linuxdev,
Get some info for your suggestions as below. Please help to check. Thanks!
---- max performance ----
My performance is maximized with 6 cpu cores & max power, proved by jetson_clocks.sh. See below:
$ sudo ./jetson_clocks.sh --show
SOC family:tegra186 Machine:quill
Online CPUs: 0-5
CPU Cluster Switching: Disabled
cpu0: Gonvernor=schedutil MinFreq=2035200 MaxFreq=2035200 CurrentFreq=2035200
cpu1: Gonvernor=schedutil MinFreq=2035200 MaxFreq=2035200 CurrentFreq=2035200
cpu2: Gonvernor=schedutil MinFreq=2035200 MaxFreq=2035200 CurrentFreq=2035200
cpu3: Gonvernor=schedutil MinFreq=2035200 MaxFreq=2035200 CurrentFreq=2035200
cpu4: Gonvernor=schedutil MinFreq=2035200 MaxFreq=2035200 CurrentFreq=2035200
cpu5: Gonvernor=schedutil MinFreq=2035200 MaxFreq=2035200 CurrentFreq=2035200
GPU MinFreq=1300500000 MaxFreq=1300500000 CurrentFreq=1300500000
EMC MinFreq=40800000 MaxFreq=1866000000 CurrentFreq=1866000000 FreqOverride=1
---- “route” looks OK ----
nvidia@tegra-ubuntu:~$ route
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
link-local * 255.255.0.0 U 1000 0 0 eth0
192.168.1.0 * 255.255.255.0 U 100 0 0 eth0
---- ifconfig info: dropped RX pkts ----
“ifconfig” shows increasing dropped RX packets, and it’s the only error. See below detail info:
nvidia@tegra-ubuntu:~ date
Mon Oct 22 03:16:45 UTC 2018
nvidia@tegra-ubuntu:~ ifconfig eth0
eth0 Link encap:Ethernet HWaddr 00:04:4b:a5:a2:31
inet addr:192.168.1.101 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fe80::f2d4:57fd:7e91:c927/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:1584 errors:0 dropped:416 overruns:0 frame:0
TX packets:1085 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:124090 (124.0 KB) TX bytes:151536 (151.5 KB)
Interrupt:42
Mon Oct 22 03:16:49 UTC 2018
RX packets:1621 errors:0 dropped:420 overruns:0 frame:0
TX packets:1113 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:127100 (127.1 KB) TX bytes:155772 (155.7 KB)
Interrupt:42
Mon Oct 22 03:16:53 UTC 2018
RX packets:1659 errors:0 dropped:424 overruns:0 frame:0
TX packets:1142 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:130176 (130.1 KB) TX bytes:160226 (160.2 KB)
Interrupt:42
nvidia@tegra-ubuntu:~$ date
Mon Oct 22 03:16:57 UTC 2018
---- “dmesg --follow”: some pci0 issue, BUT no new message during “ping”. ----
[ 8.265629] dhd_preinit_ioctls pspretend_threshold for HostAPD failed -23
[ 8.269822] Firmware version = wl0: May 4 2017 13:48:00 version 7.35.221.21 (r697384) FWID 01-58d9d0b3
[ 8.271997] dhd_interworking_enable: failed to set WNM info, ret=-23
[ 8.272167] tegra_sysfs_on
[ 8.287465] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 8.320431] usb 1-2.1: New USB device found, idVendor=05e3, idProduct=0606
[ 8.331993] usb 1-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 8.339473] usb 1-2.1: Product: USB Hub 2.0
[ 8.339475] usb 1-2.1: Manufacturer: ALCOR
[ 8.339819] usb 1-2.1: ep 0x81 - rounding interval to 1024 microframes, ep desc says 2040 microframes
[ 8.340468] hub 1-2.1:1.0: USB hub found
[ 8.340596] hub 1-2.1:1.0: 4 ports detected
[ 8.404274] CFGP2P-ERROR) wl_cfgp2p_add_p2p_disc_if : P2P interface registered
[ 8.428942] usb 1-3.2: new high-speed USB device number 5 using xhci-tegra
[ 8.442372] WLC_E_IF: NO_IF set, event Ignored
[ 8.525893] usb 1-3.2: New USB device found, idVendor=0bda, idProduct=8153
[ 8.532836] usb 1-3.2: New USB device strings: Mfr=1, Product=2, SerialNumber=6
[ 8.540232] usb 1-3.2: Product: USB 10/100/1000 LAN
[ 8.545166] usb 1-3.2: Manufacturer: Realtek
[ 8.549494] usb 1-3.2: SerialNumber: 000000000000
[ 8.555813] usb 1-3.2: rejected 2 configurations due to insufficient available bus power
[ 8.564031] usb 1-3.2: no configuration chosen from 2 choices
[ 8.640835] usb 1-2.1.4: new low-speed USB device number 6 using xhci-tegra
[ 8.742067] usb 1-2.1.4: New USB device found, idVendor=1a2c, idProduct=0b2a
[ 8.749170] usb 1-2.1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 8.756821] usb 1-2.1.4: Product: USB Keyboard
[ 8.761299] usb 1-2.1.4: Manufacturer: SEM
[ 8.767134] usb 1-2.1.4: ep 0x81 - rounding interval to 64 microframes, ep desc says 80 microframes
[ 8.776558] usb 1-2.1.4: ep 0x82 - rounding interval to 64 microframes, ep desc says 80 microframes
[ 8.785644] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 8.795875] input: SEM USB Keyboard as /devices/3530000.xhci/usb1/1-2/1-2.1/1-2.1.4/1-2.1.4:1.0/0003:1A2C:0B2A.0001/input/input4
[ 8.861222] hid-generic 0003:1A2C:0B2A.0001: input,hidraw0: USB HID v1.10 Keyboard [SEM USB Keyboard] on usb-3530000.xhci-2.1.4/input0
[ 8.877111] input: SEM USB Keyboard as /devices/3530000.xhci/usb1/1-2/1-2.1/1-2.1.4/1-2.1.4:1.1/0003:1A2C:0B2A.0002/input/input5
[ 8.945676] hid-generic 0003:1A2C:0B2A.0002: input,hidraw1: USB HID v1.10 Device [SEM USB Keyboard] on usb-3530000.xhci-2.1.4/input1
[ 8.996661] fuse init (API version 7.23)
[ 9.244833] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 9.253198] tegra-pcie 10003000.pcie-controller: link 2 down, ignoring
[ 9.259811] tegra-pcie 10003000.pcie-controller: PCIE: no end points detected
[ 9.267369] tegra-pcie 10003000.pcie-controller: PCIE: Disable power rails
[ 9.602339] xhci-tegra 3530000.xhci: tegra_xhci_mbox_work mailbox command 5
[ 9.609435] xhci-tegra 3530000.xhci: tegra_xhci_mbox_work ignore firmware MBOX_CMD_DEC_SSPI_CLOCK request
[ 10.496136] eqos 2490000.ether_qos eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[ 10.505292] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 17.646438] gk20a 17000000.gp10b: railgate is disabled.
