I’m using an Action Recognition model trained in TAO. not getting the same results as in TAO.
I want to validate the preprocess images sent to the Action recognition.
getting error:
/dvs/git/dirty/git-master_linux/nvutils/nvbufsurftransform/nvbufsurftransform.cpp:4339: => Surface type not supported for transformation NVBUF_MEM_CUDA_UNIFIED
compiled makefile WITH_OPENCV:=1
and set define DUMP_ROIS
Hi @fanzh ,
I use custom code. but for simplicity, I also tried now the original deepstream-3d-action-recognition sample with the same results (on OrinAGX):
./deepstream-3d-action-recognition -c deepstream_action_recognition_config.txt
num-sources = 4
Now playing: file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_walk.mov, file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_ride_bike.mov, file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_run.mov, file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_push.mov,
0:00:00.118756256 3059496 0xaaab00917a70 WARN nvinfer gstnvinfer.cpp:887:gst_nvinfer_start:<primary-nvinference-engine> warning: NvInfer output-tensor-meta is enabled but init_params auto increase memory (auto-inc-mem) is disabled. The bufferpool will not be automatically resized.
0:00:02.132655968 3059496 0xaaab00917a70 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1988> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-6.3/sources/apps/sample_apps/deepstream-3d-action-recognition/resnet18_3d_rgb_hmdb5_32.etlt_b4_gpu0_fp16.engine
INFO: [FullDims Engine Info]: layers num: 2
0 INPUT kFLOAT input_rgb 3x32x224x224 min: 1x3x32x224x224 opt: 4x3x32x224x224 Max: 4x3x32x224x224
1 OUTPUT kFLOAT fc_pred 5 min: 0 opt: 0 Max: 0
0:00:02.274426944 3059496 0xaaab00917a70 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2091> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-6.3/sources/apps/sample_apps/deepstream-3d-action-recognition/resnet18_3d_rgb_hmdb5_32.etlt_b4_gpu0_fp16.engine
0:00:02.294572064 3059496 0xaaab00917a70 INFO nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus:<primary-nvinference-engine> [UID 1]: Load new model:config_infer_primary_3d_action.txt sucessfully
/dvs/git/dirty/git-master_linux/deepstream/sdk/apps/deepstream/sample_apps/deepstream-3d-action-recognition/custom_sequence_preprocess/sequence_image_process.cpp:494, [INFO: CUSTOM_LIB] 3D custom sequence network info(NCSHW), [N: 4, C: 3, S: 32, H: 224, W:224]
/dvs/git/dirty/git-master_linux/deepstream/sdk/apps/deepstream/sample_apps/deepstream-3d-action-recognition/custom_sequence_preprocess/sequence_image_process.cpp:522, [INFO: CUSTOM_LIB] Sequence preprocess buffer manager initialized with stride: 1, subsample: 0
/dvs/git/dirty/git-master_linux/deepstream/sdk/apps/deepstream/sample_apps/deepstream-3d-action-recognition/custom_sequence_preprocess/sequence_image_process.cpp:526, [INFO: CUSTOM_LIB] SequenceImagePreprocess initialized successfully
Using user provided processing height = 224 and processing width = 224
Decodebin child added: source
Decodebin child added: decodebin0
Decodebin child added: decodebin1
Decodebin child added: decodebin2
Decodebin child added: decodebin3
Running...
WARNING from element primary-nvinference-engine: NvInfer output-tensor-meta is enabled but init_params auto increase memory (auto-inc-mem) is disabled. The bufferpool will not be automatically resized.
Warning: NvInfer output-tensor-meta is enabled but init_params auto increase memory (auto-inc-mem) is disabled. The bufferpool will not be automatically resized.
Decodebin child added: qtdemux0
Decodebin child added: qtdemux1
Decodebin child added: qtdemux2
Decodebin child added: qtdemux3
Decodebin child added: multiqueue0
Decodebin child added: multiqueue1
Decodebin child added: multiqueue2
Decodebin child added: multiqueue3
Decodebin child added: h264parse0
Decodebin child added: h264parse1
Decodebin child added: h264parse2
Decodebin child added: capsfilter1
Decodebin child added: capsfilter0
Decodebin child added: capsfilter2
Decodebin child added: h264parse3
Decodebin child added: capsfilter3
Decodebin child added: aacparse0
Decodebin child added: aacparse1
Decodebin child added: aacparse2
Decodebin child added: aacparse3
Decodebin child added: faad2
Decodebin child added: faad0
Decodebin child added: faad3
Decodebin child added: faad1
Decodebin child added: nvv4l2decoder0
Decodebin child added: nvv4l2decoder3
Decodebin child added: nvv4l2decoder1
Decodebin child added: nvv4l2decoder2
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 261
NvMMLiteBlockCreate : Block : BlockType = 261
In cb_newpad
In cb_newpad
In cb_newpad
In cb_newpad
In cb_newpad
In cb_newpad
In cb_newpad
In cb_newpad
0:00:02.785967680 3059496 0xaaab0009eaa0 ERROR nvdspreprocess gstnvdspreprocess.cpp:1156:batch_transformation: NvBufSurfTransform failed with error -1
ERROR from element preprocess-plugin: Transformation from plugin failed with error
Error details: gstnvdspreprocess.cpp(1282): group_transformation (): /GstPipeline:preprocess-test-pipeline/GstNvDsPreProcess:preprocess-plugin
Returned, stopping playback
/dvs/git/dirty/git-master_linux/deepstream/sdk/apps/deepstream/sample_apps/deepstream-3d-action-recognition/custom_sequence_preprocess/sequence_image_process.cpp:586, [INFO: CUSTOM_LIB] SequenceImagePreprocess is deinitializing
Deleting pipeline
when compiling preprocess with WITH_OPENCV:=0 and without DUMP_ROI runs ok.
thanks for the sharing! from the error “Surface type not supported for transformation NVBUF_MEM_CUDA_UNIFIED”, it is related with memorytype. can you try
allocator_info.memory_type = NVBUF_MEM_DEFAULT; instead of allocator_info.memory_type = NVBUF_MEM_CUDA_UNIFIED in opt\nvidia\deepstream\deepstream\sources\gst-plugins\gst-nvdspreprocess\gstnvdspreprocess.cpp? especially you need to rebuild and replace libnvdsgst_preprocess.so.
Thanks for the sharing! I can reproduce this issue on Orin with DS6.4. some images were saved from different parts of different sources or the same sources from different frame numbers. we are investigating.
sorry for the late reply. here is the reason for sources mixing issue.
deepstream-3d-action-recognition did not set custom-input-transformation-function in configuration. the default transformation of nvpreprocess plugin is using NvBufSurfTransformAsync to do buffertransform. NvBufSurfTransformAsync is async function. we need to dump data after NvBufSurfTransformSyncObjWait ending.
here is a workaround.
delete
gboolean ret = dump_rois(nvdspreprocess, batch.get(), memory->surf);
