I’m trying to train a character detector using the Transfer Learning Toolkit.
I have labeled over 3000 images in this ratio:
seven: 3689
one: 3913
four: 3787
zero: 4648
six: 3955
two: 1337
u: 1862
t: 3801
five: 3906
x: 3920
a: 3843
c: 4151
b: 3633
e: 3780
d: 3801
g: 3759
f: 3787
h: 3360
k: 3822
j: 2611
m: 2044
l: 3850
o: 7
n: 3801
p: 3059
s: 3787
r: 819
nine: 2471
three: 896
w: 2688
v: 3871
y: 3773
eight: 2646
z: 3612
using the following train kitti config:
random_seed: 42
dataset_config {
data_sources {
tfrecords_path: "/workspace/tlt-experiments/tfrecords/kitti_trainval/*"
image_directory_path: "/workspace/tlt-experiments/data/training"
image_extension: "jpg"
target_class_mapping {
key: "a"
value: "a"
key: "b"
value: "b"
key: "c"
value: "c"
key: "d"
value: "d"
key: "e"
value: "e"
key: "f"
value: "f"
key: "g"
value: "g"
key: "h"
value: "h"
key: "j"
value: "j"
key: "k"
value: "k"
key: "l"
value: "l"
key: "m"
value: "m"
key: "n"
value: "n"
key: "p"
value: "p"
key: "r"
value: "r"
key: "s"
value: "s"
key: "t"
value: "t"
key: "u"
value: "u"
key: "v"
value: "v"
key: "w"
value: "w"
key: "x"
value: "x"
key: "y"
value: "y"
key: "z"
value: "z"
key: "zero"
value: "zero"
key: "one"
value: "one"
key: "two"
value: "two"
key: "three"
value: "three"
key: "four"
value: "four"
key: "five"
value: "five"
key: "six"
value: "six"
key: "seven"
value: "seven"
key: "eight"
value: "eight"
key: "nine"
value: "nine"
validation_fold: 0
augmentation_config {
preprocessing {
output_image_width: 480
output_image_height: 272
min_bbox_width: 1.0
min_bbox_height: 1.0
output_image_channel: 3
spatial_augmentation {
zoom_min: 1.0
zoom_max: 1.0
translate_max_x: 8.0
translate_max_y: 8.0
color_augmentation {
hue_rotation_max: 25.0
saturation_shift_max: 0.20000000298
contrast_scale_max: 0.10000000149
contrast_center: 0.5
postprocessing_config {
target_class_config {
key: "a"
value {
clustering_config {
coverage_threshold: 0.00499999988824
dbscan_eps: 0.20000000298
dbscan_min_samples: 0.0500000007451
minimum_bounding_box_height: 20
key: "b"
value {
clustering_config {
key: "c"
value {
clustering_config {
key: "d"
value {
clustering_config {
key: "e"
value {
clustering_config {
key: "f"
value {
clustering_config {
key: "g"
value {
clustering_config {
key: "h"
value {
clustering_config {
key: "j"
value {
clustering_config {
key: "k"
value {
clustering_config {
key: "l"
value {
clustering_config {
key: "m"
value {
clustering_config {
key: "n"
value {
clustering_config {
key: "p"
value {
clustering_config {
key: "r"
value {
clustering_config {
key: "s"
value {
clustering_config {
key: "t"
value {
clustering_config {
key: "u"
value {
clustering_config {
key: "v"
value {
clustering_config {
key: "w"
value {
clustering_config {
key: "x"
value {
clustering_config {
key: "y"
value {
clustering_config {
key: "z"
value {
clustering_config {
key: "zero"
value {
clustering_config {
key: "one"
value {
clustering_config {
key: "two"
value {
clustering_config {
key: "three"
value {
clustering_config {
key: "four"
value {
clustering_config {
key: "five"
value {
clustering_config {
key: "six"
value {
clustering_config {
key: "seven"
value {
clustering_config {
key: "eight"
value {
clustering_config {
key: "nine"
value {
clustering_config {
model_config {
pretrained_model_file: "/workspace/tlt-experiments/pretrained_resnet18/tlt_resnet18_detectnet_v2_v1/resnet18.hdf5"
num_layers: 18
use_batch_norm: true
activation {
activation_type: "relu"
objective_set {
bbox {
scale: 35.0
offset: 0.5
cov {
training_precision {
backend_floatx: FLOAT32
arch: "resnet"
evaluation_config {
validation_period_during_training: 10
first_validation_epoch: 1
minimum_detection_ground_truth_overlap {
key: "a"
value: 0.5
key: "b"
value: 0.5
key: "c"
value: 0.5
key: "d"
value: 0.5
key: "e"
value: 0.5
key: "f"
value: 0.5
key: "g"
value: 0.5
key: "h"
value: 0.5
key: "j"
value: 0.5
key: "k"
value: 0.5
key: "l"
value: 0.5
key: "m"
value: 0.5
key: "n"
value: 0.5
key: "p"
value: 0.5
key: "r"
value: 0.5
key: "s"
value: 0.5
key: "t"
value: 0.5
key: "u"
value: 0.5
key: "v"
value: 0.5
key: "w"
value: 0.5
key: "x"
value: 0.5
key: "y"
value: 0.5
key: "z"
value: 0.5
key: "zero"
value: 0.5
key: "one"
value: 0.5
key: "two"
value: 0.5
key: "three"
value: 0.5
key: "four"
value: 0.5
key: "five"
value: 0.5
key: "six"
value: 0.5
key: "seven"
value: 0.5
key: "eight"
value: 0.5
key: "nine"
value: 0.5
evaluation_box_config {
key: "a"
value {
minimum_height: 20
maximum_height: 9999
minimum_width: 10
maximum_width: 9999
key: "b"
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
key: "c"
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
key: "d"
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
key: "e"
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
key: "f"
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
key: "g"
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
key: "h"
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
key: "j"
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
key: "k"
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
key: "l"
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
key: "m"
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
key: "n"
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
key: "p"
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
key: "r"
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
key: "s"
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
key: "t"
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
key: "u"
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
key: "v"
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
key: "w"
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
key: "x"
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
key: "y"
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
key: "z"
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
key: "zero"
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
key: "one"
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
key: "two"
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
key: "three"
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
key: "four"
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
key: "five"
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
key: "six"
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
key: "seven"
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
key: "eight"
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
key: "nine"
