Unable to locate package libopencv4tegra
I met a Problem that “Unable to locate package libopencv4tegra”
I met this problem when I run “sudo apt-get install libopencv4tegra”, when the atumatic installication failed in Jetpack which asked me to “sudo apt-get install libopencv4tegra”.
It seems that I had a bad “source.list” in “/etc/apt/” , so how can I fix this problem
Thanks for your reply
Hi Gehen,
What JetPack version are you install?
You can install “OpenCV for Tegra” via JetPack3.0 directly.
or you can try below command:
$ sudo add-apt-repository universe
$ sudo apt-get update
$ sudo apt-get install libopencv4tegra
Hi carolyuu,
This problem is solved by reinstall all via Jetpack 3.0, including file system .It seems that there is a dismatch between the pre-installed system on Jetson TX1 and the opencv4tegra.
