Do you have hardware from Seeed? If so, then that is the correct software (I assume you also downloaded from Seeed).
Some explanation might clear up confusion…
During the normal flash a default image is created. That comes from the “sample root filesystem
” package, which is purely Ubuntu. When running “sudo ./apply_binaries.sh
”, it overlays NVIDIA drivers on top of that. You’d only run apply_binaries.sh
once for a given sample rootfs. Running it a second time would attempt to install content which is already there.
Seeed might have modified the sample root filesystem. I don’t know. If they did, then possibly they also modified what is installed from apply_binaries.sh
. Don’t know. If Seeed did modify that, then it seems logical they would have also modified arguments (normally one would not use arguments to apply_binaries.sh
, but that’s on a purely NVIDIA dev kit).
The default install location of flash software is to produce a directory “Linux_for_Tegra/
”. If this was from the NVIDIA SDKM, then you’d have:
~/nvidia/nvidia_sdk/JetPack...version.../Linux_for_Tegra/
Possibly Seeed has this elsewhere? Don’t know.
The apply_binaries.sh
file itself is normally always at “Linux_for_Tegra/apply_binaries.sh
”. If you have this file somewhere else, then I’d expect an error and to have the script tell you about its options. This would be true regardless of whether it is a stock NVIDIA version or a Seeed version (which might be the same, I don’t know). Is apply_binaries.sh
in the “Linux_for_Tegra/
” subdirectory?
Incidentally, this is applied to content in “Linux_for_Tegra/rootfs/
”. That content would need to exist prior to running apply_binaries.sh
All of the above just prepares the rootfs for flash. There is a separate script for setting up first boot login, and it is at:
Linux_for_Tegra/tools/l4t_create_default_user.sh
(you’d execute that from “Linux_for_Tegra/
” via “sudo ./tools/l4t_create_default_user.sh
Note that I don’t know what modifications Seeed makes, so this might not be 100% correct for you.
