Hi
I m using a Jetson NX and access video streams
I’m unable access the video feed with uri - rtsp:://admin:xxx@2011@11.11.11.20:554
Cameras are hikvision NVR
I m able access this from a laptop and python.
I m guessing the uri format im using might incorrect, is the @ in the password the problem.
Regards
Gautam
The error message I get is 401: Unauthorised
DaneLLL
September 21, 2020, 2:28am
4
You may try
gst-launch-1.0 rtspsrc location=rtsp://admin:xxx@2011@11.11.11.20:554 ! fakesink
to check if the URI is valid. If it works, please try
gst-launch-1.0 uridecodebin uri=rtsp://admin:xxx@2011@11.11.11.20:554 ! nvoverlaysink
I tried the URI as mentioned above, getting the error as “No valid RTSP URL was provided”
I tried as - gst-launch-1.0 rtspsrc location=rtsp://admin:xxx@2011@11.11.11.20:554 ! fakesink
for this i get error as
gst_rtspsrc_send (): /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0:
Unauthorized (401)
Regards
Gautam
DaneLLL
September 21, 2020, 7:00am
6
You may check with vendor to have a valid URI.
FYR. We have a Hikvision IP camera and the URI is
rtsp://admin:hello123@10.24.238.156:554/ISAPI/Streaming/channels/101
Hi
I checked but the URI’s were correct.
However, I tried encoding the URI while passing it (instead of @ - used %40) and it worked !!!
rtsp://admin:xxx%402011@11.11.11.20:554
Not sure if this is standard but it worked… Thanks
Regards
Gautam
