rkk2
November 27, 2023, 10:22am
1
I have referred the following link to build UEFI using docker.
I am facing the following error while running “edk2_docker echo hello”.
nvidia:~$ export EDK2_DEV_IMAGE=“Package containers/ubuntu-20-dev · GitHub ”
nvidia:~$ export EDK2_USER_ARGS=“-v "${HOME}":"${HOME}" -e EDK2_DOCKER_USER_HOME="${HOME}"”
nvidia:~$ export EDK2_BUILD_ROOT=“/build”
nvidia:~$ export EDK2_BUILDROOT_ARGS=“-v "${EDK2_BUILD_ROOT}":"${EDK2_BUILD_ROOT}"”
nvidia:~$ alias edk2_docker=“docker run -it --rm -w "$(pwd)" ${EDK2_BUILDROOT_ARGS} ${EDK2_USER_ARGS} "${EDK2_DEV_IMAGE}"”
nvidia:~$ edk2_docker echo hello
Unable to find image ‘Package containers/ubuntu-20-dev · GitHub ’ locally
latest: Pulling from tianocore/containers/ubuntu-20-dev
99803d4b97f3: Retrying in 5 seconds
5a9dc81a6652: Retrying in 1 second
54debb09bff5: Retrying in 1 second
1ed55f661ae8: Waiting
4585169d800e: Waiting
f842c2638481: Waiting
a218e4ff6133: Waiting
cecc21f2085d: Waiting
52d2c40697e3: Waiting
91c387080e91: Waiting
docker: error pulling image configuration: download failed after attempts=6: read: connection reset by peer.
See ‘docker run --help’.
nvidia:~$
When I try to access “ghcr.io/tianocore/containers ” url, I could see 404 error. Ant different url I have to use for the docker image?
Hi rkk2,
What’s your host using for docker?
Have you confirmed the network access working as expected?
rkk2
November 29, 2023, 10:31am
4
In the office network few urls are blocked, so I have faced the issue. After connecting to open network, I could see the docker run is working fine.
rkk2
November 29, 2023, 10:48am
5
While creating work space, it failed. But it didn’t show any errors. The message shows that “failed to complete successfully with the following errors.”, but errors are not listed.
user:~$ edk2_docker edkrepo clone nvidia-uefi NVIDIA-Platforms r35.4.1
Cloning global manifest repository to: /home/user/.edkrepo/edk2-edkrepo-manifest-main from: GitHub - tianocore/edk2-edkrepo-manifest: Platforms manifests used by the edkrepo utility
The git command: git clone --branch=main --progress -v GitHub - tianocore/edk2-edkrepo-manifest: Platforms manifests used by the edkrepo utility /home/user/.edkrepo/edk2-edkrepo-manifest-main failed to complete successfully with the following errors.
user:~$
Have you confirmed if git installed correctly?
rkk2
November 30, 2023, 6:47am
7
It was proxy issue in the git config. I have unset using “git config --global --unset http.proxy”.
rkk2
November 30, 2023, 6:59am
8
After build it created multiple artifacts. Can you help which images I have to take for my Nvidia Jetson AGX Orin development module.
PROGRESS - Running Post Build
INFO - Generating uefi image /build/nvidia-uefi/images/uefi_Jetson_RELEASE.bin
INFO - Copying boot app /build/nvidia-uefi/images/BOOTAA64_Jetson_RELEASE.efi
INFO - Copying DTB images/DgpuDtEfifbSupport_Jetson_RELEASE.dtbo
INFO - Copying DTB images/BootOrderUsb_Jetson_RELEASE.dtbo
INFO - Copying DTB images/BootOrderHttp_Jetson_RELEASE.dtbo
INFO - Copying DTB images/BootOrderUfs_Jetson_RELEASE.dtbo
INFO - Copying DTB images/L4TConfiguration_Jetson_RELEASE.dtbo
INFO - Copying DTB images/AcpiBoot_Jetson_RELEASE.dtbo
INFO - Copying DTB images/BootOrderPxe_Jetson_RELEASE.dtbo
INFO - Copying DTB images/BootOrderEmmc_Jetson_RELEASE.dtbo
INFO - Copying DTB images/BootOrderNvme_Jetson_RELEASE.dtbo
INFO - Copying DTB images/BootOrderSata_Jetson_RELEASE.dtbo
DEBUG - Plugin Success: Linux GCC5 Tool Chain Support
INFO - Writing BuildToolsReports to /build/nvidia-uefi/Build/Jetson/RELEASE_GCC5/BUILD_TOOLS_REPORT
DEBUG - Plugin Success: Build Tools Report Generator
Please replace <Linux_for_Tegra>/bootloader/uefi_jetson.bin with uefi_Jetson_RELEASE.bin you just built.
system
Closed
January 2, 2024, 4:20am
11
