TX2 WIFI Hotspot
Where can I see the TX2 supported country code? And the applicable channel?
What is Hostapd for Hot Spot Configuration?
I did not see the AP according to this configuration
interface=wlan0
driver=nl80211
hw_mode=a
channel=36
ieee80211ac=1
ssid=WLAN-TEST
auth_algs=1
wpa=2
wpa_key_mgmt=WPA-PSK
wpa_pairwise=TKIP
rsn_pairwise=CCMP
wpa_passphrase=12345678
ctrl_interface=/var/run/hostapd
ctrl_interface_group=0
After changing the configuration or not
interface=wlan0
ssid=Calmcar
hw_mode=a
channel=36
wpa=2
driver=nl80211
ieee80211n=1
ieee80211ac=1
wpa_pairwise=TKIP
rsn_pairwise=CCMP
auth_algs=1
root@tegra-ubuntu:/etc/hostapd# sudo hostapd -B /etc/hostapd/hostapd.conf
Configuration file: /etc/hostapd/hostapd.conf
[ 5135.495800]
[ 5135.495800] Dongle Host Driver, version 1.201.82 (r)
[ 5135.495800] Compiled in drivers/net/wireless/bcmdhd on Aug 23 2017 at 18:30:8
[ 5135.511615] wl_android_wifi_on in
[ 5135.515044] wifi_platform_set_power = 1
[ 5135.794278] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[ 5135.873574] sdhci-tegra 3440000.sdhci: Tuning already done, restoring the be0
[ 5135.883309] F1 signature read @0x18000000=0x17214354
[ 5135.896309] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 5135.903740] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 5136.012305] dhdsdio_write_vars: Download, Upload and compare of NVRAM succee.
[ 5136.062208] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
[ 5136.068478] gpio tegra-gpio-aon wake69 for gpio=59(FF:3)
[ 5136.073858] gpio tegra-gpio-aon wake69 for gpio=59(FF:3)
[ 5136.079165] Enabling wake69
[ 5136.084896] wifi_platform_get_mac_addr
[ 5136.090825] Firmware up: op_mode=0x0005, MAC=00:04:4b:8d:5a:30
[ 5136.104879] dhd_preinit_ioctls pspretend_threshold for HostAPD failed  -23
[ 5136.118804] Firmware version = wl0: May  4 2017 13:48:00 version 7.35.221.213
[ 5136.131650] dhd_interworking_enable: failed to set WNM info, ret=-23
[ 5136.138360] tegra_sysfs_on
[ 5136.202311] CFG80211-ERROR) wl_cfg80211_del_station : [ 5136.203966] dhd_ndo3
[ 5136.203969] dhd_inet6_work_handler: Adding host ip for NDO failed -23
[ 5136.219889] Disconnect STA : ff:ff:ff:ff:ff:ff scb_val.val 3
Using interface wlan0 with hwaddr 00:04:4b:8d:5a:30 and ssid "Calmcar"
[ 5136.264689] CFG80211-ERROR) check_dev_role_integrity : device role select fad
wlan0: interface state UNINITIALIZED->ENABLED
wlan0: AP-ENABLED
Calmcar-Bao,
If you are using PX2, please move the Drive forum board.
As for country code for tx2, please refer to wifi compliance document:
https://developer.nvidia.com/embedded/dlc/Jetson-TX1-OEM-Wireless-Compliance-Guide
My fault.
Has been switching between the two platforms recently.
This problem is seen in TX2.
TX2 hotspot configuration can say it? I can’t open the hotspot according to the above configuration
Please try to use different channels which are valid in your country.
