It happens again and I have no clue this time if it is due to broken driver. Please advise. Thanks.
nvidia-bug-report.log.gz (95.7 KB)
I spent three days following all kinds of suggestions on internet. None of them worked. The error was nvidia.ko module not being found and being loaded. Just at an additional info my cable is USB-C to DP port on the monitor (not regular HDMI). This is the only way i figured out that fixes the problem -it rolls back to the official Ubuntu 2204 supported kernel:
1.1. Fix second display on Ubuntu (nvidia)
List installed kernels: latest Ubuntu2204 kernel is 5.15….
$ dpkg --list | grep linux-image
rc linux-image-5.13.0-41-generic 5.13.0-41.46~20.04.1 amd64 Signed kernel image generic
ii linux-image-5.15.0-30-generic 5.15.0-30.31 amd64 Signed kernel image generic
ii linux-image-5.15.0-33-generic 5.15.0-33.34 amd64 Signed kernel image generic
ii linux-image-generic 5.15.0.33.36 amd64 Generic Linux kernel image
ii linux-image-generic-hwe-22.04 5.15.0.33.36 amd64 Generic Linux kernel image
ii linux-image-unsigned-5.16.12-051612-generic 5.16.12-051612.202203021142 amd64 Linux kernel image for version 5.16.12 on 64 bit x86 SMP
The recommended Ubuntu kernel was 5.15.0-33, so remove the extra new one,
which will upgrade boot options …
$ sudo apt remove linux-image-5.16.12-051612.202203021142 linux-headers-5.16.12-051612.202203021142
OR just if headers are not installed
$ sudo apt remove linux-image-unsigned-5.16.12-051612-generic
then:
$ sudo update-grub
$ sudo apt install linux-headers-5.15.0.33-generic
$ reboot
$ for x in linux-headers-5.15.0-33 linux-image-5.15.0-33-generic; do sudo apt reinstall $x; done
The above will place the nvidia.ko where it belongs ……
$ sudo update-grub
$ sudo reboot
Hello! I have the same problem. New Notebook, Kubuntu 22.04. TV on HDMI. TV is not detected! No Signal. The TV shows an image during the booting process for a short moment. When the Kubuntu logo appears the display goes to black and shows no-signal-massage. (with Windows all works fine). I have try all suggested solutions without success. :(
I hope, anybody can help!
PS: I have the nvidia-bug-report.log.gz file, but the upload seems to bee broken at the moment?
I spent hours pulling my hair out, even changing distros. Mint can finally recognize my external monitor. Thank you so much!
It seems like I am having the same issue too on Ubuntu 20.04. Attaching my nvidia bug report for reference
nvidia-bug-report.log.txt (523.5 KB)
Hello @Z.FZ and welcome to the NVIDIA developer forums!
I had a look at your log file and your problem is different. Your driver is incorrectly installed.
This looks like an aborted installation or some leftover driver files from a Distro upgrade.
First indicator is
*** /var/log/nvidia-installer.log does not exist
should be there unless you automatically purge log files.
Another issue here:
Scanning kernel log files for NVIDIA kernel messages:
/var/log/kern.log:
/var/log/dmesg:
journalctl -b -0:
Jan 12 14:51:45 FZ-Dell nvidia-settings-autostart.desktop[2113]: ERROR: NVIDIA driver is not loaded
Jan 12 14:51:45 FZ-Dell nvidia-settings-autostart.desktop[2113]: ERROR: Unable to load info from any available system
Lastly you also find that nouveau is installed as kernel module
Kernel modules: nvidiafb, nouveau
which should not be the case. See my earlier post.
My recommendation is to completely remove (purge) all NVIDIA drivers and do a fresh install, using the Ubuntu Software Manager and using the certified driver coming with the Distro. And follow the instructions exactly.
If that still causes issues, please be so kind and open a new topic here.
Hi, I have the same problem. Ubuntu cannot detect second monitor as a device. Please advise.
Many thanks.
