UEFI modification takes no effect
Hi ,i’m using jetson orin nx on a project. i need to change the uefi bootlog for our project. i have suceeded change the bootlogo by add new bmp file. But there still remains some annoying charactor print on the display. like below:
Jetson UEFI firmware (version 5.0-35550185 built on 2024-02-20T04:21:22+00:00)
ESC to enter Setup.
F11 to enter Boot Manager Menu.
Enter to continue boot.
** WARNING: Test Key is used. **
L4TLauncher: Attempting Direct Boot
EFI stub: Booting Linux Kernel…
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services and installing virtual address map…
By modify the uefi source code i suceed delete those charactors:
ESC to enter Setup.
But those below still remain :
i modify the L4TLauncher.c by change those codes:
    // ErrorPrint (L"%a: Attempting Direct Boot\r\n", __FUNCTION__);
     ErrorPrint (L"%a: test Attempting Direct Boot\r\n", __FUNCTION__);
it takes no effect.
how do i make this work?
FYI: I change the uefi by the uefi_jetson.bin and the BOOTAA64.efi and reflash the jetson module by the cmd below:
sudo ./tools/kernel_flash/l4t_initrd_flash.sh   -c tools/kernel_flash/flash_l4t_t234_nvme.xml -p "-c bootloader/generic/cfg/flash_t234_qspi.xml"   --showlogs --network usb0 jetson-orin-nano-devkit internal
Hi k.fudong,
Please refer to the following thread to remove the messages showing in UEFI.
How can I remove text printing from the UEFI Logo interface?
You can run the following command to update booloader.
$ sudo ./flash.sh -c bootloader/t186ref/cfg/flash_t234_qspi.xml jetson-orin-nano-devkit nvme0n1p1
i sucessed in removing those lines
but “L4TLauncher: Attempting Direct Boot” still remain
but it takes no effect.
i use Jetson™ Linux version 36.3. cmd seems not working
what do i miss?
For L4TLauncher.c , you might need to update esp partition to apply the change.
You can refer to the following thread to update esp partition.
Arm Trusted Firmware Fork - #9 by KevinFFF
thanks a lot my problem has been solved!
