Unable to build OFED kernel modules with any kernel version 6.x
OS: RHEL 9.4 (x86_64)
OFED: 24.10-1.1.4.0
All attempts to build the ofed kernel modules with a 6.x kernel fail. As an example, this is the log when trying to run mlnx_add_kernel_support.sh with linux 6.6 kernel:
knem-1.1.4.90mlnx3.rpmbuild.log
rpmbuild --rebuild --define _topdir /tmp/mlnx_iso.12098/OFED_topdir --define _sourcedir %{_topdir}/SOURCES --define _specdir %{_topdir}/SPECS --define _srcrpmdir %{_topdir}/SRPMS --define _rpmdir %{_topdir}/RPMS --define KVERSION 6.6.0 --define K_SRC /lib/modules/6.6.0/build --define _dist .rhel9u4 --define _prefix /usr /tmp/mlnx_iso.12098/MLNX_OFED_SRC-24.10-1.1.4.0/SRPMS/knem-1.1.4.90mlnx3-OFED.23.10.0.2.1.1.src.rpm
warning: user builder does not exist - using root
warning: group dip does not exist - using root
warning: extra tokens at the end of %else directive in line 88: %else # not KMP
warning: extra tokens at the end of %endif directive in line 100: %endif #end if “%{KMP}” == “1”
warning: extra tokens at the end of %endif directive in line 128: %endif # end of setup module sign scripts
warning: extra tokens at the end of %endif directive in line 237: %endif # end KMP=1
Installing /tmp/mlnx_iso.12098/MLNX_OFED_SRC-24.10-1.1.4.0/SRPMS/knem-1.1.4.90mlnx3-OFED.23.10.0.2.1.1.src.rpm
setting SOURCE_DATE_EPOCH=1395014400
Executing(%prep): /bin/sh -e /var/tmp/rpm-tmp.dA0TWo
  • umask 022
  • cd /tmp/mlnx_iso.12098/OFED_topdir/BUILD
  • rm -rf knem-1.1.4.90mlnx3
  • /usr/bin/gzip -dc /tmp/mlnx_iso.12098/OFED_topdir/SOURCES/knem-1.1.4.90mlnx3.tar.gz
  • /usr/bin/tar -xvvof -
    drwxr-xr-x builder/dip 0 2023-09-21 08:41 knem-1.1.4.90mlnx3/
    drwxr-xr-x builder/dip 0 2023-09-21 08:41 knem-1.1.4.90mlnx3/common/
    -rw-r–r-- builder/dip 788 2023-09-21 08:41 knem-1.1.4.90mlnx3/common/knem_config.h.in
    -rw-r–r-- builder/dip 20930 2023-09-21 08:41 knem-1.1.4.90mlnx3/common/knem_io.h
    -rw-r–r-- builder/dip 165 2023-09-21 08:41 knem-1.1.4.90mlnx3/AUTHORS
    -rw-r–r-- builder/dip 501 2023-09-21 08:41 knem-1.1.4.90mlnx3/COPYING
    -rwxr-xr-x builder/dip 205328 2023-09-21 08:41 knem-1.1.4.90mlnx3/configure
    drwxr-xr-x builder/dip 0 2023-09-21 08:41 knem-1.1.4.90mlnx3/tools/
    -rw-r–r-- builder/dip 10133 2023-09-21 08:41 knem-1.1.4.90mlnx3/tools/knem_multifd_test.c
    -rw-r–r-- builder/dip 4632 2023-09-21 08:41 knem-1.1.4.90mlnx3/tools/knem_local_install.in
    drwxr-xr-x builder/dip 0 2023-09-21 08:41 knem-1.1.4.90mlnx3/tools/check/
    -rw-r–r-- builder/dip 5746 2023-09-21 08:41 knem-1.1.4.90mlnx3/tools/check/wrapper.in
    -rw-r–r-- builder/dip 1489 2023-09-21 08:41 knem-1.1.4.90mlnx3/tools/check/Makefile.am
    -rw-r–r-- builder/dip 26795 2023-09-21 08:41 knem-1.1.4.90mlnx3/tools/check/Makefile.in
    -rw-r–r-- builder/dip 18682 2023-09-21 08:41 knem-1.1.4.90mlnx3/tools/knem_pingpong.c
    -rwxr-xr-x builder/dip 1498 2023-09-21 08:41 knem-1.1.4.90mlnx3/tools/sign-modules
    -rw-r–r-- builder/dip 6564 2023-09-21 08:41 knem-1.1.4.90mlnx3/tools/knem_access_rights_test.c
    -rw-r–r-- builder/dip 6729 2023-09-21 08:41 knem-1.1.4.90mlnx3/tools/knem_cost.c
    -rw-r–r-- builder/dip 2068 2023-09-21 08:41 knem-1.1.4.90mlnx3/tools/Makefile.am
    -rw-r–r-- builder/dip 8838 2023-09-21 08:41 knem-1.1.4.90mlnx3/tools/knem_notify_fd_test.c
    -rw-r–r-- builder/dip 8581 2023-09-21 08:41 knem-1.1.4.90mlnx3/tools/knem_loopback.c
    -rw-r–r-- builder/dip 38710 2023-09-21 08:41 knem-1.1.4.90mlnx3/tools/Makefile.in
    -rw-r–r-- builder/dip 8294 2023-09-21 08:41 knem-1.1.4.90mlnx3/tools/knem_offload_test.c
    -rw-r–r-- builder/dip 1733 2023-09-21 08:41 knem-1.1.4.90mlnx3/tools/10-knem.rules
    -rw-r–r-- builder/dip 7577 2023-09-21 08:41 knem-1.1.4.90mlnx3/tools/knem_vect_test.c
    -rw-r–r-- builder/dip 23711 2023-09-21 08:41 knem-1.1.4.90mlnx3/tools/knem_collectives.c
    -rw-r–r-- builder/dip 5750 2023-09-21 08:41 knem-1.1.4.90mlnx3/tools/knem_region_cost.c
    -rw-r–r-- builder/dip 12621 2023-09-21 08:41 knem-1.1.4.90mlnx3/tools/knem_status_test.c
    -rw-r–r-- builder/dip 1337 2023-09-21 08:41 knem-1.1.4.90mlnx3/COPYING.BSD-3
    -rw-r–r-- builder/dip 13331 2023-09-21 08:41 knem-1.1.4.90mlnx3/configure.ac
    -rw-r–r-- builder/dip 831 2023-09-21 08:41 knem-1.1.4.90mlnx3/README.devel
    drwxr-xr-x builder/dip 0 2023-09-21 08:41 knem-1.1.4.90mlnx3/debian/
    -rw-r–r-- builder/dip 111 2023-09-21 08:41 knem-1.1.4.90mlnx3/debian/knem.postinst
    -rw-r–r-- builder/dip 1356 2023-09-21 08:41 knem-1.1.4.90mlnx3/debian/control
    -rw-r–r-- builder/dip 15 2023-09-21 08:41 knem-1.1.4.90mlnx3/debian/knem-dkms.install
    -rwxr-xr-x builder/dip 3386 2023-09-21 08:41 knem-1.1.4.90mlnx3/debian/rules
    -rw-r–r-- builder/dip 1292 2023-09-21 08:41 knem-1.1.4.90mlnx3/debian/control.no_dkms
    -rwxr-xr-x builder/dip 432 2023-09-21 08:41 knem-1.1.4.90mlnx3/debian/knem-dkms.prerm
    -rw-r–r-- builder/dip 11 2023-09-21 08:41 knem-1.1.4.90mlnx3/debian/knem.docs
    -rw-r–r-- builder/dip 63 2023-09-21 08:41 knem-1.1.4.90mlnx3/debian/knem-modules.install
    -rw-r–r-- builder/dip 170 2023-09-21 08:41 knem-1.1.4.90mlnx3/debian/changelog
    -rw-r–r-- builder/dip 64 2023-09-21 08:41 knem-1.1.4.90mlnx3/debian/clean
    -rw-r–r-- builder/dip 542 2023-09-21 08:41 knem-1.1.4.90mlnx3/debian/knem.install
    -rw-r–r-- builder/dip 2 2023-09-21 08:41 knem-1.1.4.90mlnx3/debian/compat
    -rwxr-xr-x builder/dip 1035 2023-09-21 08:41 knem-1.1.4.90mlnx3/debian/knem-dkms.postinst
    drwxr-xr-x builder/dip 0 2023-09-21 08:41 knem-1.1.4.90mlnx3/debian/source/
    -rw-r–r-- builder/dip 12 2023-09-21 08:41 knem-1.1.4.90mlnx3/debian/source/format
    -rwxr-xr-x builder/dip 2144 2023-09-21 08:41 knem-1.1.4.90mlnx3/autogen.sh
    -rw-r–r-- builder/dip 1025 2023-09-21 08:41 knem-1.1.4.90mlnx3/TODO
    -rw-r–r-- builder/dip 14138 2023-09-21 08:41 knem-1.1.4.90mlnx3/ChangeLog
    -rwxr-xr-x builder/dip 8662 2023-09-21 08:41 knem-1.1.4.90mlnx3/common.postinst
    drwxr-xr-x builder/dip 0 2023-09-21 08:41 knem-1.1.4.90mlnx3/autom4te.cache/
    -rw-r–r-- builder/dip 205944 2023-09-21 08:41 knem-1.1.4.90mlnx3/autom4te.cache/output.0
    -rw-r–r-- builder/dip 34363 2023-09-21 08:41 knem-1.1.4.90mlnx3/autom4te.cache/traces.1
    -rw-r–r-- builder/dip 50835 2023-09-21 08:41 knem-1.1.4.90mlnx3/autom4te.cache/traces.0
    -rw-r–r-- builder/dip 205944 2023-09-21 08:41 knem-1.1.4.90mlnx3/autom4te.cache/output.1
    -rw-r–r-- builder/dip 7639 2023-09-21 08:41 knem-1.1.4.90mlnx3/autom4te.cache/requests
    -rwxr-xr-x builder/dip 43499 2023-09-21 08:41 knem-1.1.4.90mlnx3/config.guess
    -rw-r–r-- builder/dip 2485 2023-09-21 08:41 knem-1.1.4.90mlnx3/Makefile.am
    -rwxr-xr-x builder/dip 36144 2023-09-21 08:41 knem-1.1.4.90mlnx3/config.sub
    -rwxr-xr-x builder/dip 7333 2023-09-21 08:41 knem-1.1.4.90mlnx3/compile
