Hi, I have trouble with cmake of hector slam. The same works on the x86 architecture, I have tested it but it’s not working on my TX2. please help me.
tx2slam@tx2slam-desktop:~/catkin_ws$ source devel/setup.bash
tx2slam@tx2slam-desktop:~/catkin_ws$ catkin_make
Base path: /home/tx2slam/catkin_ws
Source space: /home/tx2slam/catkin_ws/src
Build space: /home/tx2slam/catkin_ws/build
Devel space: /home/tx2slam/catkin_ws/devel
Install space: /home/tx2slam/catkin_ws/install
Running command: “make cmake_check_build_system” in “/home/tx2slam/catkin_ws/build”
– Using CATKIN_DEVEL_PREFIX: /home/tx2slam/catkin_ws/devel
– Using CMAKE_PREFIX_PATH: /home/tx2slam/catkin_ws/devel;/opt/ros/melodic
– This workspace overlays: /home/tx2slam/catkin_ws/devel;/opt/ros/melodic
– Found PythonInterp: /usr/bin/python2 (found suitable version “2.7.17”, minimum required is “2”)
– Using PYTHON_EXECUTABLE: /usr/bin/python2
– Using Debian Python package layout
– Using empy: /usr/bin/empy
– Using CATKIN_ENABLE_TESTING: ON
– Call enable_testing()
– Using CATKIN_TEST_RESULTS_DIR: /home/tx2slam/catkin_ws/build/test_results
– Found gtest sources under ‘/usr/src/googletest’: gtests will be built
– Found gmock sources under ‘/usr/src/googletest’: gmock will be built
– Found PythonInterp: /usr/bin/python2 (found version “2.7.17”)
– Using Python nosetests: /usr/bin/nosetests-2.7
– catkin 0.7.23
– BUILD_SHARED_LIBS is on
– Using CATKIN_WHITELIST_PACKAGES: hector_compressed_map_transport;hector_geotiff;hector_geotiff_plugins;hector_imu_attitude_to_tf;hector_map_server;hector_map_tools;hector_mapping;hector_marker_drawing;hector_nav_msgs;hector_slam;hector_slam_launch;hector_trajectory_server;rplidar_ros
– ~~ traversing 13 packages in topological order:
– ~~ - hector_slam (metapackage)
– ~~ - hector_slam_launch
– ~~ - hector_map_tools
– ~~ - hector_nav_msgs
– ~~ - hector_geotiff
– ~~ - hector_geotiff_plugins
– ~~ - hector_marker_drawing
– ~~ - hector_compressed_map_transport
– ~~ - rplidar_ros
– ~~ - hector_imu_attitude_to_tf
– ~~ - hector_map_server
– ~~ - hector_trajectory_server
– ~~ - hector_mapping
– +++ processing catkin metapackage: ‘hector_slam’
– ==> add_subdirectory(RPLidar_Hector_SLAM/hector_slam/hector_slam)
– +++ processing catkin package: ‘hector_slam_launch’
– ==> add_subdirectory(RPLidar_Hector_SLAM/hector_slam/hector_slam_launch)
– +++ processing catkin package: ‘hector_map_tools’
– ==> add_subdirectory(RPLidar_Hector_SLAM/hector_slam/hector_map_tools)
– Using these message generators: gencpp;geneus;genlisp;gennodejs;genpy
CMake Warning at /opt/ros/melodic/share/catkin/cmake/catkin_package.cmake:166 (message):
catkin_package() DEPENDS on ‘Eigen’ but neither ‘Eigen_INCLUDE_DIRS’ nor
‘Eigen_LIBRARIES’ is defined.
Call Stack (most recent call first):
/opt/ros/melodic/share/catkin/cmake/catkin_package.cmake:102 (_catkin_package)
RPLidar_Hector_SLAM/hector_slam/hector_map_tools/CMakeLists.txt:51 (catkin_package)
– +++ processing catkin package: ‘hector_nav_msgs’
– ==> add_subdirectory(RPLidar_Hector_SLAM/hector_slam/hector_nav_msgs)
– hector_nav_msgs: 0 messages, 5 services
– +++ processing catkin package: ‘hector_geotiff’
– ==> add_subdirectory(RPLidar_Hector_SLAM/hector_slam/hector_geotiff)
– +++ processing catkin package: ‘hector_geotiff_plugins’
– ==> add_subdirectory(RPLidar_Hector_SLAM/hector_slam/hector_geotiff_plugins)
– +++ processing catkin package: ‘hector_marker_drawing’
– ==> add_subdirectory(RPLidar_Hector_SLAM/hector_slam/hector_marker_drawing)
– +++ processing catkin package: ‘hector_compressed_map_transport’
– ==> add_subdirectory(RPLidar_Hector_SLAM/hector_slam/hector_compressed_map_transport)
CMake Error at /opt/ros/melodic/share/cv_bridge/cmake/cv_bridgeConfig.cmake:113 (message):
Project ‘cv_bridge’ specifies ‘/usr/local/include/opencv’ as an include
dir, which is not found. It does neither exist as an absolute directory
nor in ‘${{prefix}}//usr/local/include/opencv’. Check the issue tracker
‘Issues · ros-perception/vision_opencv · GitHub’ and consider
creating a ticket if the problem has not been reported yet.
/opt/ros/melodic/share/catkin/cmake/catkinConfig.cmake:76 (find_package)
RPLidar_Hector_SLAM/hector_slam/hector_compressed_map_transport/CMakeLists.txt:7 (find_package)
– Configuring incomplete, errors occurred!
See also “/home/tx2slam/catkin_ws/build/CMakeFiles/CMakeOutput.log”.
See also “/home/tx2slam/catkin_ws/build/CMakeFiles/CMakeError.log”.
Makefile:320: recipe for target ‘cmake_check_build_system’ failed
make: *** [cmake_check_build_system] Error 1
Invoking “make cmake_check_build_system” failed
