I use the information from page U-Boot Customization, based on Release 32.3. According to the SDK Mannager, I am using JetPack 4.3, which uses L4T 32.3.1.
In the mean time I have found that when I install the Device Tree Compiler package, instead of downloading and compiling the tool myself, the 3 header files, fdt.h, libfdt_env.h and libfdt.h, are not part of the Ubuntu package.
When using the Device Tree Compiler from the Ubuntu package, I am able to build U-Boot albeit the build contains a fair amount of build warnings.
This might solve the build failing, but I am reluctant to use this u-boot since I am not sure it will work correctly given the build warnings:
DTC arch/arm/dts/tegra20-harmony.dtb
arch/arm/dts/skeleton.dtsi:12.9-50: Warning (unit_address_vs_reg): /memory: node has a reg or ranges property, but no unit name
also defined at arch/arm/dts/tegra20-harmony.dts:24.9-26.4
arch/arm/dts/tegra20-harmony.dts:38.15-49.8: Warning (unit_address_vs_reg): /host1x@50000000/dc@54200000/rgb/display-timings/timing@0: node has a unit name, but no reg or ranges property
arch/arm/dts/tegra20.dtsi:585.27-645.4: Warning (pci_bridge): /pcie-controller@80003000: node name is not "pci" or "pcie"
also defined at arch/arm/dts/tegra20-harmony.dts:601.27-617.4
arch/arm/dts/tegra20-harmony.dtb: Warning (unit_address_format): Failed prerequisite 'pci_bridge'
arch/arm/dts/tegra20-harmony.dtb: Warning (pci_device_reg): Failed prerequisite 'pci_bridge'
arch/arm/dts/tegra20-harmony.dtb: Warning (pci_device_bus_num): Failed prerequisite 'pci_bridge'
arch/arm/dts/tegra20.dtsi:647.15-659.4: Warning (unique_unit_address): /usb@c5000000: duplicate unit-address (also used in node /usb-phy@c5000000)
also defined at arch/arm/dts/tegra20-harmony.dts:619.15-621.4
arch/arm/dts/tegra20.dtsi:684.15-694.4: Warning (unique_unit_address): /usb@c5004000: duplicate unit-address (also used in node /usb-phy@c5004000)
also defined at arch/arm/dts/tegra20-harmony.dts:627.15-630.4
arch/arm/dts/tegra20.dtsi:709.15-719.4: Warning (unique_unit_address): /usb@c5008000: duplicate unit-address (also used in node /usb-phy@c5008000)
also defined at arch/arm/dts/tegra20-harmony.dts:638.15-640.4
DTC arch/arm/dts/tegra20-medcom-wide.dtb
also defined at arch/arm/dts/tegra20-tamonten.dtsi:7.9-9.4
also defined at arch/arm/dts/tegra20-medcom-wide.dts:18.9-20.4
arch/arm/dts/tegra20-medcom-wide.dtb: Warning (unit_address_format): Failed prerequisite 'pci_bridge'
arch/arm/dts/tegra20-medcom-wide.dtb: Warning (pci_device_reg): Failed prerequisite 'pci_bridge'
arch/arm/dts/tegra20-medcom-wide.dtb: Warning (pci_device_bus_num): Failed prerequisite 'pci_bridge'
arch/arm/dts/tegra20-tamonten.dtsi:12.8-19.5: Warning (simple_bus_reg): /host1x@50000000/hdmi: missing or empty reg/ranges property
also defined at arch/arm/dts/tegra20-tamonten.dtsi:475.15-477.4
also defined at arch/arm/dts/tegra20-medcom-wide.dts:39.15-41.4
DTC arch/arm/dts/tegra20-paz00.dtb
also defined at arch/arm/dts/tegra20-paz00.dts:19.9-21.4
arch/arm/dts/tegra20-paz00.dtb: Warning (unit_address_format): Failed prerequisite 'pci_bridge'
arch/arm/dts/tegra20-paz00.dtb: Warning (pci_device_reg): Failed prerequisite 'pci_bridge'
arch/arm/dts/tegra20-paz00.dtb: Warning (pci_device_bus_num): Failed prerequisite 'pci_bridge'
also defined at arch/arm/dts/tegra20-paz00.dts:38.15-40.4