    -rw-r–r-- builder/dip 31317 2023-09-21 08:41 knem-1.1.4.90mlnx3/Makefile.in
    -rwxr-xr-x builder/dip 15155 2023-09-21 08:41 knem-1.1.4.90mlnx3/install-sh
    -rwxr-xr-x builder/dip 9218 2023-09-21 08:41 knem-1.1.4.90mlnx3/knem.spec
    -rw-r–r-- builder/dip 229 2023-09-21 08:41 knem-1.1.4.90mlnx3/knem.pc.in
    -rw-r–r-- builder/dip 3148 2023-09-21 08:41 knem-1.1.4.90mlnx3/README.md
    drwxr-xr-x builder/dip 0 2023-09-21 08:41 knem-1.1.4.90mlnx3/driver/
    drwxr-xr-x builder/dip 0 2023-09-21 08:41 knem-1.1.4.90mlnx3/driver/linux/
    -rwxr-xr-x builder/dip 13780 2023-09-21 08:41 knem-1.1.4.90mlnx3/driver/linux/check_kernel_headers.sh
    -rw-r–r-- builder/dip 3017 2023-09-21 08:41 knem-1.1.4.90mlnx3/driver/linux/Makefile.am
    -rw-r–r-- builder/dip 12571 2023-09-21 08:41 knem-1.1.4.90mlnx3/driver/linux/knem_hal.h
    -rw-r–r-- builder/dip 17367 2023-09-21 08:41 knem-1.1.4.90mlnx3/driver/linux/Makefile.in
    -rw-r–r-- builder/dip 17 2023-09-21 08:41 knem-1.1.4.90mlnx3/driver/linux/Module.supported
    -rw-r–r-- builder/dip 105082 2023-09-21 08:41 knem-1.1.4.90mlnx3/driver/linux/knem_main.c
    -rw-r–r-- builder/dip 2669 2023-09-21 08:41 knem-1.1.4.90mlnx3/driver/linux/Kbuild.in
    -rw-r–r-- builder/dip 18011 2023-09-21 08:41 knem-1.1.4.90mlnx3/COPYING.GPL-2
    -rw-r–r-- builder/dip 1031 2023-09-21 08:41 knem-1.1.4.90mlnx3/.gitignore
    -rwxr-xr-x builder/dip 4640 2023-09-21 08:41 knem-1.1.4.90mlnx3/test-driver
    -rw-r–r-- builder/dip 3077 2023-09-21 08:41 knem-1.1.4.90mlnx3/dkms.conf
    -rw-r–r-- builder/dip 52391 2023-09-21 08:41 knem-1.1.4.90mlnx3/aclocal.m4
    -rwxr-xr-x builder/dip 6872 2023-09-21 08:41 knem-1.1.4.90mlnx3/missing
    drwxr-xr-x builder/dip 0 2023-09-21 08:41 knem-1.1.4.90mlnx3/doc/
    -rw-r–r-- builder/dip 1492 2023-09-21 08:41 knem-1.1.4.90mlnx3/doc/Makefile.am
    -rw-r–r-- builder/dip 15578 2023-09-21 08:41 knem-1.1.4.90mlnx3/doc/Makefile.in
    -rw-r–r-- builder/dip 7161 2023-09-21 08:41 knem-1.1.4.90mlnx3/doc/knem.html
    -rw-r–r-- builder/dip 12322 2023-09-21 08:41 knem-1.1.4.90mlnx3/doc/knem-api.html
    -rwxr-xr-x builder/dip 23566 2023-09-21 08:41 knem-1.1.4.90mlnx3/depcomp
    -rw-r–r-- builder/dip 42 2023-09-21 08:41 knem-1.1.4.90mlnx3/REPORTING-BUGS
  • STATUS=0
  • ‘[’ 0 -ne 0 ‘]’
  • cd knem-1.1.4.90mlnx3
  • /usr/bin/chmod -Rf a+rX,u+w,g-w,o-w .
  • set – AUTHORS COPYING COPYING.BSD-3 COPYING.GPL-2 ChangeLog Makefile.am Makefile.in README.devel README.md REPORTING-BUGS TODO aclocal.m4 autogen.sh autom4te.cache common common.postinst compile config.guess config.sub configure configure.ac debian depcomp dkms.conf doc driver install-sh knem.pc.in knem.spec missing test-driver tools
  • mkdir source
  • mv AUTHORS COPYING COPYING.BSD-3 COPYING.GPL-2 ChangeLog Makefile.am Makefile.in README.devel README.md REPORTING-BUGS TODO aclocal.m4 autogen.sh autom4te.cache common common.postinst compile config.guess config.sub configure configure.ac debian depcomp dkms.conf doc driver install-sh knem.pc.in knem.spec missing test-driver tools source/
  • mkdir obj
  • RPM_EC=0
    ++ jobs -p
  • exit 0
    Executing(%build): /bin/sh -e /var/tmp/rpm-tmp.5767s3
  • umask 022
  • rm -rf /tmp/mlnx_iso.12098/OFED_topdir/BUILDROOT/knem-1.1.4.90mlnx3-OFED.23.10.0.2.1.1.rhel9u4.x86_64
  • export INSTALL_MOD_DIR=extra/knem
  • INSTALL_MOD_DIR=extra/knem
  • for flavor in default
  • export KSRC=/lib/modules/6.6.0/build
  • KSRC=/lib/modules/6.6.0/build
  • export KVERSION=6.6.0
  • KVERSION=6.6.0
  • export LIB_MOD_DIR=/lib/modules/6.6.0/extra/knem
  • LIB_MOD_DIR=/lib/modules/6.6.0/extra/knem
  • export MODULE_DESTDIR=/lib/modules/6.6.0/extra/knem
  • MODULE_DESTDIR=/lib/modules/6.6.0/extra/knem
  • rm -rf obj/default
  • cp -a source obj/default
  • cd /tmp/mlnx_iso.12098/OFED_topdir/BUILD/knem-1.1.4.90mlnx3/obj/default
  • find . -type f -exec touch -t 200012201010 ‘{}’ ‘;’
  • ./configure --prefix=/opt/knem-1.1.4.90mlnx3 --with-linux-release=6.6.0 --with-linux=/lib/modules/6.6.0/source --with-linux-build=/lib/modules/6.6.0/build --libdir=/opt/knem-1.1.4.90mlnx3/lib
    checking build system type… x86_64-pc-linux-gnu
    checking host system type… x86_64-pc-linux-gnu
    checking target system type… x86_64-pc-linux-gnu
    checking for a BSD-compatible install… /usr/bin/install -c
    checking whether build environment is sane… yes
    checking for a thread-safe mkdir -p… /usr/bin/mkdir -p
    checking for gawk… gawk
    checking whether make sets $(MAKE)… yes
    checking whether make supports nested variables… yes
    checking whether make supports nested variables… (cached) yes
    checking for style of include used by make… GNU
    checking for gcc… gcc
    checking whether the C compiler works… yes
    checking for C compiler default output file name… a.out
    checking for suffix of executables…
    checking whether we are cross compiling… no
    checking for suffix of object files… o
    checking whether we are using the GNU C compiler… yes
    checking whether gcc accepts -g… yes
    checking for gcc option to accept ISO C89… none needed
    checking whether gcc understands -c and -o together… yes
    checking dependency style of gcc… gcc3
    checking how to run the C preprocessor… gcc -E
    checking for gcc… (cached) gcc
    checking whether we are using the GNU C compiler… (cached) yes
    checking whether gcc accepts -g… (cached) yes
    checking for gcc option to accept ISO C89… (cached) none needed
    checking whether gcc understands -c and -o together… (cached) yes
    checking dependency style of gcc… (cached) gcc3
    checking which compiler to use for kernel modules…
    configure: overriding kernel source and build dirs with /lib/modules/6.6.0/source
    configure: overriding kernel build dir with /lib/modules/6.6.0/build
    expr: syntax error: unexpected argument ‘LINUX_COMPILER’
    ./configure: line 4815: [: -lt: unary operator expected
    checking kernel.h kernel header… found in /lib/modules/6.6.0/build
    checking autoconf.h kernel header… found in /lib/modules/6.6.0/build
    checking kernel Makefile… found in /lib/modules/6.6.0/build
    configure: found Linux kernel release 6.6.0 in build tree
    checking kernel build supports ccflags-y… yes
    configure: checking kernel headers …
    checking (in kernel headers) vmalloc_user() availability… yes
    checking (in kernel headers) remap_vmalloc_range() availability … yes
    checking (in kernel headers) get_user_pages_fast() availability … yes
    checking (in kernel headers) whether get_user_pages_fast() wants flags … yes
    checking (in kernel headers) pin_user_pages_fast() availability … yes
    checking (in kernel headers) unpin_user_pages_dirty_lock() availability … yes
    checking (in kernel headers) cpumask_pr_args() availability … yes