Notebook: Dell Precision 7540
System: Ubuntu 18.04
GPU: Nvidia quadro T2000
nvidia-bug-report.log.gz (127.4 KB)
Hi, I have a similar issue, I am running Ubuntu 22.04 and I can’t get my monitor to connect to my ASUS ROG laptop either. I am pretty certain I have installed the NVIDIA drivers (for my RTX 3050 card) correctly. Read through all of the answers above and tried em all, still didn’t fix my issue.
nvidia-bug-report.log.gz.compressed (364.0 KB)
I have the same Issue 2nd monitor not detected (no HW issue, monitor and HDMI cable works great with other computers)
my system is a Dell precision 7920
NVIDIA Corporation GP104GL [Quadro P4000]
intel® Xeon(R) Silver 4114 CPU @ 2.20GHz × 40
DDR4 62.5 GiB
nvidia-bug-report.log.gz (535.5 KB)
| NVIDIA-SMI 550.54.14 Driver Version: 550.54.14 CUDA Version: 12.4 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 Quadro P4000 Off | 00000000:73:00.0 On | N/A |
| 50% 48C P8 9W / 105W | 962MiB / 8192MiB | 7% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 2680 G /usr/lib/xorg/Xorg 57MiB |
| 0 N/A N/A 4442 G /usr/lib/xorg/Xorg 243MiB |
| 0 N/A N/A 4584 G /usr/bin/gnome-shell 167MiB |
| 0 N/A N/A 5259 G …/jvm/java-11-openjdk-amd64/bin/java 18MiB |
| 0 N/A N/A 7149 G …evpnclient/microsoft-azurevpnclient 35MiB |
| 0 N/A N/A 7351 G /usr/lib/firefox/firefox 425MiB |
| 0 N/A N/A 10337 G gnome-control-center 2MiB |
I’ve tried solutions listed here and I still cant get the second monitor to work, help is appreciated.
I have the same issue after a kernel update on Oracle Linux 9.4
running lscpi I can see some differences on th 2 versions:
OLD kernel (the one where 2nd monitor works fine): 5.15.0-210.163.7.el9uek.x86_64
[XXX.YYY@N2852 ~]$ lspci -vnn | grep VGA -A 12
00:02.0 VGA compatible controller [0300]: Intel Corporation TigerLake-H GT1 [UHD Graphics] [8086:9a60] (rev 01) (prog-if 00 [VGA controller])
DeviceName: Onboard IGD
Subsystem: Hewlett-Packard Company Device [103c:8870]
Flags: bus master, fast devsel, latency 0, IRQ 151, IOMMU group 2
Memory at 6052000000 (64-bit, non-prefetchable) [size=16M]
Memory at 4000000000 (64-bit, prefetchable) [size=256M]
I/O ports at 4000 [size=64]
Expansion ROM at 000c0000 [virtual] [disabled] [size=128K]
Capabilities: <access denied>
Kernel driver in use: i915
Kernel modules: i915
00:04.0 Signal processing controller [1180]: Intel Corporation TigerLake-LP Dynamic Tuning Processor Participant [8086:9a03] (rev 05)
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation TU117GLM [T1200 Laptop GPU] [10de:1fbc] (rev a1) (prog-if 00 [VGA controller])
Flags: bus master, fast devsel, latency 0, IRQ 150, IOMMU group 17
Memory at 6d000000 (32-bit, non-prefetchable) [size=16M]
Memory at 6040000000 (64-bit, prefetchable) [size=256M]
Memory at 6050000000 (64-bit, prefetchable) [size=32M]
I/O ports at 3000 [size=128]
Expansion ROM at 6e080000 [disabled] [size=512K]
Kernel driver in use: nouveau
01:00.1 Audio device [0403]: NVIDIA Corporation Device [10de:10fa] (rev a1)
00:00.0 Host bridge: Intel Corporation 11th Gen Core Processor Host Bridge/DRAM Registers (rev 05)
00:01.0 PCI bridge: Intel Corporation 11th Gen Core Processor PCIe Controller #1 (rev 05)
00:02.0 VGA compatible controller: Intel Corporation TigerLake-H GT1 [UHD Graphics] (rev 01)
00:04.0 Signal processing controller: Intel Corporation TigerLake-LP Dynamic Tuning Processor Participant (rev 05)
00:07.0 PCI bridge: Intel Corporation Tiger Lake-H Thunderbolt 4 PCI Express Root Port #0 (rev 05)
00:07.1 PCI bridge: Intel Corporation Tiger Lake-H Thunderbolt 4 PCI Express Root Port #1 (rev 05)
00:08.0 System peripheral: Intel Corporation GNA Scoring Accelerator module (rev 05)
