After compiling I try to execute the code but i get this error:
OpenCV Error: Unspecified error (The function is not implemented.
Rebuild the library with Windows, GTK+ 2.x or Carbon support.
If you are on Ubuntu or Debian, install libgtk2.0-dev and pkg-config,
then re-run cmake or configure script) in cvNamedWindow,
file /hdd/buildbot/slaves/slave_jetson_tk1/52-O4T-L4T/opencv/modules/highgui/src/window.cpp,
line 483
terminate called after throwing an instance of 'cv::Exception'
what(): /hdd/buildbot/slaves/slave_jetson_tk1/52-O4T-L4T/opencv/modules/highgui/src/window.cpp:483: error: (-2)
The function is not implemented. Rebuild the library with Windows, GTK+ 2.x or Carbon support.
If you are on Ubuntu or Debian, install libgtk2.0-dev and pkg-config, then re-run cmake or configure script in function cvNamedWindow
What is this? What can I do?