    checking (in kernel headers) cpumask_of_node() availability … yes
    checking (in kernel headers) cpumask_complement() availability … no
    checking (in kernel headers) set_cpus_allowed_ptr() … yes
    checking (in kernel headers) whether task_struct contains a cpus_mask field … yes
    checking (in kernel headers) whether the idr interface is RCU-ready … yes
    checking (in kernel headers) idr_preload() availability … yes
    checking (in kernel headers) the ida interface … no
    checking (in kernel headers) whether work_struct contains a data field … no
    checking (in kernel headers) whether kmap_atomic() needs a type … no
    checking (in kernel headers) the dmaengine interface … yes
    checking (in kernel headers) is_dma_copy_aligned availability … yes
    checking (in kernel headers) dma_async_issue_pending() availability … yes
    checking (in kernel headers) dma_async_is_tx_complete() availability … yes
    checling (in kernel headers) DMA_COMPLETE availability … yes
    checking (in kernel headers) dma_async_memcpy_pg_to_pg() availability … no
    checking (in kernel headers) dmaengine_get_unmap_data() availability … yes
    checking (in kernel headers) current_uid() availability … yes
    checking (in kernel headers) whether cred uses kuid_t fields … yes
    checking (in kernel headers) printk_once() availability … yes
    checking (in kernel headers) timer_setup() availability … yes
    creating driver/linux/./driver/linux/knem_checks.h
    checking if debug is enabled in the driver… no
    checking for pkg-config… /usr/bin/pkg-config
    checking pkg-config is at least version 0.9.0… yes
    checking for HWLOC… no
    configure: creating symlinks to wrapper in tools/check/ …
    checking that generated files are newer than configure… done
    configure: creating ./config.status
    config.status: creating driver/linux/Makefile
    config.status: creating driver/linux/Kbuild
    config.status: creating tools/Makefile
    config.status: creating tools/knem_local_install
    config.status: creating tools/check/Makefile
    config.status: creating tools/check/wrapper
    config.status: creating doc/Makefile
    config.status: creating Makefile
    config.status: creating knem.pc
    config.status: creating common/knem_config.h
    config.status: executing depfiles commands
    config.status: executing chmoding-check_wrapper commands
Driver Configuration Summary
Linux kernel headers: /lib/modules/6.6.0/build
Linux kernel build tree: /lib/modules/6.6.0/build
Linux kernel release: 6.6.0
  • make
    Making all in driver/linux
    make[1]: Entering directory ‘/tmp/mlnx_iso.12098/OFED_topdir/BUILD/knem-1.1.4.90mlnx3/obj/default/driver/linux’
    LDFLAGS=“” make -C /lib/modules/6.6.0/build M=/tmp/mlnx_iso.12098/OFED_topdir/BUILD/knem-1.1.4.90mlnx3/obj/default/driver/linux CONFIG_CC_STACKPROTECTOR_STRONG= CONFIG_CTF= V= || test xid -u != xstat -c %u Kbuild
    make[2]: Entering directory ‘/usr/src/kernels/linux-6.6’
    CC [M] /tmp/mlnx_iso.12098/OFED_topdir/BUILD/knem-1.1.4.90mlnx3/obj/default/driver/linux/knem_main.o
    In file included from ./include/linux/rhashtable-types.h:15,
    from ./include/linux/ipc.h:7,
    from ./include/uapi/linux/sem.h:5,
    from ./include/linux/sem.h:5,
    from ./include/linux/sched.h:15,
    from ./include/linux/ratelimit.h:6,
    from ./include/linux/dev_printk.h:16,
    from ./include/linux/device.h:15,
    from ./include/linux/miscdevice.h:7,
    from /tmp/mlnx_iso.12098/OFED_topdir/BUILD/knem-1.1.4.90mlnx3/obj/default/driver/linux/knem_main.c:9:
    /tmp/mlnx_iso.12098/OFED_topdir/BUILD/knem-1.1.4.90mlnx3/obj/default/driver/linux/knem_main.c: In function ‘knem_exit’:
    ./include/linux/workqueue.h:631:9: error: call to ‘__warn_flushing_systemwide_wq’ declared with attribute warning: Please avoid flushing system-wide workqueues. [-Werror=attribute-warning]
    631 | __warn_flushing_systemwide_wq();
    /tmp/mlnx_iso.12098/OFED_topdir/BUILD/knem-1.1.4.90mlnx3/obj/default/driver/linux/knem_main.c:3526:9: note: in expansion of macro ‘flush_scheduled_work’
    3526 | flush_scheduled_work();
    cc1: all warnings being treated as errors
    make[4]: *** [scripts/Makefile.build:243: /tmp/mlnx_iso.12098/OFED_topdir/BUILD/knem-1.1.4.90mlnx3/obj/default/driver/linux/knem_main.o] Error 1
    make[3]: *** [/usr/src/kernels/linux-6.6/Makefile:1913: /tmp/mlnx_iso.12098/OFED_topdir/BUILD/knem-1.1.4.90mlnx3/obj/default/driver/linux] Error 2
    make[2]: *** [Makefile:234: __sub-make] Error 2
    make[2]: Leaving directory ‘/usr/src/kernels/linux-6.6’
    make[1]: *** [Makefile:530: knem.ko] Error 1
    make[1]: Leaving directory ‘/tmp/mlnx_iso.12098/OFED_topdir/BUILD/knem-1.1.4.90mlnx3/obj/default/driver/linux’
    make: *** [Makefile:487: all-recursive] Error 1
    error: Bad exit status from /var/tmp/rpm-tmp.5767s3 (%build)
RPM build errors:
extra tokens at the end of %endif directive in line 100:  %endif #end if "%{KMP}" == "1"
---------------- START OF DEBUG INFO -------------------
Install command: MLNX_OFED_SRC-24.10-1.1.4.0/install.pl --tmpdir /tmp/mlnx_iso.12098_logs --kernel-only --fwctl --kernel 6.6.0 --kernel-sources /lib/modules/6.6.0/build --builddir /tmp/mlnx_iso.12098 --disable-kmp --build-only
Vars dump:
  • ofedlogs: /tmp/mlnx_iso.12098_logs/OFED.12488.logs
  • DISTRO: RHEL9.4
  • dist_rpm: redhat-release-9.4-0.4.el9
  • rpm_distro: rhel9u4
  • arch: x86_64
  • kernel: 6.6.0
  • kmp: 0
  • config: /tmp/mlnx_iso.12098/MLNX_OFED_SRC-24.10-1.1.4.0/ofed.conf
  • target_cpu: x86_64
  • update: 0
Setup info:
  • uname -r: 6.6.0
  • uname -m: x86_64
  • rpm -qf /etc/issue: redhat-release-9.4-0.4.el9.x86_64
  • cat /etc/issue: \S
    Kernel \r on an \m
  • rpm -qf /etc/os-release: redhat-release-9.4-0.4.el9.x86_64
  • cat /etc/os-release: NAME=“Red Hat Enterprise Linux”
    VERSION=“9.4 (Plow)”
    ID=“rhel”
    ID_LIKE=“fedora”
    VERSION_ID=“9.4”
    PLATFORM_ID=“platform:el9”
    PRETTY_NAME=“Red Hat Enterprise Linux 9.4 (Plow)”
    ANSI_COLOR=“0;31”
    LOGO=“fedora-logo-icon”
    CPE_NAME=“cpe:/o:redhat:enterprise_linux:9::baseos”
    HOME_URL=“https://www.redhat.com/
    DOCUMENTATION_URL=“Red Hat Enterprise Linux | Red Hat Product Documentation
    BUG_REPORT_URL=“https://bugzilla.redhat.com/
REDHAT_BUGZILLA_PRODUCT=“Red Hat Enterprise Linux 9”
REDHAT_BUGZILLA_PRODUCT_VERSION=9.4
REDHAT_SUPPORT_PRODUCT=“Red Hat Enterprise Linux”
REDHAT_SUPPORT_PRODUCT_VERSION=“9.4”
  • cat /proc/version: Linux version 6.6.0 (root@icx-dev1) (gcc (GCC) 11.3.1 20221121 (Red Hat 11.3.1-4), GNU ld version 2.35.2-43.el9) #1 SMP PREEMPT_DYNAMIC Mon Feb 3 12:13:13 PST 2025
  • gcc --version: gcc (GCC) 11.3.1 20221121 (Red Hat 11.3.1-4)
    Copyright (C) 2021 Free Software Foundation, Inc.
