Hi
I am trying to bring up TC358840 to Xavier NX.
I use Jetson 5.02 (JetPack_5.0.2_Linux_JETSON_XAVIER_NX_TARGETS)
The problem is that the Toshiba chip always said that NO SYNC on HDMI in
12.437100] v4l2-ctrls: tc358840 2-000f: Power Present: 0x00000001
[ 12.437648] v4l2-ctrls: tc358840 2-000f: Splitter Width: 1920
[ 12.437963] tc358840 2-000f: -----Chip status-----
[ 12.453294] tegra-i2c 3190000.i2c: I2C transfer timed out
[ 12.462196] tc358840 2-000f: Chip ID: 0x47
[ 12.465899] tc358840 2-000f: Chip revision: 0x00
[ 12.466059] tc358840 2-000f: Reset: IR: 0, CEC: 0, CSI TX: 0, HDMI: 0
[ 12.466256] tc358840 2-000f: Sleep mode: off
[ 12.468786] tc358840 2-000f: Cable detected (+5V power): yes
[ 12.473574] tegra210-adsp tegra210-adsp: Loaded app adma
[ 12.497484] tc358840 2-000f: DDC lines enabled: yes
[ 12.497726] tc358840 2-000f: Hotplug enabled: no
[ 12.505186] tc358840 2-000f: CEC enabled: no
[ 12.506046] tc358840 2-000f: -----Signal status-----
[ 12.506571] tc358840 2-000f: TMDS signal detected: yes
[ 12.525579] tc358840 2-000f: Stable sync signal: no
[ 12.525731] tc358840 2-000f: PHY PLL locked: yes
[ 12.525887] tc358840 2-000f: PHY DE detected: yes
[ 12.529345] tegra210-adsp tegra210-adsp: Loaded app adma_tx
[ 12.534343] nvadsp_set_adma_dump_reg: callback for adma reg dump is sent to 00000000cd33d266
[ 12.555429] tegra210-adsp tegra210-adsp: Tegra210 ADSP driver successfully registered
[ 12.559506] get_detected_timings no sync on signal
[ 12.559704] tc358840 2-000f: No video detected
[ 12.565104] tc358840 2-000f: Configured format: 1920x1080p30.00 (2200x1125)
[ 12.573337] tegra-i2c 3190000.i2c: I2C transfer timed out
[ 12.590391] tc358840 2-000f: horizontal: fp = 88, +sync = 44, bp = 148
[ 12.590601] tc358840 2-000f: vertical: fp = 4, +sync = 5, bp = 36
12.590764] tc358840 2-000f: pixelclock: 74250000
[ 12.592854] tc358840 2-000f: flags (0x92): CAN_REDUCE_FPS CE_VIDEO HAS_CEA861_VIC
[ 12.600381] tc358840 2-000f: standards (0x1): CEA
[ 12.610164] tc358840 2-000f: CEA-861 VIC: 34
[ 12.610372] tc358840 2-000f: -----CSI-TX status-----
[ 12.621387] tc358840 2-000f: Lanes needed: 4
[ 12.645596] LTS3b i2c_rd
[ 12.653216] tc358840 2-000f: Lanes in use: 4
[ 12.653410] LTS3b i2c_rd
[ 12.656417] tc358840 2-000f: Splitter disabled
[ 12.656619] tc358840 2-000f: Color space: YCbCr 422 16-bit
[ 12.656798] LTS3b i2c_rd
[ 12.657467] tc358840 2-000f: -----HDMI status-----
[ 12.657674] tc358840 2-000f: HDCP encrypted content: no
[ 12.657895] tc358840 2-000f: Input color space: YCbCr 709 limited range
[ 12.665524] tc358840 2-000f: AV Mute: off
[ 12.668867] tc358840 2-000f: Deep color mode: 8-bits per channel
v4l2_async_register_subdev hdmi_sys_status=0x1F sysctl=0x0000 vi_status3= 0x07
My device-tree is as following:
host1x {
vi_base: vi {
num-channels = <1>;
ports {
#address-cells = <1>;
#size-cells = <0>;
tc_vi_port0: port@0 { /* HDMI IN A (4K) */
reg = <0>;
status = "okay";
tc358840_vi_in0: endpoint {
status = "okay";
port-index = <0>;
bus-width = <4>;
