• Hardware (Training on system with NVIDIA TITAN RTX(24G), Precision 7920 Tower with 32G memory)
• Network Type (Mask_rcnn using mapillary-vistas-dataset)
I am training maskrcnn with resnet34 architecture.
I have error as
Total size of new array must be unchanged for block_1a_conv_1/kernel lh_shape: [(1, 1, 64, 64)], rh_shape: [(3, 3, 64, 64)]
What could be issue?
Attached is the config file for training.
maskrcnn_train_resnet34.txt (2.0 KB)
The whole error is
INFO:tensorflow:Done calling model_fn.
File "/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/mask_rcnn/scripts/train.py", line 222, in <module>
File "/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/mask_rcnn/scripts/train.py", line 218, in main
File "/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/mask_rcnn/scripts/train.py", line 85, in run_executer
File "/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/mask_rcnn/executer/distributed_executer.py", line 399, in train_and_eval
File "/usr/local/lib/python3.6/dist-packages/tensorflow_estimator/python/estimator/estimator.py", line 370, in train
loss = self._train_model(input_fn, hooks, saving_listeners)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_estimator/python/estimator/estimator.py", line 1161, in _train_model
return self._train_model_default(input_fn, hooks, saving_listeners)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_estimator/python/estimator/estimator.py", line 1195, in _train_model_default
saving_listeners)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_estimator/python/estimator/estimator.py", line 1490, in _train_with_estimator_spec
log_step_count_steps=log_step_count_steps) as mon_sess:
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/monitored_session.py", line 584, in MonitoredTrainingSession
stop_grace_period_secs=stop_grace_period_secs)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/monitored_session.py", line 1014, in __init__
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/monitored_session.py", line 713, in __init__
h.begin()
File "/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/mask_rcnn/hooks/pretrained_restore_hook.py", line 208, in begin
File "/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/mask_rcnn/hooks/pretrained_restore_hook.py", line 113, in assign_from_checkpoint
ValueError: Total size of new array must be unchanged for block_1a_conv_1/kernel lh_shape: [(1, 1, 64, 64)], rh_shape: [(3, 3, 64, 64)]
[MaskRCNN] ERROR : Job finished with an uncaught exception: `FAILURE`
2022-05-18 08:46:27,717 [INFO] tlt.components.docker_handler.docker_handler: Stopping container.
#print("To resume training from a checkpoint, simply run the same training script. It will pick up from where it's left.")
#!tao mask_rcnn train -e $SPECS_DIR/maskrcnn_train_resnet50.txt \
# -d $USER_EXPERIMENT_DIR/experiment_dir_unpruned\
# -k $KEY \
# --gpus 1
print('Model for each epoch:')
