UEFI Build Error
Hello, NVIDIA engineer:
I have a problem getting the EDK2-UEFI package:
$ edkrepo clone nvidia-uefi NVIDIA-Jetson r35.2.1
Syncing the global manifest repository: /home/dhy/.edkrepo/edk2-edkrepo-manifest-main
The git command: git pull -v origin failed to complete successfully with the following errors.
stderr: ‘fatal: unable to access ‘GitHub - tianocore/edk2-edkrepo-manifest: Platforms manifests used by the edkrepo utility’: gnutls_handshake() failed: The TLS connection was non-properly terminated.’
Syncing the global manifest repository: /home/dhy/.edkrepo/nvidia
Verifying the global manifest repository entry for project: NVIDIA-Jetson
Cloning from: GitHub - NVIDIA/edk2: NVIDIA fork of tianocore/edk2
The git command: git clone --no-checkout --progress -v GitHub - NVIDIA/edk2: NVIDIA fork of tianocore/edk2 /home/dhy/edkrepo/nvidia-uefi/edk2 failed to complete successfully with the following errors.
This bag has been pulled for a long time but has not been pulled down. Sometimes it will fail if it is pulled halfway.
Is there any other way to get the Edk2-UEFI package.
Look forward to your reply.
Sorry for the late response, is this still an issue to support? Thanks
Hi hanyu.du,
Could you help to use main instead of r35.2.1 as the following command to clone?
$ edkrepo clone nvidia-uefi NVIDIA-Jetson main
You could also download in the following link (Code → Local → Download ZIP)
GitHub - NVIDIA/edk2-nvidia: NVIDIA EDK2 platform support