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
average_precision_mode: INTEGRATE
cost_function_config {
target_classes {
class_weight: 1.2
coverage_foreground_weight: 0.0500000007451
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
initial_weight: 10.0
weight_target: 10.0
target_classes {
class_weight: 1.3
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
target_classes {
class_weight: 1.1
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
target_classes {
class_weight: 1.2
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
target_classes {
class_weight: 1.2
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
target_classes {
class_weight: 1.2
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
target_classes {
class_weight: 1.2
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
target_classes {
class_weight: 1.4
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
target_classes {
class_weight: 1.8
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
target_classes {
class_weight: 1.2
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
target_classes {
class_weight: 1.2
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
target_classes {
class_weight: 2.3
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
target_classes {
class_weight: 1.2
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
target_classes {
class_weight: 1.5
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
target_classes {
class_weight: 5.7
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
target_classes {
class_weight: 1.2
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
target_classes {
class_weight: 1.2
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
target_classes {
class_weight: 2.5
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
target_classes {
class_weight: 1.2
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
target_classes {
class_weight: 1.7
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
target_classes {
class_weight: 1.2
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
target_classes {
class_weight: 1.2
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
target_classes {
class_weight: 1.3
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
target_classes {
class_weight: 1.0
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
target_classes {
class_weight: 1.2
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
target_classes {
class_weight: 3.5
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
target_classes {
class_weight: 5.2
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
target_classes {
class_weight: 1.2
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
target_classes {
class_weight: 1.2
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
target_classes {
class_weight: 1.2
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
target_classes {
class_weight: 1.3
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
target_classes {
class_weight: 1.8
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
target_classes {
class_weight: 1.9
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
enable_autoweighting: true
max_objective_weight: 0.999899983406
min_objective_weight: 9.99999974738e-05
training_config {
batch_size_per_gpu: 4
num_epochs: 150
learning_rate {
soft_start_annealing_schedule {
min_learning_rate: 5e-06
max_learning_rate: 5e-04
soft_start: 0.10000000149
annealing: 0.699999988079
regularizer {
type: L1
weight: 3.00000002618e-09
optimizer {
adam {
epsilon: 9.99999993923e-09
beta1: 0.899999976158
beta2: 0.999000012875
cost_scaling {
initial_exponent: 20.0
increment: 0.005
decrement: 1.0
checkpoint_interval: 10
bbox_rasterizer_config {
key: "a"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
bbox_min_radius: 1.0
key: "b"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
key: "c"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
key: "d"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
key: "e"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
key: "f"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
key: "g"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
key: "h"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
key: "j"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
key: "k"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
key: "l"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
key: "m"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
key: "n"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
key: "p"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
key: "r"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
key: "s"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
key: "t"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
key: "u"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
key: "v"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
key: "w"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
key: "x"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
key: "y"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
key: "z"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
key: "zero"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
key: "one"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
key: "two"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
key: "three"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
key: "four"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
key: "five"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
key: "six"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
key: "seven"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
key: "eight"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
key: "nine"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
deadzone_radius: 0.400000154972
And this is the accuracy i achieve after 450 epochs:
a 11.9462
b 8.30766
c 19.3613
d 14.6858
e 10.8618
eight 3.43902
f 23.0676
five 17.7585
four 3.84648
g 7.12558
h 0.0393383
j 0
k 12.4779
l 15.5864
m 0
n 11.8924
nine 0.793651
one 66.2518
p 4.1165
r 0
s 9.66167
seven 0.41767
six 25.0398
t 5.57963
three 0
two 0
u 0
v 13.7759
w 0.690544
x 21.5387
y 5.55486
z 7.93171
zero 28.8068
Could someone give me some hints as to what i’m doing wrong?
I’ve also tested other resolutions such as: 1920x1088, 1280x720, 480x272 and i’m achieving simmilar results to this.
I was able to train an ssd model using the same dataset and i achieved 95% accuracy there? Any idea why?
