Hello, I have been trying for the past week to get a Tesla K80 setup on Ubuntu 20.04 To use with OpenCV DNN.
I am able to get the drivers for the card installed and running: nvidia-smi shows Tesla K80 4 times (I have 2 cards installed). When building OpenCV, I see the Cuda is enabled (YES) however DNN is not. I see the the “backend” is not built, but as soon as I attempt to install the Cuda-Toolkit, the machiene will no longer be able to see the cards nvidia-smi. And the OpenCV Build still says NO for DNN. I am banging my head against the wall trying to figure this one out. Would anyone please give me a hint???
Here is a more complete output:
:~/opencv/build$ cmake -D CMAKE_BUILD_TYPE=RELEASE -D CMAKE_INSTALL_PREFIX=/usr/local -D WITH_CUDA=ON -D WITH_CUDNN=ON -D WITH_CUBLAS=ON -D WITH_TBB=ON -D OPENCV_DNN_CUDA=ON -D OPENCV_ENABLE_NONFREE=ON -D CUDA_ARCH_BIN=3.7 -D OPENCV_EXTRA_MODULES_PATH=$HOME/opencv_contrib/modules -D BUILD_EXAMPLES=OFF -D HAVE_opencv_python3=ON ..
-- Detected processor: x86_64
-- Could NOT find PythonInterp (missing: PYTHON_EXECUTABLE) (Required is at least version "2.7")
-- Looking for ccache - not found
-- Found ZLIB: /usr/lib/x86_64-linux-gnu/libz.so (found suitable version "1.2.11", minimum required is "1.2.3")
Cleaning INTERNAL cached variable: WEBP_LIBRARY
Cleaning INTERNAL cached variable: WEBP_INCLUDE_DIR
-- Could NOT find OpenJPEG (minimal suitable version: 2.0, recommended version >= 2.3.1). OpenJPEG will be built from sources
-- OpenJPEG: VERSION = 2.4.0, BUILD = opencv-4.6.0-dev-openjp2-2.4.0
-- OpenJPEG libraries will be built from sources: libopenjp2 (version "2.4.0")
-- Found ZLIB: /usr/lib/x86_64-linux-gnu/libz.so (found version "1.2.11")
-- libva: missing va.h header (VA_INCLUDE_DIR)
-- found Intel IPP (ICV version): 2020.0.0 [2020.0.0 Gold]
-- at: /home/kevin/opencv/build/3rdparty/ippicv/ippicv_lnx/icv
-- found Intel IPP Integration Wrappers sources: 2020.0.0
-- at: /home/kevin/opencv/build/3rdparty/ippicv/ippicv_lnx/iw
-- Could NOT find CUDNN (missing: CUDNN_LIBRARY CUDNN_INCLUDE_DIR) (Required is at least version "7.5")
-- CUDA detected: 11.7
-- CUDA: Using CUDA_ARCH_BIN=3.7
-- CUDA NVCC target flags: -gencode;arch=compute_37,code=sm_37;-D_FORCE_INLINES
-- Could not find OpenBLAS include. Turning OpenBLAS_FOUND off
-- Could not find OpenBLAS lib. Turning OpenBLAS_FOUND off
-- Could NOT find Atlas (missing: Atlas_CBLAS_INCLUDE_DIR Atlas_CLAPACK_INCLUDE_DIR Atlas_CBLAS_LIBRARY Atlas_BLAS_LIBRARY Atlas_LAPACK_LIBRARY)
-- Could NOT find BLAS (missing: BLAS_LIBRARIES)
-- Could NOT find LAPACK (missing: LAPACK_LIBRARIES)
Reason given by package: LAPACK could not be found because dependency BLAS could not be found.
