• Hardware Platform (Jetson / GPU) - Dev container on WSL with GPU A3000
• DeepStream Version - 7.0 (Container)
• TensorRT Version - 8.6.1
• NVIDIA GPU Driver Version (valid for GPU only) - 551.86
• Issue Type( questions, new requirements, bugs) - question
I am trying to setup a simple deepstream pipeline for creating a stereo disparity map with two inputs and am using ESS DNN model. Before starting with deepstream I verified the working of the model and it works well with tensorrt. I used the probe functions to customize the input hoping this is the input initialization. But I get this error “Failed to initialize non-image input layers”. I need help with a direction to cusotmize the nvinfer or input initialization in python.
This is the deserialized model for knowing the input and output dimensions along with the error.
INFO: ../nvdsinfer/nvdsinfer_model_builder.cpp:612 [Implicit Engine Info]: layers num: 4
0 INPUT kFLOAT input_left 3x576x960
1 INPUT kFLOAT input_right 3x576x960
2 OUTPUT kFLOAT output_conf 576x960
3 OUTPUT kFLOAT output_left 576x960
0:00:06.319003623 26086 0x56400d53df00 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2198> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-7.0/samples/models/dnn_stereo_disparity_v4.0.0/ess.engine
0:00:06.343570956 26086 0x56400d53df00 WARN nvinfer gstnvinfer.cpp:679:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::initNonImageInputLayers() <nvdsinfer_context_impl.cpp:1622> [UID = 1]: More than one input layers but custom initialization function not implemented
0:00:06.343609185 26086 0x56400d53df00 ERROR nvinfer gstnvinfer.cpp:676:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1386> [UID = 1]: Failed to initialize non-image input layers
0:00:06.357136893 26086 0x56400d53df00 WARN nvinfer gstnvinfer.cpp:912:gst_nvinfer_start:<primary-inference> error: Failed to create NvDsInferContext instance
0:00:06.357977710 26086 0x56400d53df00 WARN nvinfer gstnvinfer.cpp:912:gst_nvinfer_start:<primary-inference> error: Config file path: disparity_pgie_config.txt, NvDsInfer Error: NVDSINFER_CUSTOM_LIB_FAILED
Error: gst-resource-error-quark: Failed to create NvDsInferContext instance (1): gstnvinfer.cpp(912): gst_nvinfer_start (): /GstPipeline:deepstream-pipeline/GstNvInfer:primary-inference:
Exiting pipeline
Here is the config file,
disparity_pgie_config.txt (2.8 KB)
This is my probe function attached to pgie sink
# Probe function to extract and save input images
def pgie_sink_pad_buffer_probe(pad, info, u_data):
gst_buffer = info.get_buffer()
if not gst_buffer:
print("Unable to get GstBuffer")
return Gst.PadProbeReturn.OK
batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
l_frame = batch_meta.frame_meta_list
left_image = None
right_image = None
while l_frame is not None:
try:
except StopIteration:
break
# Get the frame's image data
frame_number = frame_meta.frame_num
surface = pyds.get_nvds_buf_surface(hash(gst_buffer), frame_meta.batch_id)
if frame_number == 0:
left_image = np.array(surface, copy=True, order='C', dtype=np.uint8)
elif frame_number == 1:
right_image = np.array(surface, copy=True, order='C', dtype=np.uint8)
try:
l_frame = l_frame.next
break
if left_image is not None and right_image is not None:
combined_images = np.array([left_image, right_image])
# Replace the input image data with the array of arrays
for i, img in enumerate(combined_images):
surface = pyds.get_nvds_buf_surface(hash(gst_buffer), i)
np.copyto(surface, img)