    This is free software; see the source for copying conditions. There is NO
    warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
  • lspci -n | grep 15b3:
  • rpm -qa: linux-firmware-whence-20240219-143.el9.noarch
    crypto-policies-20240202-1.git283706d.el9.noarch
    fonts-filesystem-2.0.5-7.el9.1.noarch
    hwdata-0.348-9.13.el9.noarch
    tzdata-2024a-1.el9.noarch
    dejavu-sans-fonts-2.37-18.el9.noarch
    langpacks-core-font-en-3.0-16.el9.noarch
    javapackages-filesystem-6.0.0-4.el9.noarch
    emacs-filesystem-27.2-9.el9.noarch
    adobe-mappings-cmap-20171205-12.el9.noarch
    subscription-manager-rhsm-certificates-20220623-1.el9.noarch
    libreport-filesystem-2.15.2-6.el9.noarch
    dnf-data-4.14.0-9.el9.noarch
    adobe-mappings-cmap-deprecated-20171205-12.el9.noarch
    osinfo-db-20231215-1.el9.noarch
    adobe-source-code-pro-fonts-2.030.1.050-12.el9.1.noarch
    abattis-cantarell-fonts-0.301-4.el9.noarch
    google-droid-sans-fonts-20200215-11.el9.2.noarch
    linux-firmware-20240219-143.el9.noarch
    xkeyboard-config-2.33-2.el9.noarch
    tzdata-java-2024a-1.el9.noarch
    rust-srpm-macros-17-4.el9.noarch
    qt5-srpm-macros-5.15.9-1.el9.noarch
    poppler-data-0.4.9-9.el9.noarch
    perl-srpm-macros-1-41.el9.noarch
    openblas-srpm-macros-2-11.el9.noarch
    ocaml-srpm-macros-6-6.el9.noarch
    libX11-common-1.7.0-9.el9.noarch
    kernel-headers-5.14.0-427.13.1.el9_4.x86_64
    ghc-srpm-macros-1.5.0-6.el9.noarch
    gettext-common-devel-0.21-8.el9.noarch
    gawk-all-langpacks-5.1.0-6.el9.x86_64
    adwaita-cursor-theme-40.1.1-3.el9.noarch
    adobe-mappings-pdf-20180407-10.el9.noarch
    redhat-release-eula-9.4-0.4.el9.x86_64
    setup-2.13.7-10.el9.noarch
    filesystem-3.16-2.el9.x86_64
    urw-base35-fonts-common-20200910-6.el9.noarch
    efi-filesystem-6-2.el9_0.noarch
    basesystem-11-13.el9.noarch
    python3-setuptools-wheel-53.0.0-12.el9.noarch
    publicsuffix-list-dafsa-20210518-3.el9.noarch
    pkgconf-m4-1.7.3-10.el9.noarch
    bash-5.1.8-9.el9.x86_64
    zlib-1.2.11-40.el9.x86_64
    xz-libs-5.2.5-8.el9_0.x86_64
    libzstd-1.5.1-2.el9.x86_64
    popt-1.18-8.el9.x86_64
    elfutils-libelf-0.190-2.el9.x86_64
    bzip2-libs-1.0.8-8.el9.x86_64
    libcap-2.48-9.el9_2.x86_64
    sqlite-libs-3.34.1-7.el9_3.x86_64
    libxcrypt-4.4.18-3.el9.x86_64
    expat-2.5.0-2.el9_4.x86_64
    nspr-4.35.0-6.el9_3.x86_64
    libpng-1.6.37-12.el9.x86_64
    readline-8.1-4.el9.x86_64
    gmp-6.2.0-13.el9.x86_64
    json-c-0.14-11.el9.x86_64
    libcom_err-1.46.5-5.el9.x86_64
    lua-libs-5.4.4-4.el9.x86_64
    nss-util-3.90.0-6.el9_3.x86_64
    libmnl-1.0.4-15.el9.x86_64
    libjpeg-turbo-2.0.90-7.el9.x86_64
    mpfr-4.1.0-7.el9.x86_64
    alternatives-1.24-1.el9.x86_64
    libcap-ng-0.8.2-7.el9.x86_64
    audit-libs-3.1.2-2.el9.x86_64
    libgpg-error-1.42-5.el9.x86_64
    libtdb-1.4.9-1.el9.x86_64
    libunistring-0.9.10-15.el9.x86_64
    libicu-67.1-9.el9.x86_64
    keyutils-libs-1.6.3-1.el9.x86_64
    findutils-4.8.0-6.el9.x86_64
    libtalloc-2.4.1-1.el9.x86_64
    lz4-libs-1.9.3-5.el9.x86_64
    boost-system-1.75.0-8.el9.x86_64
    libogg-1.3.4-6.el9.x86_64
    libvorbis-1.3.7-5.el9.x86_64
    libidn2-2.3.0-7.el9.x86_64
    libgcrypt-1.10.0-10.el9_2.x86_64
    libwayland-client-1.21.0-1.el9.x86_64
    xml-common-0.6.3-58.el9.noarch
    libedit-3.1-38.20210216cvs.el9.x86_64
    dmidecode-3.5-3.el9.x86_64
    fuse-libs-2.9.9-15.el9.x86_64
    gdbm-libs-1.19-4.el9.x86_64
    libattr-2.5.1-3.el9.x86_64
    libacl-2.3.1-4.el9.x86_64
    sed-4.8-9.el9.x86_64
    shadow-utils-4.9-8.el9.x86_64
    libnl3-3.9.0-1.el9.x86_64
    libseccomp-2.5.2-2.el9.x86_64
    alsa-lib-1.2.10-2.el9.x86_64
    lcms2-2.12-3.el9.x86_64
    libtool-ltdl-2.4.6-45.el9.x86_64
    tar-1.34-6.el9_1.x86_64
    libtevent-0.16.0-1.el9.x86_64
    libassuan-2.5.5-3.el9.x86_64
    libmpc-1.2.1-4.el9.x86_64
    unzip-6.0-56.el9.x86_64
    file-libs-5.39-16.el9.x86_64
    file-5.39-16.el9.x86_64
    diffutils-3.7-12.el9.x86_64
    efivar-libs-38-3.el9.x86_64
    jansson-2.14-1.el9.x86_64
    libbrotli-1.0.9-6.el9.x86_64
    libtasn1-4.16.0-8.el9_1.x86_64
    p11-kit-0.25.3-2.el9.x86_64
    p11-kit-trust-0.25.3-2.el9.x86_64
    make-4.3-8.el9.x86_64
    pciutils-libs-3.7.0-5.el9.x86_64
    which-2.21-29.el9.x86_64
    libstemmer-0-18.585svn.el9.x86_64
    libwebp-1.2.0-8.el9_3.x86_64
    m4-1.4.19-1.el9.x86_64
    opus-1.3.1-10.el9.x86_64
    zip-3.0-35.el9.x86_64
    gettext-libs-0.21-8.el9.x86_64
    gettext-0.21-8.el9.x86_64
    libwayland-cursor-1.21.0-1.el9.x86_64
    libpsl-0.21.1-5.el9.x86_64
    libnftnl-1.2.6-2.el9.x86_64
    libwayland-server-1.21.0-1.el9.x86_64
    exiv2-0.27.5-2.el9.x86_64
    exiv2-libs-0.27.5-2.el9.x86_64
    gdisk-1.0.7-5.el9.x86_64
    libbpf-1.3.0-2.el9.x86_64
    dwz-0.14-3.el9.x86_64
    libxslt-1.1.34-9.el9.x86_64
    groff-base-1.22.4-10.el9.x86_64
    libproxy-0.4.15-35.el9.x86_64
    less-590-3.el9_3.x86_64
    hicolor-icon-theme-0.17-13.el9.noarch
    cpio-2.13-16.el9.x86_64
    libbasicobjects-0.1.1-53.el9.x86_64
    libcollection-0.7.0-53.el9.x86_64
    libdb-5.3.28-53.el9.x86_64
    libdhash-0.5.0-53.el9.x86_64
    libref_array-0.1.5-53.el9.x86_64
    libsigsegv-2.13-4.el9.x86_64
    gawk-5.1.0-6.el9.x86_64
    libsss_idmap-2.9.4-2.el9.x86_64
    libyaml-0.2.5-7.el9.x86_64
    lzo-2.10-7.el9.x86_64
    pcre-8.44-3.el9.3.x86_64
    grep-3.6-5.el9.x86_64
    xz-5.2.5-8.el9_0.x86_64
    fribidi-1.0.10-6.el9.2.x86_64
    libICE-1.0.10-8.el9.x86_64
    libXau-1.0.9-8.el9.x86_64
    libxcb-1.13.1-9.el9.x86_64
    libXext-1.3.4-8.el9.x86_64
    libXrender-0.9.10-16.el9.x86_64
    libXi-1.7.10-8.el9.x86_64
    libXfixes-5.0.3-16.el9.x86_64
    libXcursor-1.2.0-7.el9.x86_64
    libXdamage-1.1.5-7.el9.x86_64
    libXrandr-1.5.2-8.el9.x86_64
    libXinerama-1.1.4-10.el9.x86_64
    libXcomposite-0.4.5-7.el9.x86_64
    libXpm-3.5.13-10.el9.x86_64
    libglvnd-1.3.4-1.el9.x86_64
    libwayland-egl-1.21.0-1.el9.x86_64
    libxshmfence-1.3-10.el9.x86_64
    mesa-libglapi-23.3.3-1.el9.x86_64
    openjpeg2-2.4.0-7.el9.x86_64
    pixman-0.40.0-6.el9.x86_64
    libXtst-1.2.3-16.el9.x86_64
    libXv-1.0.11-16.el9.x86_64
    libXxf86vm-1.1.4-18.el9.x86_64
    libSM-1.2.3-10.el9.x86_64
    libXt-1.2.0-6.el9.x86_64
    libXmu-1.1.3-8.el9.x86_64
    libXaw-1.0.13-19.el9.x86_64
    gettext-devel-0.21-8.el9.x86_64
    squashfs-tools-4.4-10.git1.el9.x86_64
    bison-3.7.4-5.el9.x86_64
    flex-2.6.4-9.el9.x86_64
    libnl3-cli-3.9.0-1.el9.x86_64
    libteam-1.31-16.el9_1.x86_64
    libutempter-1.2.1-6.el9.x86_64
    llvm-libs-17.0.6-5.el9.x86_64
    iso-codes-4.6.0-3.el9.noarch
    flac-libs-1.3.3-10.el9_2.1.x86_64
    libtheora-1.1.1-31.el9.x86_64