-- Could NOT find JNI (missing: JAVA_INCLUDE_PATH JAVA_INCLUDE_PATH2 JAVA_AWT_INCLUDE_PATH)
-- VTK is not found. Please set -DVTK_DIR in CMake to VTK build directory, or to VTK install subdirectory with VTKConfig.cmake file
-- Checking for module 'gtk+-3.0'
-- No package 'gtk+-3.0' found
-- Checking for module 'gtk+-2.0'
-- No package 'gtk+-2.0' found
-- Checking for modules 'libavcodec;libavformat;libavutil;libswscale'
-- No package 'libavcodec' found
-- No package 'libavformat' found
-- No package 'libavutil' found
-- No package 'libswscale' found
-- FFMPEG is disabled. Required libraries: libavcodec;libavformat;libavutil;libswscale. Missing libraries: libavcodec;libavformat;libavutil;libswscale
-- Checking for module 'libdc1394-2'
-- No package 'libdc1394-2' found
-- Module opencv_alphamat disabled because the following dependencies are not found: Eigen
-- Checking for module 'freetype2'
-- No package 'freetype2' found
-- Checking for module 'harfbuzz'
-- No package 'harfbuzz' found
-- freetype2: NO
-- harfbuzz: NO
-- Could NOT find HDF5 (missing: HDF5_LIBRARIES HDF5_INCLUDE_DIRS) (found version "")
-- Julia not found. Not compiling Julia Bindings.
-- Module opencv_ovis disabled because OGRE3D was not found
-- No preference for use of exported gflags CMake configuration set, and no hints for include/library directories provided. Defaulting to preferring an installed/exported gflags CMake configuration if available.
-- Failed to find installed gflags CMake configuration, searching for gflags build directories exported with CMake.
-- Failed to find gflags - Failed to find an installed/exported CMake configuration for gflags, will perform search for installed gflags components.
-- Failed to find gflags - Could not find gflags include directory, set GFLAGS_INCLUDE_DIR to directory containing gflags/gflags.h
-- Failed to find glog - Could not find glog include directory, set GLOG_INCLUDE_DIR to directory containing glog/logging.h
-- Module opencv_sfm disabled because the following dependencies are not found: Eigen Glog/Gflags
-- Checking for module 'tesseract'
-- No package 'tesseract' found
-- Tesseract: NO
-- Allocator metrics storage type: 'long long'
CMake Error at modules/dnn/CMakeLists.txt:45 (message):
DNN: CUDA backend requires cuDNN. Please resolve dependency or disable
OPENCV_DNN_CUDA=OFF
-- Registering hook 'INIT_MODULE_SOURCES_opencv_dnn': /home/kevin/opencv/modules/dnn/cmake/hooks/INIT_MODULE_SOURCES_opencv_dnn.cmake
-- opencv_dnn: filter out cuda4dnn source code
-- Excluding from source files list: <BUILD>/modules/dnn/layers/layers_common.rvv.cpp
-- imgcodecs: OpenEXR codec is disabled in runtime. Details: https://github.com/opencv/opencv/issues/21326
-- highgui: using builtin backend: NONE
-- rgbd: Eigen support is disabled. Eigen is Required for Posegraph optimization
-- Building with NVIDIA Optical Flow API 2.0
-- Found 'misc' Python modules from /home/kevin/opencv/modules/python/package/extra_modules
-- Found 'mat_wrapper;utils' Python modules from /home/kevin/opencv/modules/core/misc/python/package