00:0a.0 Signal processing controller: Intel Corporation Tigerlake Telemetry Aggregator Driver (rev 01)
00:0d.0 USB controller: Intel Corporation Tiger Lake-H Thunderbolt 4 USB Controller (rev 05)
00:0d.2 USB controller: Intel Corporation Tiger Lake-H Thunderbolt 4 NHI #0 (rev 05)
00:12.0 Serial controller: Intel Corporation Tiger Lake-H Integrated Sensor Hub (rev 11)
00:14.0 USB controller: Intel Corporation Tiger Lake-H USB 3.2 Gen 2x1 xHCI Host Controller (rev 11)
00:14.2 RAM memory: Intel Corporation Tiger Lake-H Shared SRAM (rev 11)
00:14.3 Network controller: Intel Corporation Tiger Lake PCH CNVi WiFi (rev 11)
00:15.0 Serial bus controller: Intel Corporation Tiger Lake-H Serial IO I2C Controller #0 (rev 11)
00:16.0 Communication controller: Intel Corporation Tiger Lake-H Management Engine Interface (rev 11)
00:1b.0 PCI bridge: Intel Corporation Tiger Lake-H PCIe Root Port #17 (rev 11)
00:1c.0 PCI bridge: Intel Corporation Tiger Lake-H PCIe Root Port #3 (rev 11)
00:1f.0 ISA bridge: Intel Corporation WM590 LPC/eSPI Controller (rev 11)
00:1f.3 Multimedia audio controller: Intel Corporation Tiger Lake-H HD Audio Controller (rev 11)
00:1f.4 SMBus: Intel Corporation Tiger Lake-H SMBus Controller (rev 11)
00:1f.5 Serial bus controller: Intel Corporation Tiger Lake-H SPI Controller (rev 11)
00:1f.6 Ethernet controller: Intel Corporation Ethernet Connection (14) I219-V (rev 11)
01:00.0 VGA compatible controller: NVIDIA Corporation TU117GLM [T1200 Laptop GPU] (rev a1)
01:00.1 Audio device: NVIDIA Corporation Device 10fa (rev a1)
56:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller SM981/PM981/PM983
57:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTS5261 PCI Express Card Reader (rev 01)
[XXX.YYY@N2852 ~]$
NEW kernel (5.15.0-301… )
Flags: bus master, fast devsel, latency 0, IRQ 150, IOMMU group 2
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation TU117GLM [T1200 Laptop GPU] [10de:1fbc] (rev ff) (prog-if ff)
!!! Unknown header type 7f
01:00.1 Audio device [0403]: NVIDIA Corporation Device [10de:10fa] (rev ff) (prog-if ff)
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
56:00.0 Non-Volatile memory controller [0108]: Samsung Electronics Co Ltd NVMe SSD Controller SM981/PM981/PM983 [144d:a808] (prog-if 02 [NVM Express])
Subsystem: Samsung Electronics Co Ltd SSD 970 EVO/PRO [144d:a801]
Flags: bus master, fast devsel, latency 0, IRQ 16, IOMMU group 18
Memory at 6eb00000 (64-bit, non-prefetchable) [size=16K]
01:00.0 VGA compatible controller: NVIDIA Corporation TU117GLM [T1200 Laptop GPU] (rev ff)
01:00.1 Audio device: NVIDIA Corporation Device 10fa (rev ff)
@MarkusHoHo :
I don’t have any /var/log/nvidia-installer.log and probably it happen because the logs file in this directory are purged automatically (oldest log file in the dire is of 30 days ago). There is a different way for check what is happened during kernel update?
How proceed exactly? Remove nvidia drivers and do a fresh installation is clear and I agree with the approach but it’s a little bit generic
It works for me for the first time and then the screen does not output any image from itself, I redone these steps but not worked again.
My Laptop is LenovoUbuntu 24.04 freezes with NVIDIA profile (GTX 1650, Lenovo IdeaPad L340) — works only on Intel, HDMI not detected
Hi there @eng.islammesha and welcome to the NVIDIA developer forums.
Please open a new topic in this forum category and follow the instructions in this post: »»»»»»»»»» If you have a problem, PLEASE read this first ««««««««««
Thanks for your response.
This is the output when I run sudo nvidia-bug-report.sh command.
And this is the new topic. Ubuntu 24.04 with NVIDIA profile (GTX 1650, Lenovo IdeaPad L340) — HDMI not detected
