Unable to add conservative default mode "nvidia-auto-select"
I am currently running Orin NX on the Orin Nano board. I am experiencing an issue where the X server crashes when a specific device is connected to the DisplayPort at startup (the device I have confirmed the issue with is a DP hub device with nothing connected on the Tx side).
$ sudo cat /var/log/Xorg.0.log | grep EE
[    29.766] Current Operating System: Linux eizo-desktop 5.15.136-tegra #1 SMP PREEMPT Mon May 6 09:56:39 PDT 2024 aarch64
        (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[    30.254] (EE) NVIDIA(GPU-0): Unable to add conservative default mode "nvidia-auto-select".
[    30.254] (EE) NVIDIA(GPU-0): Unable to add "nvidia-auto-select" mode to ModePool.
[    30.255] (EE) NVIDIA(0): Unable to use default mode "nvidia-auto-select".
[    30.255] (EE) NVIDIA(0): Failing initialization of X screen
[    30.537] (EE) Screen(s) found, but none have a usable configuration.
[    30.537] (EE)
[    30.537] (EE) no screens found(EE)
[    30.537] (EE)
[    30.537] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[    30.537] (EE)
[    30.543] (EE) Server terminated with error (1). Closing log file.
I am unable to determine the following regarding this issue:
  • Under what conditions does the DisplayPort device cause this abnormal behavior?
  • Can this issue be prevented through X server configuration or other settings?
  • If resolving this is difficult, is there a guarantee that this issue only occurs with this specific device?
What should I check to resolve this issue? I appreciate your assistance with this matter.
Sounds an issue to check. Could you flash your BSP back to rel-35.5 and see if such issue is there too?
Also, provide us model ID of the device you are using.
Hello, Wayne. Thank you for your response.
It seems that the same issue occurs with R35.5.0 as well.
ubuntu@ubuntu-desktop:~$ sudo cat /var/log/Xorg.0.log | grep EE
[    17.913] Current Operating System: Linux ubuntu-desktop 5.10.192-tegra #1 SMP PREEMPT Mon Feb 19 20:19:53 PST 2024 aarch64
[    18.849] (EE) NVIDIA(GPU-0): Unable to add conservative default mode "nvidia-auto-select".
[    18.849] (EE) NVIDIA(GPU-0): Unable to add "nvidia-auto-select" mode to ModePool.
[    18.850] (EE) NVIDIA(0): Unable to use default mode "nvidia-auto-select".
[    18.850] (EE) NVIDIA(0): Failing initialization of X screen
[    18.888] (EE) Screen(s) found, but none have a usable configuration.
[    18.888] (EE)
[    18.888] (EE) no screens found(EE)
[    18.888] (EE)
[    18.888] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[    18.888] (EE)
[    18.895] (EE) Server terminated with error (1). Closing log file.
The device where I confirmed the issue is the Synaptics VMM6220 (with nothing connected on the Tx side).
Thank you.
Could you share your full xorg log but not just this partial one?
I am attaching the complete syslog and Xorg.0.log.
Thank you.
r35_5_syslog.log (541.9 KB)
r35_5_Xorg.0.log (9.1 KB)
Do you have other hub there that can check if all the hub would hit such issue or only VMM6220?
I only have hubs from the same manufacturer.
It seems that these hubs also experience the same issue.
Synaptics VMM5320
Synaptics VMM6210
Also, I have not yet confirmed the same issue with monitors. However, I have not tested with special monitors that lack EDID or have incomplete EDID information.
I still haven’t found a good solution to this problem.
Is there any additional information I should provide here to help resolve this issue?
