These changes have marginally changed the timeout, as the screen is only present for around 1 second now. Any idea what could still be holding the screen up?
Do you mean there is still a one-second timeout even after configuring it to 0s?
Please review the serial console log with timestamps enabled to identify what is causing this delay.
Hi @KevinFFF , any other ways that may need to be configured to remove the Timeout? I also saw in another forum that It can be configured fromthe boot manager setup, please confirm if this is the case for JP6.
Hi @KevinFFF , I have checked in the manager, and the autoboot timeout is 0, so could there be a module holding this process up? What we really dont like is that the screen flashesd from the uefi to the boot screen. We’d prefer it to either all be black, or have the same logo constantly.
Thanks @KevinFFF , but closing or hiding the UEFI menu does not solve my problem. I don’t want that screen to show up at all, I am not concerned about their being a menu enabled, as long as the uefi timeout screen never shows up.
Okay, UEFI menu is for the prompt and the function to enter into the UEFI menu.
You can try replacing the boot logo file with the black image to keep it dark in UEFI boot. UEFI Adaptation — Customized Logo
Please point out the line with the unexpected delay in your case.
Hi @KevinFFF , I’ll change it to a black image, and then try disable all the text printing.
This is where it is being held:
[2026-07-01 08:15:18] ��MmInstallProtocolInterface: 7CE88FB3-4BD7-4679-87A8-A8D0
[2026-07-01 08:15:18] ��L4TLauncher: Attempting Direct Boot
They are within the same second 18. I don’t think there’s any unexpected delay between these 2 lines.
[2026-07-01 08:15:21] EFI stub: Booting Linux Kernel...
If the hang occurs above, use the debug UEFI binary to investigate.
Based on my understanding, UEFI/L4TLauncher selects the boot option, applies DTB overlays and reserved-memory updates, and then hands control over to the Linux kernel.
I am seeing promising results having followed this forum and changed the background to black,
However, I am still seeing the message “L4TLauncher : Attempting Direct Boot”. I have commented this field out in L4TLauncher.c and rebuilt the image, but i am still seeing this message. Any idea why?
Please could you run me through the steps in some more detail, I’m not understanding where to run this (host or target) and where the replacment bootaa64.efi file is located.