    boost-filesystem-1.75.0-8.el9.x86_64
    boost-thread-1.75.0-8.el9.x86_64
    bubblewrap-0.4.1-6.el9.x86_64
    boost-regex-1.75.0-8.el9.x86_64
    source-highlight-3.1.9-11.el9.x86_64
    libbytesize-2.5-3.el9.x86_64
    libksba-1.5.1-6.el9_1.x86_64
    ethtool-6.2-1.el9.x86_64
    ipset-libs-7.11-8.el9.x86_64
    ipset-7.11-8.el9.x86_64
    nss-softokn-freebl-3.90.0-6.el9_3.x86_64
    nss-softokn-3.90.0-6.el9_3.x86_64
    lua-5.4.4-4.el9.x86_64
    lua-posix-35.0-8.el9.x86_64
    copy-jdk-configs-4.0-3.el9.noarch
    e2fsprogs-libs-1.46.5-5.el9.x86_64
    libss-1.46.5-5.el9.x86_64
    libcomps-0.1.18-1.el9.x86_64
    exempi-2.6.0-0.2.20211007gite23c213.el9.x86_64
    libxcrypt-compat-4.4.18-3.el9.x86_64
    bzip2-1.0.8-8.el9.x86_64
    libxkbcommon-1.0.3-4.el9.x86_64
    graphite2-1.3.14-9.el9.x86_64
    snappy-1.1.8-8.el9.x86_64
    tbb-2020.3-8.el9.x86_64
    webrtc-audio-processing-0.3.1-8.el9.x86_64
    info-6.7-15.el9.x86_64
    ed-1.14.2-12.el9.x86_64
    patch-2.7.6-16.el9.x86_64
    pigz-2.5-4.el9.x86_64
    libfontenc-1.1.3-17.el9.x86_64
    hostname-3.23-6.el9.x86_64
    kernel-tools-libs-5.14.0-427.13.1.el9_4.x86_64
    lksctp-tools-1.0.19-3.el9_4.x86_64
    adwaita-icon-theme-40.1.1-3.el9.noarch
    libpaper-1.1.28-4.el9.x86_64
    psmisc-23.4-3.el9.x86_64
    iproute-6.2.0-6.el9_4.x86_64
    bluez-libs-5.64-2.el9.x86_64
    c-ares-1.19.1-1.el9.x86_64
    dosfstools-4.2-3.el9.x86_64
    inih-49-6.el9.x86_64
    libatomic-11.4.1-3.el9.x86_64
    libcbor-0.7.0-5.el9.x86_64
    libdaemon-0.14-23.el9.x86_64
    libeconf-0.4.1-3.el9_2.x86_64
    libndp-1.8-4.el9.x86_64
    libnfnetlink-1.0.1-21.el9.x86_64
    libnetfilter_conntrack-1.0.9-1.el9.x86_64
    iptables-libs-1.8.10-2.el9.x86_64
    nftables-1.0.9-1.el9.x86_64
    libnghttp2-1.43.0-5.el9_3.1.x86_64
    libpath_utils-0.2.1-53.el9.x86_64
    libini_config-1.3.1-53.el9.x86_64
    libpciaccess-0.16-6.el9.x86_64
    libdrm-2.4.117-1.el9.x86_64
    mesa-libgbm-23.3.3-1.el9.x86_64
    libglvnd-egl-1.3.4-1.el9.x86_64
    mesa-libEGL-23.3.3-1.el9.x86_64
    libglvnd-glx-1.3.4-1.el9.x86_64
    mesa-libGL-23.3.3-1.el9.x86_64
    libpipeline-1.5.3-4.el9.x86_64
    libpkgconf-1.7.3-10.el9.x86_64
    pkgconf-pkg-config-1.7.3-10.el9.x86_64
    libzstd-devel-1.5.1-2.el9.x86_64
    zlib-devel-1.2.11-40.el9.x86_64
    elfutils-libelf-devel-0.190-2.el9.x86_64
    xz-devel-5.2.5-8.el9_0.x86_64
    libsss_nss_idmap-2.9.4-2.el9.x86_64
    libsss_sudo-2.9.4-2.el9.x86_64
    libverto-0.3.2-3.el9.x86_64
    lmdb-libs-0.9.29-3.el9.x86_64
    nettle-3.9.1-1.el9.x86_64
    gnutls-3.8.3-1.el9.x86_64
    npth-1.6-8.el9.x86_64
    oniguruma-6.9.6-1.el9.5.x86_64
    jq-1.6-16.el9.x86_64
    sg3_utils-libs-1.47-9.el9.x86_64
    slang-2.3.2-11.el9.x86_64
    newt-0.52.21-11.el9.x86_64
    userspace-rcu-0.12.1-6.el9.x86_64
    checkpolicy-3.6-1.el9.x86_64
    fdk-aac-free-2.0.0-8.el9.x86_64
    giflib-5.2.1-9.el9.x86_64
    libxcrypt-devel-4.4.18-3.el9.x86_64
    gsm-1.0.19-6.el9.x86_64
    libsndfile-1.0.31-8.el9.x86_64
    jbig2dec-libs-0.19-7.el9.x86_64
    jbigkit-libs-2.1-23.el9.x86_64
    libtiff-4.4.0-12.el9.x86_64
    libasyncns-0.8-22.el9.x86_64
    libdatrie-0.2.13-4.el9.x86_64
    libthai-0.1.28-8.el9.x86_64
    libepoxy-1.5.5-4.el9.x86_64
    libestr-0.1.11-4.el9.x86_64
    libexif-0.6.22-6.el9.x86_64
    libfastjson-0.99.9-5.el9.x86_64
    libijs-0.35-15.el9.x86_64
    libipt-2.0.4-5.el9.x86_64
    libiptcdata-1.0.5-9.el9.x86_64
    libldac-2.0.2.3-10.el9.x86_64
    libsbc-1.4-9.el9.x86_64
    libvisual-0.4.0-34.el9.x86_64
    orc-0.4.31-6.el9.x86_64
    langpacks-core-en-3.0-16.el9.noarch
    libssh-config-0.10.4-13.el9.noarch
    kbd-misc-2.4.0-9.el9.noarch
    kbd-legacy-2.4.0-9.el9.noarch
    fuse-common-3.10.2-8.el9.x86_64
    fuse-2.9.9-15.el9.x86_64
    firewalld-filesystem-1.3.4-1.el9.noarch
    coreutils-common-8.32-35.el9.x86_64
    openssl-fips-provider-3.0.7-2.el9.x86_64
    openssl-libs-3.0.7-27.el9.x86_64
    coreutils-8.32-35.el9.x86_64
    ca-certificates-2023.2.60_v7.0.306-90.1.el9_2.noarch
    kmod-libs-28-9.el9.x86_64
    dbus-libs-1.12.20-8.el9.x86_64
    krb5-libs-1.21.1-1.el9.x86_64
    libarchive-3.5.3-4.el9.x86_64
    json-glib-1.6.6-1.el9.x86_64
    freetype-2.10.4-9.el9.x86_64
    fontconfig-2.14.0-2.el9_1.x86_64
    cairo-1.17.4-7.el9.x86_64
    atk-2.36.0-5.el9.x86_64
    polkit-libs-0.117-11.el9.x86_64
    libgudev-237-1.el9.x86_64
    gzip-1.12-1.el9.x86_64
    cairo-gobject-1.17.4-7.el9.x86_64
    NetworkManager-libnm-1.46.0-4.el9_4.x86_64
    shared-mime-info-2.1-5.el9.x86_64
    gdk-pixbuf2-2.42.6-3.el9.x86_64
    libusbx-1.0.26-1.el9.x86_64
    kmod-28-9.el9.x86_64
    libgusb-0.3.8-2.el9.x86_64
    gdk-pixbuf2-modules-2.42.6-3.el9.x86_64
    gtk-update-icon-cache-3.24.31-2.el9.x86_64
    cracklib-2.9.6-27.el9.x86_64
    gobject-introspection-1.68.0-11.el9.x86_64
    gsettings-desktop-schemas-40.0-6.el9.x86_64
    pulseaudio-libs-15.0-2.el9.x86_64
    libevent-2.1.12-6.el9.x86_64
    avahi-libs-0.8-20.el9.x86_64
    cups-libs-2.3.3op2-24.el9.x86_64
    mokutil-0.6.0-4.el9.x86_64
    avahi-glib-0.8-20.el9.x86_64
    cracklib-dicts-2.9.6-27.el9.x86_64
    colord-libs-1.4.5-4.el9.x86_64
    libgsf-1.14.47-5.el9.x86_64
    libnotify-0.7.9-8.el9.x86_64
    libxmlb-0.3.10-1.el9.x86_64
    libgxps-0.3.2-3.el9.x86_64
    gd-2.3.2-3.el9.x86_64
    libXft-2.3.3-8.el9.x86_64
    pango-1.48.7-3.el9.x86_64
    librsvg2-2.50.7-3.el9.x86_64
    urw-base35-bookman-fonts-20200910-6.el9.noarch
    urw-base35-c059-fonts-20200910-6.el9.noarch
    urw-base35-d050000l-fonts-20200910-6.el9.noarch
    urw-base35-gothic-fonts-20200910-6.el9.noarch
    urw-base35-nimbus-mono-ps-fonts-20200910-6.el9.noarch
    urw-base35-nimbus-roman-fonts-20200910-6.el9.noarch
    urw-base35-nimbus-sans-fonts-20200910-6.el9.noarch
    urw-base35-p052-fonts-20200910-6.el9.noarch
    urw-base35-standard-symbols-ps-fonts-20200910-6.el9.noarch
    urw-base35-z003-fonts-20200910-6.el9.noarch
    urw-base35-fonts-20200910-6.el9.noarch
    libgs-9.54.0-14.el9_3.x86_64
    mkfontscale-1.2.1-3.el9.x86_64
    xorg-x11-fonts-ISO8859-1-100dpi-7.5-33.el9.noarch
    librhsm-0.0.3-7.el9_3.1.x86_64
    ModemManager-glib-1.20.2-1.el9.x86_64
    graphene-1.10.6-2.el9.x86_64
    libgexiv2-0.12.3-1.el9.x86_64
    libudisks2-2.9.4-9.el9.x86_64
    low-memory-monitor-2.1-4.el9.x86_64
    totem-pl-parser-3.26.6-2.el9.x86_64
    webkit2gtk3-jsc-2.42.5-1.el9.x86_64
    libproxy-webkitgtk4-0.4.15-35.el9.x86_64
    glib-networking-2.68.3-3.el9.x86_64
    libsoup-2.72.0-8.el9.x86_64
    osinfo-db-tools-1.10.0-1.el9.x86_64
    libosinfo-1.10.0-1.el9.x86_64
    cyrus-sasl-lib-2.1.27-21.el9.x86_64
    openldap-2.6.6-3.el9.x86_64
    gnupg2-2.3.3-4.el9.x86_64
    gpgme-1.15.1-6.el9.x86_64
