I am following this guide in order to install Onnx2TensorRt: GitHub - onnx/onnx-tensorrt: ONNX-TensorRT: TensorRT backend for ONNX
I have done this:
cd onnx-tensorrt
mkdir build && cd build
cmake .. -DTENSORRT_ROOT=<path_to_trt> && make -j
// Ensure that you update your LD_LIBRARY_PATH to pick up the location of the newly built library:
export LD_LIBRARY_PATH=$PWD:$LD_LIBRARY_PATH
and the installation seems to be successful. But I am unable to run: onnx2rt which just return onnx2rt: command not found . What am I missing here?
tensorflow
It should be onnx2trt.
Could you give it a try?
I saw that I had not installed the actuall TensorRT package. But when I try to do it I end up with dependency problems:
sudo apt-get install tensorrt
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
tensorrt : Depends: libnvinfer-dev (= 7.2.3-1+cuda11.1) but 8.0.0-1+cuda11.3 is to be installed
Depends: libnvinfer-plugin-dev (= 7.2.3-1+cuda11.1) but 8.0.0-1+cuda11.3 is to be installed
Depends: libnvparsers-dev (= 7.2.3-1+cuda11.1) but 8.0.0-1+cuda11.3 is to be installed
Depends: libnvonnxparsers-dev (= 7.2.3-1+cuda11.1) but 8.0.0-1+cuda11.3 is to be installed
Depends: libnvinfer-samples (= 7.2.3-1+cuda11.1) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
I have downloaded nv-tensorrt-repo-ubuntu1804-cuda11.1-trt7.2.3.4-ga-20210226_1-1_amd64.deb and installed it along with libcudnn8_8.1.1.33-1+cuda11.2_amd64.deb and libcudnn8-dev_8.1.1.33-1+cuda11.2_amd64.deb
Then I have done this:
sudo apt-key add /var/nv-tensorrt-repo-ubuntu1804-cuda11.1-trt7.2.3.4-ga-20210226/7fa2af80.pub
What could the problem to this be?
Thanks for the support so far.
You will need an aarch64 package since Jetson is an ARM system.
Please find it from JetPack installer.
Since there are dependencies between CUDA libraries and GPU driver.
You will need to use the same JetPack version to flash and install the packages.
