我正在使用origin nano,使用v4l工具采集了28961880的一张图片
但是为什么图片的右边16个字节像是左边偏移过来的,这个右边的16字节看起来不太对
这是我设备树中的配置方法
mode0 { / IMX219_MODE_3280x2464_21FPS */
mclk_khz = “24000”;
num_lanes = “2”;
tegra_sinterface = “serial_a”;
phy_mode = “DPHY”;
discontinuous_clk = “no”;
dpcm_enable = “false”;
cil_settletime = “0”;
lane_polarity = “3”;
active_w = "2896";
active_h = "1880";
mode_type = "bayer";
pixel_phase = "rggb";
csi_pixel_bit_depth = "12";
readout_orientation = "90";
line_length = "11200";
inherent_gain = "1";
mclk_multiplier = "80";
pix_clk_hz = "200000000";
gain_factor = "16";
framerate_factor = "1000000";
exposure_factor = "1000000";
min_gain_val = "1"; /* 1.00x */
max_gain_val = "170"; /* 10.66x */
step_gain_val = "1";
default_gain = "16"; /* 1.00x */
min_hdr_ratio = "1";
max_hdr_ratio = "1";
min_framerate = "2000000"; /* 2.0 fps */
max_framerate = "46000000"; /* 21.0 fps */
step_framerate = "1";
default_framerate = "46000000"; /* 21.0 fps */
min_exp_time = "13"; /* us */
max_exp_time = "683709"; /* us */
step_exp_time = "1";
default_exp_time = "2495"; /* us */
embedded_metadata_height = "0";
请问有什么问题吗
看起来和这个问题很像
我能怎么解决这个问题?