    libldb-2.8.0-1.el9.x86_64
    libjcat-0.1.6-3.el9.x86_64
    libssh-0.10.4-13.el9.x86_64
    libcurl-7.76.1-29.el9_4.x86_64
    librepo-1.14.5-2.el9.x86_64
    tpm2-tss-3.2.2-2.el9.x86_64
    ima-evm-utils-1.4-4.el9.x86_64
    rpm-4.16.1.3-29.el9.x86_64
    rpm-libs-4.16.1.3-29.el9.x86_64
    libmodulemd-2.13.0-2.el9.x86_64
    libsolv-0.7.24-2.el9.x86_64
    libdnf-0.69.0-8.el9.x86_64
    rpm-sign-libs-4.16.1.3-29.el9.x86_64
    libdnf-plugin-subscription-manager-1.29.40-1.el9.x86_64
    libappstream-glib-0.7.18-4.el9.x86_64
    rpm-plugin-systemd-inhibit-4.16.1.3-29.el9.x86_64
    efi-srpm-macros-6-2.el9_0.noarch
    lua-srpm-macros-1-6.el9.noarch
    ostree-libs-2024.4-3.el9_4.x86_64
    pciutils-3.7.0-5.el9.x86_64
    e2fsprogs-1.46.5-5.el9.x86_64
    procps-ng-3.3.17-14.el9.x86_64
    libatasmart-0.19-22.el9.x86_64
    p11-kit-server-0.25.3-2.el9.x86_64
    python3-setuptools-53.0.0-12.el9.noarch
    python3-dbus-1.2.18-2.el9.x86_64
    python3-six-1.15.0-9.el9.noarch
    python3-dateutil-2.8.1-7.el9.noarch
    python3-gobject-base-noarch-3.40.1-6.el9.noarch
    python3-gobject-base-3.40.1-6.el9.x86_64
    gstreamer1-1.22.1-2.el9.x86_64
    python3-iniparse-0.4-45.el9.noarch
    python3-libdnf-0.69.0-8.el9.x86_64
    python3-hawkey-0.69.0-8.el9.x86_64
    python3-idna-2.10-7.el9.noarch
    gstreamer1-plugins-base-1.22.1-2.el9.x86_64
    python3-inotify-0.9.6-25.el9.noarch
    python3-setools-4.4.4-1.el9.x86_64
    python3-distro-1.5.0-7.el9.noarch
    python3-libcomps-0.1.18-1.el9.x86_64
    python3-librepo-1.14.5-2.el9.x86_64
    python3-chardet-4.0.0-5.el9.noarch
    python3-decorator-4.4.2-6.el9.noarch
    python3-gpg-1.15.1-6.el9.x86_64
    python3-nftables-1.0.9-1.el9.x86_64
    python3-firewall-1.3.4-1.el9.noarch
    python3-pysocks-1.7.1-12.el9.noarch
    python3-urllib3-1.26.5-5.el9.noarch
    python3-requests-2.25.1-8.el9.noarch
    python3-cloud-what-1.29.40-1.el9.x86_64
    python3-pyyaml-5.4.1-6.el9.x86_64
    python3-systemd-234-18.el9.x86_64
    teamd-1.31-16.el9_1.x86_64
    libcap-ng-python3-0.8.2-7.el9.x86_64
    python3-audit-3.1.2-2.el9.x86_64
    python3-file-magic-5.39-16.el9.noarch
    perl-Digest-1.19-4.el9.noarch
    perl-Digest-MD5-2.58-4.el9.x86_64
    perl-B-1.80-481.el9.x86_64
    perl-FileHandle-2.03-481.el9.noarch
    perl-Data-Dumper-2.174-462.el9.x86_64
    perl-libnet-3.13-4.el9.noarch
    perl-AutoLoader-5.74-481.el9.noarch
    perl-base-2.27-481.el9.noarch
    perl-URI-5.09-3.el9.noarch
    perl-if-0.60.800-481.el9.noarch
    perl-IO-Socket-IP-0.41-5.el9.noarch
    perl-Time-Local-1.300-7.el9.noarch
    perl-File-Path-2.18-4.el9.noarch
    perl-IO-Socket-SSL-2.073-1.el9.noarch
    perl-Net-SSLeay-1.92-2.el9.x86_64
    perl-Pod-Escapes-1.07-460.el9.noarch
    perl-Text-Tabs+Wrap-2013.0523-460.el9.noarch
    perl-Mozilla-CA-20200520-6.el9.noarch
    perl-Class-Struct-0.66-481.el9.noarch
    perl-POSIX-1.94-481.el9.x86_64
    perl-Term-ANSIColor-5.01-461.el9.noarch
    perl-IPC-Open3-1.21-481.el9.noarch
    perl-subs-1.03-481.el9.noarch
    perl-File-Temp-0.231.100-4.el9.noarch
    perl-Term-Cap-1.17-460.el9.noarch
    perl-Pod-Simple-3.42-4.el9.noarch
    perl-HTTP-Tiny-0.076-462.el9.noarch
    perl-Socket-2.031-4.el9.x86_64
    perl-SelectSaver-1.02-481.el9.noarch
    perl-Symbol-1.08-481.el9.noarch
    perl-File-stat-1.09-481.el9.noarch
    perl-podlators-4.14-460.el9.noarch
    perl-Pod-Perldoc-3.28.01-461.el9.noarch
    perl-Fcntl-1.13-481.el9.x86_64
    perl-Text-ParseWords-3.30-460.el9.noarch
    perl-mro-1.23-481.el9.x86_64
    perl-IO-1.43-481.el9.x86_64
    perl-overloading-0.02-481.el9.noarch
    perl-Pod-Usage-2.01-4.el9.noarch
    perl-Errno-1.30-481.el9.x86_64
    perl-File-Basename-2.85-481.el9.noarch
    perl-Getopt-Std-1.12-481.el9.noarch
    perl-MIME-Base64-3.16-4.el9.x86_64
    perl-Scalar-List-Utils-1.56-461.el9.x86_64
    perl-constant-1.33-461.el9.noarch
    perl-Storable-3.21-460.el9.x86_64
    perl-overload-1.31-481.el9.noarch
    perl-parent-0.238-460.el9.noarch
    perl-vars-1.05-481.el9.noarch
    perl-Getopt-Long-2.52-4.el9.noarch
    perl-Carp-1.50-460.el9.noarch
    perl-Exporter-5.74-461.el9.noarch
    perl-NDBM_File-1.15-481.el9.x86_64
    perl-PathTools-3.78-461.el9.x86_64
    perl-Encode-3.08-462.el9.x86_64
    perl-libs-5.32.1-481.el9.x86_64
    perl-interpreter-5.32.1-481.el9.x86_64
    perl-DynaLoader-1.47-481.el9.x86_64
    perl-File-Copy-2.34-481.el9.noarch
    perl-File-Find-1.37-481.el9.noarch
    perl-File-Compare-1.100.600-481.el9.noarch
    autoconf-2.69-38.el9.noarch
    perl-threads-2.25-460.el9.x86_64
    perl-threads-shared-1.61-460.el9.x86_64
    perl-Thread-Queue-3.14-460.el9.noarch
    automake-1.16.2-8.el9.noarch
    perl-TermReadKey-2.38-11.el9.x86_64
    kernel-srpm-macros-1.0-13.el9.noarch
    perl-macros-5.32.1-481.el9.noarch
    perl-Error-0.17029-7.el9.noarch
    perl-Fedora-VSP-0.001-23.el9.noarch
    perl-XML-Parser-2.46-9.el9.x86_64
    perl-lib-0.65-481.el9.x86_64
    perl-locale-1.09-481.el9.noarch
    perl-version-0.99.28-4.el9.x86_64
    iptables-nft-1.8.10-2.el9.x86_64
    openssl-3.0.7-27.el9.x86_64
    libpwquality-1.4.4-8.el9.x86_64
    pam-1.5.1-19.el9.x86_64
    dbus-1.12.20-8.el9.x86_64
    dbus-common-1.12.20-8.el9.noarch
    dbus-broker-28-7.el9.x86_64
    selinux-policy-38.1.35-2.el9_4.noarch
    selinux-policy-targeted-38.1.35-2.el9_4.noarch
    polkit-0.117-11.el9.x86_64
    polkit-pkla-compat-0.1-21.el9.x86_64
    grub2-common-2.06-77.el9.noarch
    cronie-anacron-1.5.7-11.el9.x86_64
    cronie-1.5.7-11.el9.x86_64
    crontabs-1.11-27.20190603git.el9_0.noarch
    elfutils-default-yama-scope-0.190-2.el9.noarch
    elfutils-libs-0.190-2.el9.x86_64
    elfutils-debuginfod-client-0.190-2.el9.x86_64
    binutils-gold-2.35.2-43.el9.x86_64
    binutils-2.35.2-43.el9.x86_64
    dyninst-12.1.0-1.el9.x86_64
    elfutils-0.190-2.el9.x86_64
    rpm-build-libs-4.16.1.3-29.el9.x86_64
    python3-rpm-4.16.1.3-29.el9.x86_64
    python3-dnf-4.14.0-9.el9.noarch
    dconf-0.40.0-6.el9.x86_64
    openssh-8.7p1-38.el9.x86_64
    libuser-0.63-13.el9.x86_64
    passwd-0.80-12.el9.x86_64
    usermode-1.114-4.el9.x86_64
    python3-subscription-manager-rhsm-1.29.40-1.el9.x86_64
    annobin-12.31-2.el9.x86_64
    valgrind-3.22.0-2.el9.x86_64
    elfutils-devel-0.190-2.el9.x86_64
    libbabeltrace-1.5.8-10.el9.x86_64
    gdb-headless-10.2-13.el9.x86_64
    debugedit-5.0-5.el9.x86_64
    fonts-srpm-macros-2.0.5-7.el9.1.noarch
    go-srpm-macros-3.2.0-3.el9.noarch
    redhat-rpm-config-207-1.el9.noarch
    rpm-build-4.16.1.3-29.el9.x86_64
    pyproject-srpm-macros-1.12.0-1.el9.noarch
    rtkit-0.11-28.el9.x86_64
    pipewire-libs-1.0.1-1.el9.x86_64
    pipewire-1.0.1-1.el9.x86_64