DTC arch/arm/dts/tegra20-plutux.dtb
also defined at arch/arm/dts/tegra20-plutux.dts:18.9-20.4
arch/arm/dts/tegra20-plutux.dtb: Warning (unit_address_format): Failed prerequisite 'pci_bridge'
arch/arm/dts/tegra20-plutux.dtb: Warning (pci_device_reg): Failed prerequisite 'pci_bridge'
arch/arm/dts/tegra20-plutux.dtb: Warning (pci_device_bus_num): Failed prerequisite 'pci_bridge'
DTC arch/arm/dts/tegra20-seaboard.dtb
also defined at arch/arm/dts/tegra20-seaboard.dts:33.9-35.4
arch/arm/dts/tegra20-seaboard.dts:47.15-59.8: Warning (unit_address_vs_reg): /host1x@50000000/dc@54200000/rgb/display-timings/timing@0: node has a unit name, but no reg or ranges property
arch/arm/dts/tegra20-seaboard.dtb: Warning (unit_address_format): Failed prerequisite 'pci_bridge'
arch/arm/dts/tegra20-seaboard.dtb: Warning (pci_device_reg): Failed prerequisite 'pci_bridge'
arch/arm/dts/tegra20-seaboard.dtb: Warning (pci_device_bus_num): Failed prerequisite 'pci_bridge'
also defined at arch/arm/dts/tegra20-seaboard.dts:773.15-777.4
also defined at arch/arm/dts/tegra20-seaboard.dts:785.15-789.4
also defined at arch/arm/dts/tegra20-seaboard.dts:797.15-799.4
DTC arch/arm/dts/tegra20-tec.dtb
also defined at arch/arm/dts/tegra20-tec.dts:18.9-20.4
arch/arm/dts/tegra20-tec.dtb: Warning (unit_address_format): Failed prerequisite 'pci_bridge'
arch/arm/dts/tegra20-tec.dtb: Warning (pci_device_reg): Failed prerequisite 'pci_bridge'
arch/arm/dts/tegra20-tec.dtb: Warning (pci_device_bus_num): Failed prerequisite 'pci_bridge'
DTC arch/arm/dts/tegra20-trimslice.dtb
also defined at arch/arm/dts/tegra20-trimslice.dts:21.9-23.4
also defined at arch/arm/dts/tegra20-trimslice.dts:34.27-46.4
arch/arm/dts/tegra20-trimslice.dtb: Warning (unit_address_format): Failed prerequisite 'pci_bridge'
arch/arm/dts/tegra20-trimslice.dtb: Warning (pci_device_reg): Failed prerequisite 'pci_bridge'
arch/arm/dts/tegra20-trimslice.dtb: Warning (pci_device_bus_num): Failed prerequisite 'pci_bridge'
also defined at arch/arm/dts/tegra20-trimslice.dts:48.15-51.4
DTC arch/arm/dts/tegra20-ventana.dtb
also defined at arch/arm/dts/tegra20-ventana.dts:23.9-25.4
arch/arm/dts/tegra20-ventana.dts:37.15-49.8: Warning (unit_address_vs_reg): /host1x@50000000/dc@54200000/rgb/display-timings/timing@0: node has a unit name, but no reg or ranges property
arch/arm/dts/tegra20-ventana.dtb: Warning (unit_address_format): Failed prerequisite 'pci_bridge'
arch/arm/dts/tegra20-ventana.dtb: Warning (pci_device_reg): Failed prerequisite 'pci_bridge'
arch/arm/dts/tegra20-ventana.dtb: Warning (pci_device_bus_num): Failed prerequisite 'pci_bridge'
also defined at arch/arm/dts/tegra20-ventana.dts:549.15-551.4
also defined at arch/arm/dts/tegra20-ventana.dts:557.15-561.4
also defined at arch/arm/dts/tegra20-ventana.dts:569.15-571.4
DTC arch/arm/dts/tegra20-whistler.dtb
also defined at arch/arm/dts/tegra20-whistler.dts:20.9-23.4
arch/arm/dts/tegra20-whistler.dtb: Warning (unit_address_format): Failed prerequisite 'pci_bridge'
arch/arm/dts/tegra20-whistler.dtb: Warning (pci_device_reg): Failed prerequisite 'pci_bridge'
arch/arm/dts/tegra20-whistler.dtb: Warning (pci_device_bus_num): Failed prerequisite 'pci_bridge'
also defined at arch/arm/dts/tegra20-whistler.dts:48.15-50.4
DTC arch/arm/dts/tegra20-colibri.dtb
arch/arm/dts/tegra20-colibri.dtb: Warning (unit_address_format): Failed prerequisite 'pci_bridge'
