"By default “nvinfer” works with networks having only one input layer for video frames. If the network has more than one input layer, the custom library can implement NvDsInferInitializeInputLayers interface for initializing the other input layers. “nvinfer” assumes that the other input layers have static input information and hence this method is called only once before the first inference.
Refer the FasterRCNN sample provided with the SDK for a sample implementation of the interface."
How this can help if i need to update that static input every now and then while the stream is up and running?
• DeepStream Version
• TensorRT Version
it is a special requirement, there is no deepstream sample with the same inputs.
you need custom preprocess, please refer to the similar sample deepstream-3d-action-recognition, which has speicial input. here is App introducetion: DeepStream 3D Action Recognition App — DeepStream 6.1.1 Release documentation
