Are there any recommendations on what heatsink should be used on the TX2i? We have previously used connecttech as supplier for TX2, but cannot find any heatsinks for TX2i.
Hi helgeanl,
If the heatsink can work well on TX2, it can also work well on TX2i, as in fact TX2 has more critical temperature request than TX2i. But you need to choose the heatsink that using main mounting holes to connect TTP since the heat sink mounting pattern holes that are provided on Jetson TX2 are not available on TX2i. Please check their thermal design guide in download center for detail info.