arch/arm/dts/tegra20-colibri.dtb: Warning (pci_device_reg): Failed prerequisite 'pci_bridge'
arch/arm/dts/tegra20-colibri.dtb: Warning (pci_device_bus_num): Failed prerequisite 'pci_bridge'
also defined at arch/arm/dts/tegra20-colibri.dts:34.15-37.4
also defined at arch/arm/dts/tegra20-colibri.dts:39.15-44.4
also defined at arch/arm/dts/tegra20-colibri.dts:46.15-50.4
DTC arch/arm/dts/tegra30-apalis.dtb
also defined at arch/arm/dts/tegra30-apalis.dts:30.9-33.4
arch/arm/dts/tegra30.dtsi:93.19-97.4: Warning (unit_address_vs_reg): /clock: node has a reg or ranges property, but no unit name
arch/arm/dts/tegra30.dtsi:99.14-135.4: Warning (unit_address_vs_reg): /dma: node has a reg or ranges property, but no unit name
arch/arm/dts/tegra30.dtsi:19.27-91.4: Warning (pci_bridge): /pcie-controller@00003000: node name is not "pci" or "pcie"
also defined at arch/arm/dts/tegra30-apalis.dts:35.27-58.4
arch/arm/dts/tegra30-apalis.dtb: Warning (unit_address_format): Failed prerequisite 'pci_bridge'
arch/arm/dts/tegra30-apalis.dtb: Warning (pci_device_reg): Failed prerequisite 'pci_bridge'
arch/arm/dts/tegra30-apalis.dtb: Warning (pci_device_bus_num): Failed prerequisite 'pci_bridge'
arch/arm/dts/tegra30-apalis.dts:295.30-302.5: Warning (simple_bus_reg): /regulators/regulator@100: simple-bus unit address format error, expected "64"
arch/arm/dts/tegra30-apalis.dts:304.38-311.5: Warning (simple_bus_reg): /regulators/regulator@101: simple-bus unit address format error, expected "65"
arch/arm/dts/tegra30-apalis.dts:116.15-219.6: Warning (avoid_unnecessary_addr_size): /i2c@7000d000/tps65911@2d/regulators: unnecessary #address-cells/#size-cells without "ranges" or child "reg" property
arch/arm/dts/tegra30.dtsi:209.25-220.4: Warning (dmas_property): /serial@70006000: Missing property '#dma-cells' in node /dma or bad phandle (referred from dmas[0])
arch/arm/dts/tegra30.dtsi:222.25-233.4: Warning (dmas_property): /serial@70006040: Missing property '#dma-cells' in node /dma or bad phandle (referred from dmas[0])
arch/arm/dts/tegra30.dtsi:235.25-246.4: Warning (dmas_property): /serial@70006200: Missing property '#dma-cells' in node /dma or bad phandle (referred from dmas[0])
arch/arm/dts/tegra30.dtsi:248.25-259.4: Warning (dmas_property): /serial@70006300: Missing property '#dma-cells' in node /dma or bad phandle (referred from dmas[0])
arch/arm/dts/tegra30.dtsi:261.25-272.4: Warning (dmas_property): /serial@70006400: Missing property '#dma-cells' in node /dma or bad phandle (referred from dmas[0])
arch/arm/dts/tegra30.dtsi:209.25-220.4: Warning (resets_property): /serial@70006000: Missing property '#reset-cells' in node /clock or bad phandle (referred from resets[0])
arch/arm/dts/tegra30.dtsi:222.25-233.4: Warning (resets_property): /serial@70006040: Missing property '#reset-cells' in node /clock or bad phandle (referred from resets[0])
arch/arm/dts/tegra30.dtsi:235.25-246.4: Warning (resets_property): /serial@70006200: Missing property '#reset-cells' in node /clock or bad phandle (referred from resets[0])
arch/arm/dts/tegra30.dtsi:248.25-259.4: Warning (resets_property): /serial@70006300: Missing property '#reset-cells' in node /clock or bad phandle (referred from resets[0])
arch/arm/dts/tegra30.dtsi:261.25-272.4: Warning (resets_property): /serial@70006400: Missing property '#reset-cells' in node /clock or bad phandle (referred from resets[0])