    wireplumber-libs-0.4.14-1.el9.x86_64
    wireplumber-0.4.14-1.el9.x86_64
    pipewire-jack-audio-connection-kit-libs-1.0.1-1.el9.x86_64
    flatpak-selinux-1.12.8-1.el9.noarch
    authselect-libs-1.2.6-2.el9.x86_64
    device-mapper-libs-1.02.197-2.el9.x86_64
    device-mapper-1.02.197-2.el9.x86_64
    cryptsetup-libs-2.6.0-3.el9.x86_64
    grub2-tools-minimal-2.06-77.el9.x86_64
    parted-3.5-2.el9.x86_64
    libblockdev-utils-2.28-10.el9.x86_64
    libblockdev-2.28-10.el9.x86_64
    libblockdev-fs-2.28-10.el9.x86_64
    libblockdev-loop-2.28-10.el9.x86_64
    libblockdev-part-2.28-10.el9.x86_64
    libblockdev-swap-2.28-10.el9.x86_64
    kpartx-0.8.7-27.el9.x86_64
    xfsprogs-6.3.0-1.el9.x86_64
    initscripts-service-10.11.6-1.el9.noarch
    iputils-20210202-9.el9.x86_64
    libkcapi-1.4.0-2.el9.x86_64
    libkcapi-hmaccalc-1.4.0-2.el9.x86_64
    logrotate-3.18.0-8.el9.x86_64
    rsyslog-logrotate-8.2310.0-4.el9.x86_64
    rsyslog-8.2310.0-4.el9.x86_64
    mdadm-4.2-12.el9_4.x86_64
    libblockdev-mdraid-2.28-10.el9.x86_64
    flatpak-session-helper-1.12.8-1.el9.x86_64
    geoclue2-2.6.0-7.el9.x86_64
    at-spi2-core-2.40.3-1.el9.x86_64
    at-spi2-atk-2.38.0-4.el9.x86_64
    xdg-dbus-proxy-0.1.3-1.el9.x86_64
    flatpak-1.12.8-1.el9.x86_64
    xdg-desktop-portal-1.12.6-1.el9.x86_64
    virt-what-1.25-5.el9.x86_64
    insights-client-3.2.2-2.el9.noarch
    kbd-2.4.0-9.el9.x86_64
    dracut-057-53.git20240104.el9.x86_64
    kernel-modules-core-5.14.0-427.13.1.el9_4.x86_64
    kernel-core-5.14.0-427.13.1.el9_4.x86_64
    NetworkManager-1.46.0-4.el9_4.x86_64
    dracut-network-057-53.git20240104.el9.x86_64
    kernel-modules-5.14.0-427.13.1.el9_4.x86_64
    dracut-squash-057-53.git20240104.el9.x86_64
    libfido2-1.13.0-2.el9.x86_64
    openssh-clients-8.7p1-38.el9.x86_64
    git-core-2.43.0-1.el9.x86_64
    git-core-doc-2.43.0-1.el9.noarch
    perl-Git-2.43.0-1.el9.noarch
    git-2.43.0-1.el9.x86_64
    os-prober-1.77-10.el9.x86_64
    grub2-tools-2.06-77.el9.x86_64
    grubby-8.40-64.el9.x86_64
    crypto-policies-scripts-20240202-1.git283706d.el9.noarch
    nss-sysinit-3.90.0-6.el9_3.x86_64
    nss-3.90.0-6.el9_3.x86_64
    java-1.8.0-openjdk-headless-1.8.0.402.b06-2.el9.x86_64
    nss-tools-3.90.0-6.el9_3.x86_64
    poppler-21.01.0-19.el9.x86_64
    poppler-glib-21.01.0-19.el9.x86_64
    systemtap-runtime-5.0-4.el9.x86_64
    systemtap-client-5.0-4.el9.x86_64
    volume_key-libs-0.3.12-15.el9.x86_64
    libblockdev-crypto-2.28-10.el9.x86_64
    flashrom-1.2-10.el9.x86_64
    fwupd-plugin-flashrom-1.9.13-2.el9.x86_64
    fwupd-1.9.13-2.el9.x86_64
    upower-0.99.13-2.el9.x86_64
    libtracker-sparql-3.1.2-3.el9_1.x86_64
    tracker-3.1.2-3.el9_1.x86_64
    tracker-miners-3.1.2-4.el9_3.x86_64
    sssd-client-2.9.4-2.el9.x86_64
    sgml-common-0.6.3-58.el9.noarch
    docbook-dtds-1.0-79.el9.noarch
    docbook-style-xsl-1.79.2-16.el9.noarch
    sound-theme-freedesktop-0.8-17.el9.noarch
    libcanberra-0.30-27.el9.x86_64
    libcanberra-gtk3-0.30-27.el9.x86_64
    gtk3-3.24.31-2.el9.x86_64
    xdg-desktop-portal-gtk-1.12.0-3.el9.x86_64
    gtk2-2.24.33-8.el9.x86_64
    libcanberra-gtk2-0.30-27.el9.x86_64
    graphviz-2.44.0-26.el9.x86_64
    libnvme-1.6-1.el9.x86_64
    libsss_certmap-2.9.4-2.el9.x86_64
    sssd-common-2.9.4-2.el9.x86_64
    openssl-devel-3.0.7-27.el9.x86_64
    kernel-devel-5.14.0-427.13.1.el9_4.x86_64
    systemtap-devel-5.0-4.el9.x86_64
    systemtap-5.0-4.el9.x86_64
    sssd-kcm-2.9.4-2.el9.x86_64
    nvme-cli-2.6-5.el9.x86_64
    asciidoc-9.1.0-3.el9.noarch
    shim-x64-15.8-3.el9_4.x86_64
    pesign-115-6.el9.x86_64
    jna-5.6.0-8.el9.x86_64
    kexec-tools-2.0.27-8.el9.x86_64
    grub2-efi-x64-2.06-77.el9.x86_64
    kernel-5.14.0-427.13.1.el9_4.x86_64
    NetworkManager-team-1.46.0-4.el9_4.x86_64
    NetworkManager-tui-1.46.0-4.el9_4.x86_64
    dracut-config-rescue-057-53.git20240104.el9.x86_64
    rhc-0.2.4-5.el9.x86_64
    authselect-1.2.6-2.el9.x86_64
    pipewire-jack-audio-connection-kit-1.0.1-1.el9.x86_64
    pipewire-alsa-1.0.1-1.el9.x86_64
    pipewire-pulseaudio-1.0.1-1.el9.x86_64
    gdb-10.2-13.el9.x86_64
    valgrind-devel-3.22.0-2.el9.x86_64
    yum-4.14.0-9.el9.noarch
    openssh-server-8.7p1-38.el9.x86_64
    libtool-2.4.6-45.el9.x86_64
    ltrace-0.7.91-43.el9.x86_64
    strace-5.18-2.el9.x86_64
    rpm-plugin-selinux-4.16.1.3-29.el9.x86_64
    chrony-4.5-1.el9.x86_64
    firewalld-1.3.4-1.el9.noarch
    microcode_ctl-20230808-2.20231009.1.el9_3.noarch
    sudo-1.9.5p2-10.el9_3.x86_64
    perl-generators-1.11-12.el9.noarch
    intltool-0.51.0-20.el9.noarch
    patchutils-0.4.2-7.el9.x86_64
    kernel-tools-5.14.0-427.13.1.el9_4.x86_64
    rpm-sign-4.16.1.3-29.el9.x86_64
    rpm-plugin-audit-4.16.1.3-29.el9.x86_64
    man-db-2.9.3-7.el9.x86_64
    initscripts-rename-device-10.11.6-1.el9.x86_64
    irqbalance-1.9.2-3.el9.x86_64
    prefixdevname-0.1.0-8.el9.x86_64
    langpacks-en-3.0-16.el9.noarch
    sg3_utils-1.47-9.el9.x86_64
    iproute-tc-6.2.0-6.el9_4.x86_64
    efibootmgr-16-12.el9.x86_64
    vim-minimal-8.2.2637-20.el9_1.x86_64
    lshw-B.02.19.2-10.el9.x86_64
    libsysfs-2.1.1-10.el9.x86_64
    lsscsi-0.32-6.el9.x86_64
    byacc-2.0.20210109-4.el9.x86_64
    diffstat-1.64-6.el9.x86_64
    iwl100-firmware-39.31.5.1-143.el9.noarch
    iwl1000-firmware-39.31.5.1-143.el9.noarch
    iwl105-firmware-18.168.6.1-143.el9.noarch
    iwl135-firmware-18.168.6.1-143.el9.noarch
    iwl2000-firmware-18.168.6.1-143.el9.noarch
    iwl2030-firmware-18.168.6.1-143.el9.noarch
    iwl3160-firmware-25.30.13.0-143.el9.noarch
    iwl5000-firmware-8.83.5.1_1-143.el9.noarch
    iwl5150-firmware-8.24.2.2-143.el9.noarch
    iwl6000g2a-firmware-18.168.6.1-143.el9.noarch
    iwl6050-firmware-41.28.5.1-143.el9.noarch
    iwl7260-firmware-25.30.13.0-143.el9.noarch
    rootfiles-8.1-31.el9.noarch
    gpg-pubkey-fd431d51-4ae0493b
    gpg-pubkey-5a6340b3-6229229e
    wget-1.21.1-7.el9.x86_64
    libgcc-11.3.1-4.3.el9.x86_64
    glibc-common-2.34-60.el9.x86_64
    glibc-gconv-extra-2.34-60.el9.x86_64
    glibc-langpack-en-2.34-60.el9.x86_64
    glibc-2.34-60.el9.x86_64
    libsepol-3.5-1.el9.x86_64
    libuuid-2.37.4-10.el9.x86_64
    libblkid-2.37.4-10.el9.x86_64
    libstdc+±11.3.1-4.3.el9.x86_64
    libfdisk-2.37.4-10.el9.x86_64
    pcre2-syntax-10.40-2.el9.noarch
    pcre2-10.40-2.el9.x86_64
    libselinux-3.5-1.el9.x86_64
    libmount-2.37.4-10.el9.x86_64
    systemd-libs-252-13.el9_2.x86_64
    python3-libselinux-3.5-1.el9.x86_64
    libsemanage-3.5-1.el9.x86_64
    libffi-3.4.2-7.el9.x86_64
    libsmartcols-2.37.4-10.el9.x86_64
    util-linux-core-2.37.4-10.el9.x86_64
    util-linux-2.37.4-10.el9.x86_64
    glib2-2.68.4-6.el9.x86_64
