Here is the full log on terminal:
(rasa) jetson@ubuntu:~/Python_env$ env H5PY_SETUP_REQUIRES=0 python3 -m pip install -U h5py==3.1.0
Collecting h5py==3.1.0
Using cached h5py-3.1.0.tar.gz (371 kB)
Installing build dependencies … done
Getting requirements to build wheel … done
Preparing metadata (pyproject.toml) … done
Requirement already satisfied: numpy>=1.12 in ./rasa/lib/python3.6/site-packages (from h5py==3.1.0) (1.19.4)
Collecting cached-property
Using cached cached_property-1.5.2-py2.py3-none-any.whl (7.6 kB)
Building wheels for collected packages: h5py
Building wheel for h5py (pyproject.toml) … error
ERROR: Command errored out with exit status 1:
command: /home/jetson/Python_env/rasa/bin/python3 /home/jetson/Python_env/rasa/lib/python3.6/site-packages/pip/_vendor/pep517/in_process/_in_process.py build_wheel /tmp/tmpj6ji0d0o
cwd: /tmp/pip-install-f6hsgnke/h5py_1a09bc87dcaa43b08417ea7f90508dd7
Complete output (105 lines):
running bdist_wheel
running build
running build_py
creating build
creating build/lib.linux-aarch64-3.6
creating build/lib.linux-aarch64-3.6/h5py
copying h5py/init.py → build/lib.linux-aarch64-3.6/h5py
copying h5py/version.py → build/lib.linux-aarch64-3.6/h5py
copying h5py/h5py_warnings.py → build/lib.linux-aarch64-3.6/h5py
copying h5py/ipy_completer.py → build/lib.linux-aarch64-3.6/h5py
creating build/lib.linux-aarch64-3.6/h5py/_hl
copying h5py/_hl/init.py → build/lib.linux-aarch64-3.6/h5py/_hl
copying h5py/_hl/files.py → build/lib.linux-aarch64-3.6/h5py/_hl
copying h5py/_hl/selections2.py → build/lib.linux-aarch64-3.6/h5py/_hl
copying h5py/_hl/base.py → build/lib.linux-aarch64-3.6/h5py/_hl
copying h5py/_hl/datatype.py → build/lib.linux-aarch64-3.6/h5py/_hl
copying h5py/_hl/filters.py → build/lib.linux-aarch64-3.6/h5py/_hl
copying h5py/_hl/attrs.py → build/lib.linux-aarch64-3.6/h5py/_hl
copying h5py/_hl/dataset.py → build/lib.linux-aarch64-3.6/h5py/_hl
copying h5py/_hl/vds.py → build/lib.linux-aarch64-3.6/h5py/_hl
copying h5py/_hl/dims.py → build/lib.linux-aarch64-3.6/h5py/_hl
copying h5py/_hl/compat.py → build/lib.linux-aarch64-3.6/h5py/_hl
copying h5py/_hl/selections.py → build/lib.linux-aarch64-3.6/h5py/_hl
copying h5py/_hl/group.py → build/lib.linux-aarch64-3.6/h5py/_hl
creating build/lib.linux-aarch64-3.6/h5py/tests
copying h5py/tests/init.py → build/lib.linux-aarch64-3.6/h5py/tests
copying h5py/tests/test_group.py → build/lib.linux-aarch64-3.6/h5py/tests
copying h5py/tests/test_selections.py → build/lib.linux-aarch64-3.6/h5py/tests
copying h5py/tests/test_h5.py → build/lib.linux-aarch64-3.6/h5py/tests
copying h5py/tests/test_objects.py → build/lib.linux-aarch64-3.6/h5py/tests
copying h5py/tests/test_attrs_data.py → build/lib.linux-aarch64-3.6/h5py/tests
copying h5py/tests/test_h5t.py → build/lib.linux-aarch64-3.6/h5py/tests
copying h5py/tests/test_attribute_create.py → build/lib.linux-aarch64-3.6/h5py/tests
copying h5py/tests/test_slicing.py → build/lib.linux-aarch64-3.6/h5py/tests
copying h5py/tests/test_dataset_getitem.py → build/lib.linux-aarch64-3.6/h5py/tests
copying h5py/tests/test_file2.py → build/lib.linux-aarch64-3.6/h5py/tests
copying h5py/tests/test_dims_dimensionproxy.py → build/lib.linux-aarch64-3.6/h5py/tests
copying h5py/tests/test_base.py → build/lib.linux-aarch64-3.6/h5py/tests
copying h5py/tests/test_h5d_direct_chunk.py → build/lib.linux-aarch64-3.6/h5py/tests
copying h5py/tests/test_h5p.py → build/lib.linux-aarch64-3.6/h5py/tests
copying h5py/tests/test_h5pl.py → build/lib.linux-aarch64-3.6/h5py/tests
copying h5py/tests/test_dimension_scales.py → build/lib.linux-aarch64-3.6/h5py/tests
copying h5py/tests/common.py → build/lib.linux-aarch64-3.6/h5py/tests
copying h5py/tests/test_completions.py → build/lib.linux-aarch64-3.6/h5py/tests
copying h5py/tests/test_dtype.py → build/lib.linux-aarch64-3.6/h5py/tests