arch/arm/dts/tegra30.dtsi:16.3-26: Warning (interrupts_property): /usb@7d000000:#interrupt-cells: size is (4), expected multiple of 12
arch/arm/dts/tegra30.dtsi:16.3-26: Warning (interrupts_property): /usb@7d004000:#interrupt-cells: size is (4), expected multiple of 12
arch/arm/dts/tegra30.dtsi:16.3-26: Warning (interrupts_property): /usb@7d008000:#interrupt-cells: size is (4), expected multiple of 12
DTC arch/arm/dts/tegra30-beaver.dtb
also defined at arch/arm/dts/tegra30-beaver.dts:26.9-29.4
also defined at arch/arm/dts/tegra30-beaver.dts:31.27-56.4
arch/arm/dts/tegra30-beaver.dtb: Warning (unit_address_format): Failed prerequisite 'pci_bridge'
arch/arm/dts/tegra30-beaver.dtb: Warning (pci_device_reg): Failed prerequisite 'pci_bridge'
arch/arm/dts/tegra30-beaver.dtb: Warning (pci_device_bus_num): Failed prerequisite 'pci_bridge'
arch/arm/dts/tegra30-beaver.dts:104.15-183.6: Warning (avoid_unnecessary_addr_size): /i2c@7000d000/tps65911@2d/regulators: unnecessary #address-cells/#size-cells without "ranges" or child "reg" property
DTC arch/arm/dts/tegra30-cardhu.dtb
also defined at arch/arm/dts/tegra30-cardhu.dts:25.9-28.4
also defined at arch/arm/dts/tegra30-cardhu.dts:30.27-53.4
arch/arm/dts/tegra30-cardhu.dtb: Warning (unit_address_format): Failed prerequisite 'pci_bridge'
arch/arm/dts/tegra30-cardhu.dtb: Warning (pci_device_reg): Failed prerequisite 'pci_bridge'
arch/arm/dts/tegra30-cardhu.dtb: Warning (pci_device_bus_num): Failed prerequisite 'pci_bridge'
arch/arm/dts/tegra30-cardhu.dts:321.34-330.5: Warning (simple_bus_reg): /regulators/regulator@10: simple-bus unit address format error, expected "a"
arch/arm/dts/tegra30-cardhu.dts:332.30-343.5: Warning (simple_bus_reg): /regulators/regulator@11: simple-bus unit address format error, expected "b"
arch/arm/dts/tegra30-cardhu.dts:345.29-355.5: Warning (simple_bus_reg): /regulators/regulator@12: simple-bus unit address format error, expected "c"
arch/arm/dts/tegra30-cardhu.dts:357.26-367.5: Warning (simple_bus_reg): /regulators/regulator@100: simple-bus unit address format error, expected "64"
arch/arm/dts/tegra30-cardhu.dts:369.30-379.5: Warning (simple_bus_reg): /regulators/regulator@101: simple-bus unit address format error, expected "65"
arch/arm/dts/tegra30-cardhu.dts:381.32-391.5: Warning (simple_bus_reg): /regulators/regulator@102: simple-bus unit address format error, expected "66"
arch/arm/dts/tegra30-cardhu.dts:393.32-403.5: Warning (simple_bus_reg): /regulators/regulator@103: simple-bus unit address format error, expected "67"
arch/arm/dts/tegra30-cardhu.dts:405.30-413.5: Warning (simple_bus_reg): /regulators/regulator@104: simple-bus unit address format error, expected "68"
arch/arm/dts/tegra30-cardhu.dts:415.29-425.5: Warning (simple_bus_reg): /regulators/regulator@105: simple-bus unit address format error, expected "69"
arch/arm/dts/tegra30-cardhu.dts:427.30-437.5: Warning (simple_bus_reg): /regulators/regulator@106: simple-bus unit address format error, expected "6a"
DTC arch/arm/dts/tegra30-colibri.dtb
also defined at arch/arm/dts/tegra30-colibri.dts:25.9-28.4
arch/arm/dts/tegra30-colibri.dtb: Warning (unit_address_format): Failed prerequisite 'pci_bridge'
arch/arm/dts/tegra30-colibri.dtb: Warning (pci_device_reg): Failed prerequisite 'pci_bridge'
