Hi. I’m running deepstream with 8 rtsp streams. I’m trying to save a jpg image from each stream every 30 seconds, however the frames saved and source id don’t match. Here is the code I used.
cv::Mat
Mercury::getRGBFrame(GstMapInfo in_map_info, gint idx) {
// To access the frame
NvBufSurface *surface = NULL;
NvBufSurface surface_idx;
NvBufSurfTransformRect src_rect, dst_rect;
surface = (NvBufSurface *) in_map_info.data;
surface_idx = *surface;
surface_idx.surfaceList = &(surface->surfaceList[idx]);
surface_idx.numFilled = surface_idx.batchSize = 1;
int batch_size = surface_idx.batchSize;
src_rect.top = 0;
src_rect.left = 0;
src_rect.width = (guint) surface->surfaceList[idx].width;
src_rect.height= (guint) surface->surfaceList[idx].height;
dst_rect.top = 0;
dst_rect.left = 0;
dst_rect.width = (guint) surface->surfaceList[idx].width;
dst_rect.height= (guint) surface->surfaceList[idx].height;
NvBufSurfTransformParams nvbufsurface_params;
nvbufsurface_params.src_rect = &src_rect;
nvbufsurface_params.dst_rect = &dst_rect;
nvbufsurface_params.transform_flag = NVBUFSURF_TRANSFORM_CROP_SRC | NVBUFSURF_TRANSFORM_CROP_DST;
nvbufsurface_params.transform_filter = NvBufSurfTransformInter_Default;
NvBufSurface *dst_surface = NULL;
NvBufSurfaceCreateParams nvbufsurface_create_params;
nvbufsurface_create_params.gpuId = surface->gpuId;
nvbufsurface_create_params.width = (guint) surface->surfaceList[idx].width;
nvbufsurface_create_params.height = (guint) surface->surfaceList[idx].height;
nvbufsurface_create_params.size = 0;
// nvbufsurface_create_params.isContiguous = true;
nvbufsurface_create_params.colorFormat = NVBUF_COLOR_FORMAT_RGBA;
nvbufsurface_create_params.layout = NVBUF_LAYOUT_PITCH;
// THE memType PARAM IS SET TO CUDA UNIFIED IN dGPU DEVICES COMMENT IT out
// AND USE THE IMMEDIATE NEXT LINE TO SET THE memType PARAM FOR JETSON DEVICES
#ifdef PLATFORM_TEGRA
nvbufsurface_create_params.memType = NVBUF_MEM_DEFAULT;
#else
nvbufsurface_create_params.memType = NVBUF_MEM_CUDA_UNIFIED;
#endif
cudaError_t cuda_err = cudaSetDevice (surface->gpuId);
cudaStream_t cuda_stream;
cuda_err = cudaStreamCreate(&cuda_stream);
int create_result = NvBufSurfaceCreate(&dst_surface, batch_size, &nvbufsurface_create_params);
NvBufSurfTransformConfigParams transform_config_params;
NvBufSurfTransform_Error err;
transform_config_params.compute_mode = NvBufSurfTransformCompute_Default;
transform_config_params.gpu_id = surface->gpuId;
transform_config_params.cuda_stream = cuda_stream;
err = NvBufSurfTransformSetSessionParams (&transform_config_params);
NvBufSurfaceMemSet (dst_surface, 0, 0, 0);
err = NvBufSurfTransform (&surface_idx, dst_surface, &nvbufsurface_params);
if (err != NvBufSurfTransformError_Success) {
g_print ("NvBufSurfTransform failed with error %d while converting buffer\n", err);
NvBufSurfaceMap (dst_surface, 0, 0, NVBUF_MAP_READ);
NvBufSurfaceSyncForCpu (dst_surface, 0, 0);
cv::Mat bgr_frame = cv::Mat (cv::Size(nvbufsurface_create_params.width, nvbufsurface_create_params.height), CV_8UC3);
cv::Mat in_mat = cv::Mat (nvbufsurface_create_params.height, nvbufsurface_create_params.width, CV_8UC4, dst_surface->surfaceList[0].mappedAddr.addr[0], dst_surface->surfaceList[0].pitch);
#if (CV_VERSION_MAJOR >= 4)
cv::cvtColor (in_mat, bgr_frame, COLOR_RGBA2BGR);
#else
cv::cvtColor (in_mat, bgr_frame, CV_RGBA2BGR);
#endif
NvBufSurfaceUnMap(dst_surface, 0 , 0);
NvBufSurfaceUnMap(&surface_idx, 0 , 0);
NvBufSurfaceDestroy(dst_surface);
cudaStreamDestroy (cuda_stream);
return bgr_frame;
