To remove text printing from the UEFI Logo interface on Jetson Orin Nano, you can try the following steps:
Modify the UEFI source code to remove the unwanted text. This will require recompiling the UEFI code and reflashing the Jetson module.
Update the EFI image by copying the modified BOOTAA64.EFI file to the ESP partition.
However, as you’ve mentioned, even after modifying the UEFI source code and updating the EFI image, the “L4TLauncher: Attempting Direct Boot” message still remains.
This is because the “L4TLauncher: Attempting Direct Boot” message is not part of the UEFI code, but rather a message printed by the L4TLauncher application, which is responsible for launching the Linux kernel.
To remove this message, you’ll need to modify the L4TLauncher application or disable its output. Unfortunately, the provided context does not contain information on how to achieve this.
In comparison, the solutions provided in the NVIDIA Developer Forums for removing boot messages from the screen on Jetson Xavier NX (JetPack 5.1.1) and modifying the UEFI on Jetson Orin NX do not seem to be directly applicable to your situation, as they do not address the “L4TLauncher: Attempting Direct Boot” message specifically.
Therefore, to completely remove text printing from the UEFI Logo interface on Jetson Orin Nano, you may need to explore further modifications to the L4TLauncher application or seek additional guidance from NVIDIA or the Jetson community.