arch/arm/dts/tegra30-colibri.dtb: Warning (pci_device_bus_num): Failed prerequisite 'pci_bridge'
DTC arch/arm/dts/tegra30-tec-ng.dtb
also defined at arch/arm/dts/tegra30-tamonten.dtsi:7.9-9.4
arch/arm/dts/tegra30-tec-ng.dtb: Warning (unit_address_format): Failed prerequisite 'pci_bridge'
arch/arm/dts/tegra30-tec-ng.dtb: Warning (pci_device_reg): Failed prerequisite 'pci_bridge'
arch/arm/dts/tegra30-tec-ng.dtb: Warning (pci_device_bus_num): Failed prerequisite 'pci_bridge'
DTC arch/arm/dts/tegra114-dalmore.dtb
also defined at arch/arm/dts/tegra114-dalmore.dts:25.9-28.4
arch/arm/dts/tegra114.dtsi:10.19-14.4: Warning (unit_address_vs_reg): /clock: node has a reg or ranges property, but no unit name
arch/arm/dts/tegra114.dtsi:16.14-51.4: Warning (unit_address_vs_reg): /dma: node has a reg or ranges property, but no unit name
arch/arm/dts/tegra114.dtsi:120.25-131.4: Warning (dmas_property): /serial@70006000: Missing property '#dma-cells' in node /dma or bad phandle (referred from dmas[0])
arch/arm/dts/tegra114.dtsi:133.25-144.4: Warning (dmas_property): /serial@70006040: Missing property '#dma-cells' in node /dma or bad phandle (referred from dmas[0])
arch/arm/dts/tegra114.dtsi:146.25-157.4: Warning (dmas_property): /serial@70006200: Missing property '#dma-cells' in node /dma or bad phandle (referred from dmas[0])
arch/arm/dts/tegra114.dtsi:159.25-170.4: Warning (dmas_property): /serial@70006300: Missing property '#dma-cells' in node /dma or bad phandle (referred from dmas[0])
arch/arm/dts/tegra114.dtsi:120.25-131.4: Warning (resets_property): /serial@70006000: Missing property '#reset-cells' in node /clock or bad phandle (referred from resets[0])
arch/arm/dts/tegra114.dtsi:133.25-144.4: Warning (resets_property): /serial@70006040: Missing property '#reset-cells' in node /clock or bad phandle (referred from resets[0])
arch/arm/dts/tegra114.dtsi:146.25-157.4: Warning (resets_property): /serial@70006200: Missing property '#reset-cells' in node /clock or bad phandle (referred from resets[0])
arch/arm/dts/tegra114.dtsi:159.25-170.4: Warning (resets_property): /serial@70006300: Missing property '#reset-cells' in node /clock or bad phandle (referred from resets[0])
arch/arm/dts/tegra114.dtsi:16.14-51.4: Warning (interrupts_property): /dma: Missing interrupt-parent
arch/arm/dts/tegra114.dtsi:53.22-68.4: Warning (interrupts_property): /gpio@6000d000: Missing interrupt-parent
arch/arm/dts/tegra114.dtsi:70.15-78.4: Warning (interrupts_property): /i2c@7000c000: Missing interrupt-parent
also defined at arch/arm/dts/tegra114-dalmore.dts:30.15-33.4
arch/arm/dts/tegra114.dtsi:80.15-88.4: Warning (interrupts_property): /i2c@7000c400: Missing interrupt-parent
also defined at arch/arm/dts/tegra114-dalmore.dts:35.15-38.4
arch/arm/dts/tegra114.dtsi:90.15-98.4: Warning (interrupts_property): /i2c@7000c500: Missing interrupt-parent
also defined at arch/arm/dts/tegra114-dalmore.dts:40.15-43.4
arch/arm/dts/tegra114.dtsi:100.15-108.4: Warning (interrupts_property): /i2c@7000c700: Missing interrupt-parent
also defined at arch/arm/dts/tegra114-dalmore.dts:45.15-48.4
arch/arm/dts/tegra114.dtsi:110.15-118.4: Warning (interrupts_property): /i2c@7000d000: Missing interrupt-parent
also defined at arch/arm/dts/tegra114-dalmore.dts:50.15-53.4
