[09/17/2022-23:41:05] [W] [TRT] Weights [name=Conv_30 + PWN(PWN(Sigmoid_31), Mul_32).weight] had the following issues when converted to FP16:
[09/17/2022-23:41:05] [W] [TRT] - Subnormal FP16 values detected.
[09/17/2022-23:41:05] [W] [TRT] If this is not the desired behavior, please modify the weights or retrain with regularization to reduce the magnitude of the weights.
[09/17/2022-23:41:06] [W] [TRT] Weights [name=Conv_30 + PWN(PWN(Sigmoid_31), Mul_32).weight] had the following issues when converted to FP16:
[09/17/2022-23:41:06] [W] [TRT] - Subnormal FP16 values detected.
[09/17/2022-23:41:06] [W] [TRT] If this is not the desired behavior, please modify the weights or retrain with regularization to reduce the magnitude of the weights.
