Have a 2070 S connected to two Acer CB271HU 2560x1440 monitors via HDMI (one via HDMI port, another one via DP->HDMI adapter). When using a single monitor at native resolution, everything works fine with both outputs. When either monitor is running @ 1920x1080 and the other @ native, everything is fine. When both a running native resolution, the one connected via DP->HDMI adapter drops into weird 2560x2992@30fps mode and shows split screen, bottom being a mirror of the top.
This exact setup works perfectly in windows.
Bug report is attached. Couldn’t find any smoking guns but admittedly don’t know where to look.
nvidia-bug-report.log.gz_ (551.4 KB)