arch/arm/dts/tegra114.dtsi:120.25-131.4: Warning (interrupts_property): /serial@70006000: Missing interrupt-parent
arch/arm/dts/tegra114.dtsi:133.25-144.4: Warning (interrupts_property): /serial@70006040: Missing interrupt-parent
arch/arm/dts/tegra114.dtsi:146.25-157.4: Warning (interrupts_property): /serial@70006200: Missing interrupt-parent
arch/arm/dts/tegra114.dtsi:159.25-170.4: Warning (interrupts_property): /serial@70006300: Missing interrupt-parent
arch/arm/dts/tegra114.dtsi:172.15-182.4: Warning (interrupts_property): /spi@7000d400: Missing interrupt-parent
arch/arm/dts/tegra114.dtsi:184.15-194.4: Warning (interrupts_property): /spi@7000d600: Missing interrupt-parent
arch/arm/dts/tegra114.dtsi:196.15-206.4: Warning (interrupts_property): /spi@7000d800: Missing interrupt-parent
arch/arm/dts/tegra114.dtsi:208.15-218.4: Warning (interrupts_property): /spi@7000da00: Missing interrupt-parent
also defined at arch/arm/dts/tegra114-dalmore.dts:55.15-58.4
arch/arm/dts/tegra114.dtsi:220.15-230.4: Warning (interrupts_property): /spi@7000dc00: Missing interrupt-parent
arch/arm/dts/tegra114.dtsi:232.15-242.4: Warning (interrupts_property): /spi@7000de00: Missing interrupt-parent
arch/arm/dts/tegra114.dtsi:244.17-250.4: Warning (interrupts_property): /sdhci@78000000: Missing interrupt-parent
arch/arm/dts/tegra114.dtsi:252.17-258.4: Warning (interrupts_property): /sdhci@78000200: Missing interrupt-parent
arch/arm/dts/tegra114.dtsi:260.17-266.4: Warning (interrupts_property): /sdhci@78000400: Missing interrupt-parent
also defined at arch/arm/dts/tegra114-dalmore.dts:60.17-64.4
arch/arm/dts/tegra114.dtsi:268.17-274.4: Warning (interrupts_property): /sdhci@78000600: Missing interrupt-parent
also defined at arch/arm/dts/tegra114-dalmore.dts:66.17-69.4
arch/arm/dts/tegra114.dtsi:276.15-283.4: Warning (interrupts_property): /usb@7d000000: Missing interrupt-parent
also defined at arch/arm/dts/tegra114-dalmore.dts:71.15-75.4
arch/arm/dts/tegra114.dtsi:285.15-292.4: Warning (interrupts_property): /usb@7d004000: Missing interrupt-parent
arch/arm/dts/tegra114.dtsi:294.15-301.4: Warning (interrupts_property): /usb@7d008000: Missing interrupt-parent
also defined at arch/arm/dts/tegra114-dalmore.dts:77.15-80.4
DTC arch/arm/dts/tegra124-jetson-tk1.dtb
also defined at arch/arm/dts/tegra124-jetson-tk1.dts:27.9-30.4
arch/arm/dts/tegra124.dtsi:197.37-202.4: Warning (unit_address_vs_reg): /interrupt-controller@60004000: node has a unit name, but no reg or ranges property
arch/arm/dts/tegra124.dtsi:17.27-81.4: Warning (pci_bridge): /pcie-controller@01003000: node name is not "pci" or "pcie"
also defined at arch/arm/dts/tegra124-jetson-tk1.dts:32.27-50.4
arch/arm/dts/tegra124-jetson-tk1.dtb: Warning (unit_address_format): Failed prerequisite 'pci_bridge'
arch/arm/dts/tegra124-jetson-tk1.dtb: Warning (pci_device_reg): Failed prerequisite 'pci_bridge'
arch/arm/dts/tegra124-jetson-tk1.dtb: Warning (pci_device_bus_num): Failed prerequisite 'pci_bridge'
arch/arm/dts/tegra124-jetson-tk1.dts:424.29-435.5: Warning (simple_bus_reg): /regulators/regulator@10: simple-bus unit address format error, expected "a"
arch/arm/dts/tegra124-jetson-tk1.dts:437.30-445.5: Warning (simple_bus_reg): /regulators/regulator@11: simple-bus unit address format error, expected "b"
arch/arm/dts/tegra124-jetson-tk1.dts:447.30-456.5: Warning (simple_bus_reg): /regulators/regulator@12: simple-bus unit address format error, expected "c"