    libffi-devel-3.4.2-7.el9.x86_64
    python3-libsemanage-3.5-1.el9.x86_64
    libselinux-utils-3.5-1.el9.x86_64
    policycoreutils-3.5-1.el9.x86_64
    python3-policycoreutils-3.5-1.el9.noarch
    pcre2-utf16-10.40-2.el9.x86_64
    pcre2-utf32-10.40-2.el9.x86_64
    pcre2-devel-10.40-2.el9.x86_64
    libstdc+±devel-11.3.1-4.3.el9.x86_64
    pcre-cpp-8.44-3.el9.3.x86_64
    libblkid-devel-2.37.4-10.el9.x86_64
    libsepol-devel-3.5-1.el9.x86_64
    libselinux-devel-3.5-1.el9.x86_64
    libmount-devel-2.37.4-10.el9.x86_64
    cpp-11.3.1-4.3.el9.x86_64
    glibc-headers-2.34-60.el9.x86_64
    glibc-devel-2.34-60.el9.x86_64
    libgomp-11.3.1-4.3.el9.x86_64
    numactl-libs-2.0.14-9.el9.x86_64
    pcre-utf16-8.44-3.el9.3.x86_64
    pcre-utf32-8.44-3.el9.3.x86_64
    pcre-devel-8.44-3.el9.3.x86_64
    libtirpc-1.3.3-1.el9.x86_64
    sysprof-capture-devel-3.40.1-3.el9.x86_64
    systemd-rpm-macros-252-13.el9_2.noarch
    systemd-pam-252-13.el9_2.x86_64
    systemd-252-13.el9_2.x86_64
    libgcc-11.3.1-4.3.el9.i686
    systemd-udev-252-13.el9_2.x86_64
    systemd-devel-252-13.el9_2.x86_64
    glib2-devel-2.68.4-6.el9.x86_64
    lsof-4.94.0-3.el9.x86_64
    numactl-devel-2.0.14-9.el9.x86_64
    gcc-c+±11.3.1-4.3.el9.x86_64
    gcc-plugin-annobin-11.3.1-4.3.el9.x86_64
    policycoreutils-python-utils-3.5-1.el9.noarch
    glibc-gconv-extra-2.34-60.el9.i686
    glibc-2.34-60.el9.i686
    libnl3-3.7.0-1.el9.i686
    libnl3-cli-3.7.0-1.el9.i686
    libnl3-devel-3.7.0-1.el9.x86_64
    tcl-8.6.10-7.el9.x86_64
    cmake-rpm-macros-3.20.2-8.el9.noarch
    cmake-filesystem-3.20.2-8.el9.x86_64
    vim-filesystem-8.2.2637-20.el9_1.noarch
    libuv-1.42.0-1.el9.x86_64
    ncurses-base-6.2-8.20210508.el9.noarch
    ncurses-libs-6.2-8.20210508.el9.x86_64
    cmake-data-3.20.2-8.el9.noarch
    cmake-3.20.2-8.el9.x86_64
    ncurses-c+±libs-6.2-8.20210508.el9.x86_64
    ncurses-devel-6.2-8.20210508.el9.x86_64
    ncurses-6.2-8.20210508.el9.x86_64
    tcl-devel-8.6.10-7.el9.x86_64
    tk-8.6.10-9.el9.x86_64
    python-srpm-macros-3.9-52.el9.noarch
    python-rpm-macros-3.9-52.el9.noarch
    python3-rpm-macros-3.9-52.el9.noarch
    python3-pip-wheel-21.2.3-6.el9.noarch
    python3-libs-3.9.16-1.el9.x86_64
    python3-tkinter-3.9.16-1.el9.x86_64
    python3-3.9.16-1.el9.x86_64
    python-unversioned-command-3.9.16-1.el9.noarch
    python3-pip-21.2.3-6.el9.noarch
    python3-pyparsing-2.4.7-9.el9.noarch
    python3-packaging-20.9-5.el9.noarch
    python3-rpm-generators-12-8.el9.noarch
    python3-devel-3.9.16-1.el9.x86_64
    vim-common-8.2.2637-20.el9_1.x86_64
    gpm-libs-1.20.7-29.el9.x86_64
    vim-enhanced-8.2.2637-20.el9_1.x86_64
    kernel-abi-stablelists-5.14.0-284.11.1.el9_2.noarch
    kernel-rpm-macros-185-12.el9.noarch
    ice-1.14.11-1.x86_64
    ninja-build-1.10.2-6.el9.x86_64
    python3-docutils-0.16-6.el9.noarch
    python3-Cython-0.29.22-7.el9.x86_64
    gpg-pubkey-3228467c-613798eb
    pandoc-common-2.14.0.3-17.el9.noarch
    pandoc-2.14.0.3-17.el9.x86_64
    infiniband-diags-compat-51.0-11432.el9.x86_64
    srp_daemon-51.0-11432.el9.x86_64
    iwpmd-51.0-11432.el9.x86_64
    fakeroot-libs-1.36-1.el9.x86_64
    fakeroot-1.36-1.el9.x86_64
    bc-1.07.1-14.el9.x86_64
    xorg-x11-proto-devel-2021.4-2.el9.noarch
    kernel-modules-core-5.14.0-284.11.1.el9_2.x86_64
    kernel-core-5.14.0-284.11.1.el9_2.x86_64
    libquadmath-11.3.1-4.3.el9.x86_64
    libxml2-2.9.13-3.el9_1.x86_64
    harfbuzz-2.7.4-8.el9.x86_64
    harfbuzz-icu-2.7.4-8.el9.x86_64
    createrepo_c-libs-0.20.1-1.el9.x86_64
    libxml2-devel-2.9.13-3.el9_1.x86_64
    libquadmath-devel-11.3.1-4.3.el9.x86_64
    libgfortran-11.3.1-4.3.el9.x86_64
    kernel-modules-5.14.0-284.11.1.el9_2.x86_64
    libXau-devel-1.0.9-8.el9.x86_64
    libxcb-devel-1.13.1-9.el9.x86_64
    libpng-devel-1.6.37-12.el9.x86_64
    libicu-devel-67.1-9.el9.x86_64
    graphite2-devel-1.3.14-9.el9.x86_64
    bzip2-devel-1.0.8-8.el9.x86_64
    brotli-devel-1.0.9-6.el9.x86_64
    freetype-devel-2.10.4-9.el9.x86_64
    harfbuzz-devel-2.7.4-8.el9.x86_64
    fontconfig-devel-2.14.0-2.el9_1.x86_64
    python3-dnf-plugins-core-4.3.0-5.el9_2.noarch
    libX11-xcb-1.7.0-7.el9.x86_64
    libX11-1.7.0-7.el9.x86_64
    libX11-devel-1.7.0-7.el9.x86_64
    libXrender-devel-0.9.10-16.el9.x86_64
    libXft-devel-2.3.3-8.el9.x86_64
    tk-devel-8.6.10-9.el9.x86_64
    yum-utils-4.3.0-5.el9_2.noarch
    kernel-modules-extra-5.14.0-284.11.1.el9_2.x86_64
    gcc-gfortran-11.3.1-4.3.el9.x86_64
    createrepo_c-0.20.1-1.el9.x86_64
    tcsh-6.22.03-6.el9.x86_64
    perl-meta-notation-5.32.1-480.el9.noarch
    perl-sigtrap-1.09-480.el9.noarch
    libibverbs-2410mlnx54-1.2410068.x86_64
    ucx-1.18.0-1.2410068.x86_64
    libibumad-2410mlnx54-1.2410068.x86_64
    librdmacm-2410mlnx54-1.2410068.x86_64
    infiniband-diags-2410mlnx54-1.2410068.x86_64
    ucx-ib-1.18.0-1.2410068.x86_64
    libxpmem-2.7.4-1.2410068.rhel9u4.x86_64
    sharp-3.9.0.MLNX20241029.7a20b607-1.2410068.x86_64
    hcoll-4.8.3230-1.2410068.x86_64
    openmpi-4.1.7rc1-1.2410068.x86_64
    opensm-libs-5.21.0.MLNX20241126.d9aa3dff-0.1.2410114.x86_64
    mlnx-tools-24.10-0.2410068.x86_64
    mlnx-ofa_kernel-24.10-OFED.24.10.1.1.4.1.rhel9u4.x86_64
    opensm-5.21.0.MLNX20241126.d9aa3dff-0.1.2410114.x86_64
    mpitests_openmpi-3.2.24-2ffc2d6.2410068.x86_64
    ucx-xpmem-1.18.0-1.2410068.x86_64
    ucx-ib-mlx5-1.18.0-1.2410068.x86_64
    ucx-rdmacm-1.18.0-1.2410068.x86_64
    rdma-core-devel-2410mlnx54-1.2410068.x86_64
    librdmacm-utils-2410mlnx54-1.2410068.x86_64
    perftest-24.10.0-0.65.g9093bae.2410068.x86_64
    ibacm-2410mlnx54-1.2410068.x86_64
    ibutils2-2.1.1-0.21902.MLNX20241029.g46cf6278.2410068.x86_64
    ucx-cma-1.18.0-1.2410068.x86_64
    ucx-devel-1.18.0-1.2410068.x86_64
    ucx-knem-1.18.0-1.2410068.x86_64
    ibdump-6.0.0-1.2410068.x86_64
    libibverbs-utils-2410mlnx54-1.2410068.x86_64
    rdma-core-2410mlnx54-1.2410068.x86_64
    ofed-scripts-24.10-OFED.24.10.1.1.4.x86_64
    mlnxofed-docs-24.10-1.1.4.0.noarch
    mlnx-ofa_kernel-devel-24.10-OFED.24.10.1.1.4.1.rhel9u4.x86_64
    mlnx-iproute2-6.10.0-1.2410114.x86_64
    mlnx-ethtool-6.9-1.2410068.x86_64
    mft-4.30.1-8.x86_64
    fwctl-debugsource-24.10-OFED.24.10.1.1.4.1.kver.6.6.74.x86_64
    srp-debugsource-24.10-OFED.24.10.1.1.4.1.kver.6.6.74.x86_64
    mlnx-ofa_kernel-debugsource-24.10-OFED.24.10.1.1.4.1.rhel9u4.x86_64
    mlnx-nvme-debugsource-24.10-OFED.24.10.1.1.4.1.kver.6.6.74.x86_64
    isert-debugsource-24.10-OFED.24.10.1.1.4.1.kver.6.6.74.x86_64
    iser-debugsource-24.10-OFED.24.10.1.1.4.1.kver.6.6.74.x86_64
    ---------------- END OF DEBUG INFO -------------------
Hi
Please refer MLNX_OFED release note about supported OS.
Thanks,