copying h5py/tests/test_filters.py → build/lib.linux-aarch64-3.6/h5py/tests
copying h5py/tests/test_file.py → build/lib.linux-aarch64-3.6/h5py/tests
copying h5py/tests/test_h5f.py → build/lib.linux-aarch64-3.6/h5py/tests
copying h5py/tests/test_attrs.py → build/lib.linux-aarch64-3.6/h5py/tests
copying h5py/tests/test_file_image.py → build/lib.linux-aarch64-3.6/h5py/tests
copying h5py/tests/test_dataset.py → build/lib.linux-aarch64-3.6/h5py/tests
copying h5py/tests/test_datatype.py → build/lib.linux-aarch64-3.6/h5py/tests
copying h5py/tests/conftest.py → build/lib.linux-aarch64-3.6/h5py/tests
copying h5py/tests/test_errors.py → build/lib.linux-aarch64-3.6/h5py/tests
copying h5py/tests/test_big_endian_file.py → build/lib.linux-aarch64-3.6/h5py/tests
copying h5py/tests/test_dataset_swmr.py → build/lib.linux-aarch64-3.6/h5py/tests
creating build/lib.linux-aarch64-3.6/h5py/tests/data_files
copying h5py/tests/data_files/init.py → build/lib.linux-aarch64-3.6/h5py/tests/data_files
creating build/lib.linux-aarch64-3.6/h5py/tests/test_vds
copying h5py/tests/test_vds/init.py → build/lib.linux-aarch64-3.6/h5py/tests/test_vds
copying h5py/tests/test_vds/test_virtual_source.py → build/lib.linux-aarch64-3.6/h5py/tests/test_vds
copying h5py/tests/test_vds/test_lowlevel_vds.py → build/lib.linux-aarch64-3.6/h5py/tests/test_vds
copying h5py/tests/test_vds/test_highlevel_vds.py → build/lib.linux-aarch64-3.6/h5py/tests/test_vds
copying h5py/tests/data_files/vlen_string_s390x.h5 → build/lib.linux-aarch64-3.6/h5py/tests/data_files
copying h5py/tests/data_files/vlen_string_dset.h5 → build/lib.linux-aarch64-3.6/h5py/tests/data_files
copying h5py/tests/data_files/vlen_string_dset_utc.h5 → build/lib.linux-aarch64-3.6/h5py/tests/data_files
running build_ext
File “/home/jetson/Python_env/rasa/lib/python3.6/site-packages/pip/_vendor/pep517/in_process/_in_process.py”, line 363, in
main()
File “/home/jetson/Python_env/rasa/lib/python3.6/site-packages/pip/_vendor/pep517/in_process/_in_process.py”, line 345, in main
json_out[‘return_val’] = hook(**hook_input[‘kwargs’])
File “/home/jetson/Python_env/rasa/lib/python3.6/site-packages/pip/_vendor/pep517/in_process/_in_process.py”, line 262, in build_wheel
metadata_directory)
File “/tmp/pip-build-env-94vb8xrz/overlay/lib/python3.6/site-packages/setuptools/build_meta.py”, line 231, in build_wheel
wheel_directory, config_settings)
File “/tmp/pip-build-env-94vb8xrz/overlay/lib/python3.6/site-packages/setuptools/build_meta.py”, line 215, in _build_with_temp_dir
self.run_setup()
File “/tmp/pip-build-env-94vb8xrz/overlay/lib/python3.6/site-packages/setuptools/build_meta.py”, line 158, in run_setup
exec(compile(code, file, ‘exec’), locals())
File “setup.py”, line 183, in
cmdclass = CMDCLASS,
File “/tmp/pip-build-env-94vb8xrz/overlay/lib/python3.6/site-packages/setuptools/init.py”, line 153, in setup
return distutils.core.setup(**attrs)
File “/usr/lib/python3.6/distutils/core.py”, line 148, in setup
dist.run_commands()
File “/usr/lib/python3.6/distutils/dist.py”, line 955, in run_commands
self.run_command(cmd)
File “/usr/lib/python3.6/distutils/dist.py”, line 974, in run_command
cmd_obj.run()
File “/tmp/pip-build-env-94vb8xrz/overlay/lib/python3.6/site-packages/wheel/bdist_wheel.py”, line 299, in run
self.run_command(‘build’)
File “/usr/lib/python3.6/distutils/cmd.py”, line 313, in run_command
self.distribution.run_command(command)
cmd_obj.run()
File “/usr/lib/python3.6/distutils/command/build.py”, line 135, in run
self.run_command(cmd_name)
cmd_obj.run()
File “/tmp/pip-install-f6hsgnke/h5py_1a09bc87dcaa43b08417ea7f90508dd7/setup_build.py”, line 121, in run
from Cython import version as cython_version
ModuleNotFoundError: No module named ‘Cython’
ERROR: Failed building wheel for h5py
Failed to build h5py
ERROR: Could not build wheels for h5py, which is required to install pyproject.toml-based projects