-- Found 'gapi' Python modules from /home/kevin/opencv/modules/gapi/misc/python/package
-- General configuration for OpenCV 4.6.0-dev =====================================
-- Version control: 4.6.0-50-g139c443770
-- Extra modules:
-- Location (extra): /home/kevin/opencv_contrib/modules
-- Version control (extra): 4.6.0-16-g9d0a451b
-- Platform:
-- Timestamp: 2022-07-10T23:11:26Z
-- Host: Linux 5.15.0-40-generic x86_64
-- CMake: 3.22.1
-- CMake generator: Unix Makefiles
-- CMake build tool: /usr/bin/gmake
-- Configuration: RELEASE
-- CPU/HW features:
-- Baseline: SSE SSE2 SSE3
-- requested: SSE3
-- Dispatched code generation: SSE4_1 SSE4_2 FP16 AVX AVX2 AVX512_SKX
-- requested: SSE4_1 SSE4_2 AVX FP16 AVX2 AVX512_SKX
-- SSE4_1 (18 files): + SSSE3 SSE4_1
-- SSE4_2 (2 files): + SSSE3 SSE4_1 POPCNT SSE4_2
-- FP16 (1 files): + SSSE3 SSE4_1 POPCNT SSE4_2 FP16 AVX
-- AVX (5 files): + SSSE3 SSE4_1 POPCNT SSE4_2 AVX
-- AVX2 (34 files): + SSSE3 SSE4_1 POPCNT SSE4_2 FP16 FMA3 AVX AVX2
-- AVX512_SKX (8 files): + SSSE3 SSE4_1 POPCNT SSE4_2 FP16 FMA3 AVX AVX2 AVX_512F AVX512_COMMON AVX512_SKX
-- C/C++:
-- Built as dynamic libs?: YES
-- C++ standard: 11
-- C++ Compiler: /usr/bin/c++ (ver 11.2.0)
-- C++ flags (Release): -fsigned-char -W -Wall -Wreturn-type -Wnon-virtual-dtor -Waddress -Wsequence-point -Wformat -Wformat-security -Wmissing-declarations -Wundef -Winit-self -Wpointer-arith -Wshadow -Wsign-promo -Wuninitialized -Wsuggest-override -Wno-delete-non-virtual-dtor -Wno-comment -Wimplicit-fallthrough=3 -Wno-strict-overflow -fdiagnostics-show-option -Wno-long-long -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections -msse -msse2 -msse3 -fvisibility=hidden -fvisibility-inlines-hidden -O3 -DNDEBUG -DNDEBUG
-- C++ flags (Debug): -fsigned-char -W -Wall -Wreturn-type -Wnon-virtual-dtor -Waddress -Wsequence-point -Wformat -Wformat-security -Wmissing-declarations -Wundef -Winit-self -Wpointer-arith -Wshadow -Wsign-promo -Wuninitialized -Wsuggest-override -Wno-delete-non-virtual-dtor -Wno-comment -Wimplicit-fallthrough=3 -Wno-strict-overflow -fdiagnostics-show-option -Wno-long-long -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections -msse -msse2 -msse3 -fvisibility=hidden -fvisibility-inlines-hidden -g -O0 -DDEBUG -D_DEBUG
-- C Compiler: /usr/bin/cc
-- C flags (Release): -fsigned-char -W -Wall -Wreturn-type -Waddress -Wsequence-point -Wformat -Wformat-security -Wmissing-declarations -Wmissing-prototypes -Wstrict-prototypes -Wundef -Winit-self -Wpointer-arith -Wshadow -Wuninitialized -Wno-comment -Wimplicit-fallthrough=3 -Wno-strict-overflow -fdiagnostics-show-option -Wno-long-long -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections -msse -msse2 -msse3 -fvisibility=hidden -O3 -DNDEBUG -DNDEBUG
-- C flags (Debug): -fsigned-char -W -Wall -Wreturn-type -Waddress -Wsequence-point -Wformat -Wformat-security -Wmissing-declarations -Wmissing-prototypes -Wstrict-prototypes -Wundef -Winit-self -Wpointer-arith -Wshadow -Wuninitialized -Wno-comment -Wimplicit-fallthrough=3 -Wno-strict-overflow -fdiagnostics-show-option -Wno-long-long -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections -msse -msse2 -msse3 -fvisibility=hidden -g -O0 -DDEBUG -D_DEBUG
