface=MIXER,name='MVC1 Mute'
; type=BOOLEAN,access=rw------,values=1
: values=off
numid=689,iface=MIXER,name='MVC2 Mute'
: values=off
numid=896,iface=MIXER,name='a HPCOM Playback Switch'
; type=BOOLEAN,access=rw------,values=2
: values=on,on
numid=894,iface=MIXER,name='a Line Playback Switch'
: values=on,on
numid=895,iface=MIXER,name='a HP Playback Switch'
: values=on,on
numid=875,iface=MIXER,name='a PCM Playback Volume'
; type=INTEGER,access=rw---R--,values=2,min=0,max=127,step=0
: values=121,121
| dBscale-min=-63.50dB,step=0.50dB,mute=0
numid=891,iface=MIXER,name='a HP DAC Playback Volume'
; type=INTEGER,access=rw---R--,values=2,min=0,max=118,step=0
: values=113,113
| dBscale-min=-59.00dB,step=0.50dB,mute=1
numid=893,iface=MIXER,name='a HPCOM DAC Playback Volume'
: values=95,95
numid=881,iface=MIXER,name='a Left HP Mixer DACR1 Playback Volume'
; type=INTEGER,access=rw---R--,values=1,min=0,max=118,step=0
: values=107
numid=885,iface=MIXER,name='a Left HPCOM Mixer DACR1 Playback Volume'
: values=107
Simple mixer control 'ADMAIF4 Mux',0
Capabilities: enum
Item0: 'I2S2'
Simple mixer control 'I2S2 Mux',0
Capabilities: enum
Item0: 'ADMAIF4'
: values=off
: values=off
numid=955,iface=MIXER,name='b HPCOM Playback Switch'
: values=on,on
numid=953,iface=MIXER,name='b Line Playback Switch'
: values=on,on
numid=954,iface=MIXER,name='b HP Playback Switch'
: values=on,on
numid=934,iface=MIXER,name='b PCM Playback Volume'
: values=121,121
numid=950,iface=MIXER,name='b HP DAC Playback Volume'
: values=113,113
numid=952,iface=MIXER,name='b HPCOM DAC Playback Volume'
: values=95,95
numid=940,iface=MIXER,name='b Left HP Mixer DACR1 Playback Volume'
: values=107
numid=944,iface=MIXER,name='b Left HPCOM Mixer DACR1 Playback Volume'
: values=107
Playing WAVE '../Music/piano2.wav' : Signed 16 bit Little Endian, Rate 48000 Hz, Stereo
kernel log:
[ 893.347770] pll_a_out0 = 45158400 Hz, aud_mclk = 11289600 Hz, codec rate = 44100 Hz
[ 893.355720] SOUND tegra_machine_dai_init:====ti-playback-a I2S1 =====
[ 893.363372] aic3x: SOUND DAI system clock frequency 12000000 clk_id: 0
[ 893.370421] SOUND tegra_machine_dai_init:====ti-playback-b I2S2 =====
[ 893.377418] aic3x: SOUND DAI system clock frequency 12000000 clk_id: 0
[ 893.384532] SOUND tegra_machine_dai_init:==== OK =====
[ 896.849855] pll_a_out0 = 45158400 Hz, aud_mclk = 11289600 Hz, codec rate = 44100 Hz
[ 896.857773] SOUND tegra_machine_dai_init:====ti-playback-a I2S1 =====
[ 896.864251] aic3x: SOUND DAI system clock frequency 12000000 clk_id: 0
[ 896.870878] SOUND tegra_machine_dai_init:====ti-playback-b I2S2 =====
[ 896.877430] aic3x: SOUND DAI system clock frequency 12000000 clk_id: 0
[ 896.883974] SOUND tegra_machine_dai_init:==== OK =====
and the trace pipe:
aplay-12059 [002] .... 8123.672800: snd_soc_dapm_start: card=tegra-sound
aplay-12059 [002] .... 8123.672951: snd_soc_dapm_walk_done: tegra-sound: checks 2 power, 2 path, 0 neighbour
aplay-12059 [002] .... 8123.672974: snd_soc_dapm_done: card=tegra-sound
aplay-12059 [002] .... 8123.872978: snd_soc_dapm_start: card=tegra-sound
aplay-12059 [002] .... 8123.873234: snd_soc_dapm_path: *ADMAIF3 Receive <- (direct) <- Playback 3
aplay-12059 [002] .... 8123.873261: snd_soc_dapm_path: *ADMAIF3 Receive <- (direct) <- ADMAIF3 CIF Receive-ADMAIF3 Receive
aplay-12059 [002] .... 8123.873470: snd_soc_dapm_walk_done: tegra-sound: checks 2 power, 2 path, 2 neighbour
aplay-12059 [002] .... 8123.873516: snd_soc_dapm_done: card=tegra-sound
aplay-12060 [001] .... 8123.969349: snd_soc_dapm_start: card=tegra-sound
aplay-12060 [001] .... 8123.969542: snd_soc_dapm_walk_done: tegra-sound: checks 2 power, 2 path, 0 neighbour
aplay-12060 [001] .... 8123.969561: snd_soc_dapm_done: card=tegra-sound
aplay-12060 [001] .... 8124.170077: snd_soc_dapm_start: card=tegra-sound
aplay-12060 [001] .... 8124.170914: snd_soc_dapm_path: *ADMAIF4 Receive <- (direct) <- Playback 4
aplay-12060 [001] .... 8124.171419: snd_soc_dapm_path: *ADMAIF4 Receive <- (direct) <- ADMAIF4 CIF Receive-ADMAIF4 Receive
aplay-12060 [001] .... 8124.171998: snd_soc_dapm_walk_done: tegra-sound: checks 2 power, 2 path, 2 neighbour
aplay-12060 [004] .... 8124.172869: snd_soc_dapm_done: card=tegra-sound
Note that in the DAPM trace I dont’ see any reference to the codec widgets.
Please let me know if I’m missing something, folder /sys/kernel/debug/asoc/tegra-sound/ is full of additional debug information but I’m a little bit lost and I don’t know exactly what to search for.
Thanks,
Davide
