Torch.distributed.pipelining can't be using
I’m a student, and I would like to refer to the link “PyTorch Distributed Overview — PyTorch Tutorials 2.5.0+cu124 documentation” to partition the model and then do the inference task. But I found that the code needs a command like “from torch.distributed.pipelining import pipeline, SplitPoint, PipelineStage, ScheduleGPipe”. But after I entered this command, it showed that there was no such package.
My jetson device is jetson AGX Orin, Jetpack version is 5.1.1, torch version is 1.11.0, and I installed it using the wheel file provided by nvidia.
Is torch.distributed.pipelining not working on jetson devices? Is there any alternative?
Any helpful suggestions would be greatly appreciated!
Please upgrade your device to JetPack 6.1 and install our latest PyTorch package below:
http://jetson.webredirect.org/jp6/cu126
$ python3
Python 3.10.12 (main, Jul 29 2024, 16:56:48) [GCC 11.4.0] on linux
Type "help", "copyright", "credits" or "license" for more information.
Thank you for your suggestion! By the way, are there any software instructions that can be upgraded JetPack directly instead of upgrading it by hardware?
Do you want to upgrade JetPack without using a newer BSP?
If yes, please find the document below:
https://docs.nvidia.com/jetson/archives/jetpack-archived/jetpack-61/install-setup/index.html#upgradable-compute-stack