-- Linker flags (Release): -Wl,--exclude-libs,libippicv.a -Wl,--exclude-libs,libippiw.a -Wl,--gc-sections -Wl,--as-needed -Wl,--no-undefined
-- Linker flags (Debug): -Wl,--exclude-libs,libippicv.a -Wl,--exclude-libs,libippiw.a -Wl,--gc-sections -Wl,--as-needed -Wl,--no-undefined
-- ccache: NO
-- Precompiled headers: NO
-- Extra dependencies: dl m pthread rt cudart nppc nppial nppicc nppidei nppif nppig nppim nppist nppisu nppitc npps cublas cufft -L/usr/local/cuda/lib64
-- 3rdparty dependencies:
-- OpenCV modules:
-- To be built: aruco barcode bgsegm bioinspired calib3d ccalib core cudaarithm cudabgsegm cudacodec cudafeatures2d cudafilters cudaimgproc cudalegacy cudaobjdetect cudaoptflow cudastereo cudawarping cudev datasets dnn dnn_objdetect dnn_superres dpm face features2d flann fuzzy gapi hfs highgui img_hash imgcodecs imgproc intensity_transform line_descriptor mcc ml objdetect optflow phase_unwrapping photo plot python3 quality rapid reg rgbd saliency shape stereo stitching structured_light superres surface_matching text tracking ts video videoio videostab wechat_qrcode xfeatures2d ximgproc xobjdetect xphoto
-- Disabled: world
-- Disabled by dependency: -
-- Unavailable: alphamat cvv freetype hdf java julia matlab ovis python2 sfm viz
-- Applications: tests perf_tests apps
-- Documentation: NO
-- Non-free algorithms: YES
-- GUI: NONE
-- GTK+: NO
-- VTK support: NO
-- Media I/O:
-- ZLib: /usr/lib/x86_64-linux-gnu/libz.so (ver 1.2.11)
-- JPEG: /usr/lib/x86_64-linux-gnu/libjpeg.so (ver 80)
-- WEBP: build (ver encoder: 0x020f)
-- PNG: /usr/lib/x86_64-linux-gnu/libpng.so (ver 1.6.37)
-- TIFF: /usr/lib/x86_64-linux-gnu/libtiff.so (ver 42 / 4.3.0)
-- JPEG 2000: build (ver 2.4.0)
-- OpenEXR: build (ver 2.3.0)
-- HDR: YES
-- SUNRASTER: YES
-- PXM: YES
-- PFM: YES
-- Video I/O:
-- DC1394: NO
-- FFMPEG: NO
-- avcodec: NO
-- avformat: NO
-- avutil: NO
-- swscale: NO
-- avresample: NO
-- GStreamer: YES (1.20.1)
-- v4l/v4l2: YES (linux/videodev2.h)
-- Parallel framework: pthreads
-- Trace: YES (with Intel ITT)
-- Other third-party libraries:
-- Intel IPP: 2020.0.0 Gold [2020.0.0]
-- Intel IPP IW: sources (2020.0.0)
-- VA: NO
-- Lapack: NO
-- Eigen: NO
-- Custom HAL: NO
-- Protobuf: build (3.19.1)
-- NVIDIA CUDA: YES (ver 11.7, CUFFT CUBLAS)
-- NVIDIA GPU arch: 37
-- NVIDIA PTX archs:
-- cuDNN: NO
-- OpenCL: YES (no extra features)
-- Include path: /home/kevin/opencv/3rdparty/include/opencl/1.2
-- Link libraries: Dynamic load
-- Python 3:
-- Interpreter: /usr/bin/python3 (ver 3.10.4)
-- Libraries: /usr/lib/x86_64-linux-gnu/libpython3.10.so (ver 3.10.4)
-- numpy: /usr/lib/python3/dist-packages/numpy/core/include (ver 1.21.5)
-- install path: lib/python3.10/dist-packages/cv2/python-3.10
-- Python (for build): /usr/bin/python3
-- Java:
-- ant: NO
-- JNI: NO
-- Java wrappers: NO
-- Java tests: NO
-- Install to: /usr/local
-- Configuring incomplete, errors occurred!
See also "/home/kevin/opencv/build/CMakeFiles/CMakeOutput.log".
See also "/home/kevin/opencv/build/CMakeFiles/CMakeError.log".
Thank you so much!!!
-Kevin