//gang-mode = <1>;
remote-endpoint = <&tc358840_csi_out0>;
csi_base: nvcsi {
num-channels = <1>;
#size-cells = <0>;
channel@0 {
reg = <0>;
ports {
#size-cells = <0>;
port@0 {
status = "okay";
reg = <0>;
tc358840_csi_in0: endpoint@0 {
status = "okay";
port-index = <0>;
bus-width = <4>;
//gang-mode = <1>; /* MAY REMOVE */
remote-endpoint = <&tc358840_out0>;
port@1 {
status = "okay";
reg = <1>;
tc358840_csi_out0: endpoint@1 {
status = "okay";
remote-endpoint = <&tc358840_vi_in0>;
hdmi_osc: hdmi-osc {
compatible = “fixed-clock”;
clock-output-names = “hdmi-osc”;
clock-frequency = <48000000>;
#clock-cells = <0>;
/LTS************/
i2c@3180000 {
#address-cells = <0x1>;
#size-cells = <0x0>;
status = “okay”;
vana-supply = <&p3509_avdd_cam_2v8>;
vif-supply = <&p3509_vdd_1v8_cvb>;
/* rework: also enables VDD_1V_SATA_PHY (1.18 V) */
vdig-supply = <&p3509_vdd_1v8_cvb>;
tc358840@0f {
compatible = "toshiba,tc358840";
reg = <0x0f>;
status = "okay";
clocks = <&hdmi_osc>;
clock-names = "refclk";
devnode = "video0";
/* Power Supply */
/* Sensor Model */
sensor_model ="tc358840";
/* Physical dimensions of sensor */
physical_w = "4.713";
physical_h = "3.494";
/* GPIO */
reset-gpio = <&tegra_main_gpio ENA_RST GPIO_ACTIVE_HIGH>;
reset-cam = <&tegra_main_gpio CAM2_RST GPIO_ACTIVE_LOW>;
ena_5v-gpio = <&tegra_main_gpio ENA_5V GPIO_ACTIVE_HIGH>;
/* Interrupt */
interrupt-parent = <&tegra_main_gpio>;
interrupts = <TC358840_INT GPIO_ACTIVE_HIGH>;
refclk_hz = <48000000>; /* 40 - 50 MHz */
ddc5v_delay = <1>;
/* HDCP */
enable_hdcp = <0>;
/* CSI Output */
csi_port = <3>;
lineinitcnt = <0x00000FA0>;
lptxtimecnt = <0x00000004>;
tclk_headercnt = <0x00180203>;
tclk_trailcnt = <0x00040005>;
ths_headercnt = <0x000D0004>;
twakeup = <0x00003E80>;
tclk_postcnt = <0x0000000A>;
ths_trailcnt = <0x00080006>;
hstxvregcnt = <0x00000020>;
btacnt = <0>;
/* PLL */
/* Bps per lane is (refclk_hz / pll_prd) * pll_fbd */
pll_prd = <10>;//9+1
pll_fbd = <125>;//124+1
pll_frs = <1>;
mode0 {
mclk_khz = “24000”;
num_lanes = “4”;
tegra_sinterface = “serial_a”;
phy_mode = “DPHY”;
discontinuous_clk = “yes”;
dpcm_enable = “false”;
cil_settletime = “0”;
active_w = "1920";
active_h = "1080";
mode_type = "rggb";
readout_orientation = "0";
line_length = "2200";
inherent_gain = "1";
mclk_multiplier = "25";
pix_clk_hz = "74250000";
min_gain_val = "1";
max_gain_val = "16";
min_hdr_ratio = "1";
max_hdr_ratio = "64";
min_framerate = "1000000";
max_framerate = "30000000";
default_framerate = "30000000";
min_exp_time = "30"; // us
max_exp_time = "660000"; // us
embedded_metadata_height = "1";
dynamic_pixel_bit_depth = "24";
csi_pixel_bit_depth = "24";
gain_factor = "10";
step_gain_val = "3"; // 0.3
default_gain = "1";
step_framerate = "1";
framerate_factor = "1000000";
step_exp_time = "1";
default_exp_time = "33334"; // us
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
tc358840_out0: endpoint {
port-index = <0>;
bus-width = <4>;
data-lanes = <1 2 3 4>;
clock-lanes = <0>;
remote-endpoint = <&tc358840_csi_in0>;