arch/arm/dts/tegra124-jetson-tk1.dts:459.30-468.5: Warning (simple_bus_reg): /regulators/regulator@13: simple-bus unit address format error, expected "d"
arch/arm/dts/tegra124-jetson-tk1.dts:470.31-479.5: Warning (simple_bus_reg): /regulators/regulator@14: simple-bus unit address format error, expected "e"
arch/arm/dts/tegra124.dtsi:822.15-832.4: Warning (unique_unit_address): /usb@7d000000: duplicate unit-address (also used in node /usb-phy@7d000000)
also defined at arch/arm/dts/tegra124-jetson-tk1.dts:317.15-321.4
arch/arm/dts/tegra124.dtsi:859.15-869.4: Warning (unique_unit_address): /usb@7d004000: duplicate unit-address (also used in node /usb-phy@7d004000)
arch/arm/dts/tegra124.dtsi:895.15-905.4: Warning (unique_unit_address): /usb@7d008000: duplicate unit-address (also used in node /usb-phy@7d008000)
also defined at arch/arm/dts/tegra124-jetson-tk1.dts:323.15-326.4
DTC arch/arm/dts/tegra124-nyan-big.dtb
also defined at arch/arm/dts/tegra124-nyan.dtsi:11.9-13.4
arch/arm/dts/tegra124-nyan-big.dts:34.14-44.7: Warning (unit_address_vs_reg): /host1x@50000000/dc@54200000/display-timings/timing@0: node has a unit name, but no reg or ranges property
arch/arm/dts/tegra124-nyan-big.dts:61.19-63.4: Warning (unit_address_vs_reg): /sdhci@0,700b0400: node has a unit name, but no reg or ranges property
arch/arm/dts/tegra124-nyan-big.dts:72.20-1380.4: Warning (unit_address_vs_reg): /pinmux@0,70000868: node has a unit name, but no reg or ranges property
arch/arm/dts/tegra124-nyan-big.dtb: Warning (unit_address_format): Failed prerequisite 'pci_bridge'
arch/arm/dts/tegra124-nyan-big.dtb: Warning (pci_device_reg): Failed prerequisite 'pci_bridge'
arch/arm/dts/tegra124-nyan-big.dtb: Warning (pci_device_bus_num): Failed prerequisite 'pci_bridge'
arch/arm/dts/tegra124-nyan.dtsi:649.29-663.5: Warning (simple_bus_reg): /regulators/regulator@10: simple-bus unit address format error, expected "a"
arch/arm/dts/tegra124-nyan.dtsi:665.30-673.5: Warning (simple_bus_reg): /regulators/regulator@11: simple-bus unit address format error, expected "b"
arch/arm/dts/tegra124-nyan.dtsi:675.30-684.5: Warning (simple_bus_reg): /regulators/regulator@12: simple-bus unit address format error, expected "c"
also defined at arch/arm/dts/tegra124-nyan.dtsi:415.15-418.4
also defined at arch/arm/dts/tegra124-nyan.dtsi:425.15-427.4
also defined at arch/arm/dts/tegra124-nyan.dtsi:434.15-437.4
arch/arm/dts/tegra124-nyan-big.dts:18.3-36: Warning (alias_paths): /aliases:rtc0: aliases property is not a valid node (/i2c@0,7000d000/pmic@40)
arch/arm/dts/tegra124-nyan-big.dts:19.3-28: Warning (alias_paths): /aliases:rtc1: aliases property is not a valid node (/rtc@0,7000e000)
DTC arch/arm/dts/tegra124-venice2.dtb
also defined at arch/arm/dts/tegra124-venice2.dts:28.9-31.4
arch/arm/dts/tegra124-venice2.dtb: Warning (unit_address_format): Failed prerequisite 'pci_bridge'
arch/arm/dts/tegra124-venice2.dtb: Warning (pci_device_reg): Failed prerequisite 'pci_bridge'
arch/arm/dts/tegra124-venice2.dtb: Warning (pci_device_bus_num): Failed prerequisite 'pci_bridge'
also defined at arch/arm/dts/tegra124-venice2.dts:86.15-90.4
also defined at arch/arm/dts/tegra124-venice2.dts:92.15-95.4
DTC arch/arm/dts/tegra186-p2771-0000-000.dtb
also defined at arch/arm/dts/tegra186-p2771-0000.dtsi:24.9-26.4
