Title: trajopt_plan_cspace ~0.5–1.0s on RTX 4050 (Windows) — expected latency for standalone TrajOpt?
I’m integrating cuMotion TrajOpt directly via the C++ API (TrajectoryOptimizer::planToCSpaceTarget / trajopt_plan_cspace), not the full Isaac ROS motion planner (no graph search, no NVBlox). I’d like to understand whether our planning latency is expected, and which parameters matter most for a standalone c-space TrajOpt call.
Environment
- GPU: Laptop RTX 4050 (Windows)
- cuMotion: 1.1.0 (CUDA 13, prebuilt Windows x86_64)
- Robot: Custom 5-DOF manipulator (tube / Transhift), URDF + XRDF collision spheres
- World: Static virtual walls from safe-zone union (cuboids), world collision enabled (default), self-collision disabled
- API: CreateDefaultTrajectoryOptimizerConfig → CreateTrajectoryOptimizer → planToCSpaceTarget(q_start, q_target) per segment
- Post-processing: Sample TrajOpt output at 125 Hz only; no post-TrajOpt retime / TrajGen
Config (mostly cuMotion defaults)
We do not override most TrajOpt params in our app config:
- trajopt/num_knots_per_trajectory: default (32)
- trajopt/num_seeds: default (4) — not exposed in our Rust wrapper yet
- trajopt/pbo/enabled: default (true)
- ik/num_seeds, ik/max_reattempts: default (c-space targets; IK may be less relevant)
- enable_self_collision: false
- enable_world_collision: default (true)
- App-level trajopt_retries: 1 on success path (tests use 16)
Measured timing (single segment, 2 waypoints, 1 attempt, Success)
Case | j0 travel | c-space path length | trajopt_setup | trajopt_solve | total plan
Easier | 58 mm | 2.21 | ~124 ms | ~492 ms | ~617 ms
Easier (rev) | 58 mm | 2.23 | ~138 ms | ~563 ms | ~701 ms
Harder | 146 mm (detour/walls) | 3.09 | ~134 ms | ~1004 ms | ~1140 ms
Notes:
- trajopt_solve dominates (~80–88% of plan time).
- trajopt_setup (~130 ms) is from recreating optimizer config + CreateTrajectoryOptimizer on every attempt/segment.
- Sampling 400–480 knots at 125 Hz is <1 ms (not the bottleneck).
Failure case (separate issue)
When start/goal are near zone boundaries, we sometimes get GeometricPlanningFailure and with trajopt_retries=16 total time reaches ~30+ s (~2 s per failed attempt). I understand that’s a different problem from the successful ~1 s case.
Questions
- For standalone planToCSpaceTarget (no graph planner), is ~0.5–1.0 s on a desktop RTX 4050 expected with default TrajOpt config (4 seeds, PBO on, 32 knots, world collision)?
- The cuRobo blog mentions ~100 ms median motion planning on Jetson Orin — does that benchmark include the full motion generation pipeline (graph + TrajOpt), and is it not directly comparable to a single TrajOpt c-space call with virtual walls?
- For fastest c-space TrajOpt while keeping world collision, which parameters should we tune first?
- trajopt/num_seeds
- trajopt/pbo/enabled, num_particles_per_problem, num_iterations
- L-BFGS iteration limits (initial_iterations, retiming_*)
- Is trajopt/num_seeds=4 still applied for c-space targets (linear interpolation seeds), or mainly for task-space IK seeds?
- Any recommendation on reusing TrajectoryOptimizer across plans vs rebuilding each time (we pay ~130 ms setup per call)?
Happy to provide URDF/XRDF snippets, safe-zone wall setup, or a minimal repro if helpful.
