Hi All,
Does NVIDIA plan to implement hardware accelerated MPEG-4 encoding for the TX2? I realize it is quite an old standard by now, but some of our customers still require it.
I have tried encoding via the CPU with FFmpeg just for a test. At 1080P it is able to reach 25 FPS, while top shows about 215% CPU. This was encoding from a single file in a loop, though my actual use case will be encoding from the camera input.
Prior to this test, I ran the following, which seemed to give the best numbers, FYI:
sudo ./jetson_clocks.sh
sudo nvpmodel -0
sudo echo performance | sudo tee /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
Thanks,
Chris Richardson