arch/arm/dts/tegra186.dtsi:220.27-295.4: Warning (pci_bridge): /pcie-controller@10003000: node name is not "pci" or "pcie"
also defined at arch/arm/dts/tegra186-p2771-0000-000.dts:14.27-31.4
arch/arm/dts/tegra186-p2771-0000-000.dtb: Warning (unit_address_format): Failed prerequisite 'pci_bridge'
arch/arm/dts/tegra186-p2771-0000-000.dtb: Warning (pci_device_reg): Failed prerequisite 'pci_bridge'
arch/arm/dts/tegra186-p2771-0000-000.dtb: Warning (pci_device_bus_num): Failed prerequisite 'pci_bridge'
DTC arch/arm/dts/tegra186-p2771-0000-500.dtb
also defined at arch/arm/dts/tegra186-p2771-0000-500.dts:14.27-31.4
arch/arm/dts/tegra186-p2771-0000-500.dtb: Warning (unit_address_format): Failed prerequisite 'pci_bridge'
arch/arm/dts/tegra186-p2771-0000-500.dtb: Warning (pci_device_reg): Failed prerequisite 'pci_bridge'
arch/arm/dts/tegra186-p2771-0000-500.dtb: Warning (pci_device_bus_num): Failed prerequisite 'pci_bridge'
DTC arch/arm/dts/tegra210-e2220-1170.dtb
also defined at arch/arm/dts/tegra210-e2220-1170.dts:20.9-22.4
arch/arm/dts/tegra210.dtsi:15.29-79.4: Warning (pci_bridge): /pcie-controller@0,01003000: node name is not "pci" or "pcie"
arch/arm/dts/tegra210-e2220-1170.dtb: Warning (unit_address_format): Failed prerequisite 'pci_bridge'
arch/arm/dts/tegra210-e2220-1170.dtb: Warning (pci_device_reg): Failed prerequisite 'pci_bridge'
arch/arm/dts/tegra210-e2220-1170.dtb: Warning (pci_device_bus_num): Failed prerequisite 'pci_bridge'
arch/arm/dts/tegra210.dtsi:83.3-26: Warning (interrupts_property): /usb@0,7d004000:#interrupt-cells: size is (4), expected multiple of 12
DTC arch/arm/dts/tegra210-p2371-0000.dtb
also defined at arch/arm/dts/tegra210-p2371-0000.dts:20.9-22.4
arch/arm/dts/tegra210-p2371-0000.dtb: Warning (unit_address_format): Failed prerequisite 'pci_bridge'
arch/arm/dts/tegra210-p2371-0000.dtb: Warning (pci_device_reg): Failed prerequisite 'pci_bridge'
arch/arm/dts/tegra210-p2371-0000.dtb: Warning (pci_device_bus_num): Failed prerequisite 'pci_bridge'
DTC arch/arm/dts/tegra210-p2371-2180.dtb
also defined at arch/arm/dts/tegra210-p2371-2180.dts:23.9-25.4
also defined at arch/arm/dts/tegra210-p2371-2180.dts:27.29-37.4
arch/arm/dts/tegra210-p2371-2180.dtb: Warning (unit_address_format): Failed prerequisite 'pci_bridge'
arch/arm/dts/tegra210-p2371-2180.dtb: Warning (pci_device_reg): Failed prerequisite 'pci_bridge'
arch/arm/dts/tegra210-p2371-2180.dtb: Warning (pci_device_bus_num): Failed prerequisite 'pci_bridge'
DTC arch/arm/dts/tegra210-p2571.dtb
also defined at arch/arm/dts/tegra210-p2571.dts:28.9-30.4
arch/arm/dts/tegra210-p2571.dtb: Warning (unit_address_format): Failed prerequisite 'pci_bridge'
arch/arm/dts/tegra210-p2571.dtb: Warning (pci_device_reg): Failed prerequisite 'pci_bridge'
arch/arm/dts/tegra210-p2571.dtb: Warning (pci_device_bus_num): Failed prerequisite 'pci_bridge'
DTC arch/arm/dts/tegra210-p3450-porg.dtb
also defined at arch/arm/dts/tegra210-p3450-porg.dts:24.9-26.4
also defined at arch/arm/dts/tegra210-p3450-porg.dts:28.29-38.4
arch/arm/dts/tegra210-p3450-porg.dtb: Warning (unit_address_format): Failed prerequisite 'pci_bridge'
arch/arm/dts/tegra210-p3450-porg.dtb: Warning (pci_device_reg): Failed prerequisite 'pci_bridge'
arch/arm/dts/tegra210-p3450-porg.dtb: Warning (pci_device_bus_num): Failed prerequisite 'pci_bridge'
SHIPPED dts/dt.dtb
