The below code is a modified code from GitHub - NVIDIA-AI-IOT/redaction_with_deepstream: An example of using DeepStream SDK for redaction
Here nvtracker is added in reference with deepstream test2 app
* Copyright (c) 2018, NVIDIA CORPORATION. All rights reserved.
* Permission is hereby granted, free of charge, to any person obtaining a
* copy of this software and associated documentation files (the "Software"),
* to deal in the Software without restriction, including without limitation
* the rights to use, copy, modify, merge, publish, distribute, sublicense,
* and/or sell copies of the Software, and to permit persons to whom the
* Software is furnished to do so, subject to the following conditions:
* The above copyright notice and this permission notice shall be included in
* all copies or substantial portions of the Software.
* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
* IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
* FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
* THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
* LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
* FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
* DEALINGS IN THE SOFTWARE.
#include <gst/gst.h>
#include <glib.h>
#include <stdio.h>
#include <string.h>
#include <time.h>
#include "gstnvdsmeta.h"
#define PLATFORM_TEGRA true;
/* Define global variables:
* `frame_number` & `pgie_classes_str` are used for writing meta to kitti;
* `pgie_config`,`input_mp4`,`output_mp4`,`output_kitti` are configurable file paths parsed through command line. */
clock_t t_start;
clock_t t_end;
#define MAX_DISPLAY_LEN 64
GstElement *pipeline, *video_full_processing_bin;
gint frame_number = 0;
gchar pgie_classes_str[4][32] = { "face", "license_plate", "make", "model" };
gchar *pgie_config = NULL;
gchar *input_mp4 = NULL;
gchar *output_mp4 = NULL;
gchar *output_kitti = NULL;
#define TRACKER_CONFIG_FILE "dstest2_tracker_config.txt"
/* initialize our gstreamer components for the app */
GMainLoop *loop = NULL;
GstElement *source = NULL, *decoder = NULL, *streammux = NULL,
*queue_pgie = NULL, *pgie = NULL, *nvvidconv_osd =
NULL, *osd = NULL, *queue_sink = NULL, *nvvidconv_sink =
NULL, *filter_sink = NULL, *videoconvert = NULL, *encoder = NULL, *muxer =
NULL, *sink = NULL, *nvvidconv_src = NULL, *vidconv_src=NULL, *filter_src=NULL, *nvtracker = NULL;
#ifdef PLATFORM_TEGRA
GstElement *transform = NULL;
#endif
GstBus *bus = NULL;
guint bus_watch_id;
GstCaps *caps_filter_osd = NULL, *caps_filter_sink = NULL, *caps_filter_src = NULL;
gulong osd_probe_id = 0;
GstPad *osd_sink_pad = NULL, *videopad = NULL;
/* osd_sink_pad_buffer_probe function will extract metadata received on OSD sink pad
* and then update params for drawing rectangle and write bbox to kitti file. */
#if 1
static GstPadProbeReturn
osd_sink_pad_buffer_probe (GstPad * pad, GstPadProbeInfo * info,
gpointer u_data)
GstBuffer *buf = (GstBuffer *) info->data;
NvDsObjectMeta *obj_meta = NULL;
NvDsMetaList * l_frame = NULL;
NvDsMetaList * l_obj = NULL;
NvDsBatchMeta *batch_meta = gst_buffer_get_nvds_batch_meta (buf);
FILE *bbox_params_dump_file = NULL;
gchar bbox_file[1024] = { 0 };
for (l_frame = batch_meta->frame_meta_list; l_frame != NULL;
l_frame = l_frame->next) {
NvDsFrameMeta *frame_meta = (NvDsFrameMeta *) (l_frame->data);
if (frame_meta == NULL) {
g_print ("NvDS Meta contained NULL meta \n");
frame_number++;
return GST_PAD_PROBE_OK;
if (output_kitti) {
g_snprintf (bbox_file, sizeof (bbox_file) - 1, "%s/%06d.txt",
output_kitti, frame_number);
bbox_params_dump_file = fopen (bbox_file, "w");
for (l_obj = frame_meta->obj_meta_list; l_obj != NULL;
l_obj = l_obj->next) {
obj_meta = (NvDsObjectMeta *) (l_obj->data);
NvOSD_RectParams * rect_params = &(obj_meta->rect_params);
NvOSD_TextParams * text_params = &(obj_meta->text_params);
g_print("Track_ID %d \n", obj_meta->object_id);
if (text_params->display_text) {
text_params->set_bg_clr = 0;
text_params->font_params.font_size = 0;
/* Draw black patch to cover license plates (class_id = 1) */
if (obj_meta->class_id == 1) {
rect_params->border_width = 0;
rect_params->has_bg_color = 1;
rect_params->bg_color.red = 0.0;
rect_params->bg_color.green = 0.0;
rect_params->bg_color.blue = 0.0;
rect_params->bg_color.alpha = 1.0;
/* Draw skin-color patch to cover faces (class_id = 0) */
if (obj_meta->class_id == 0) {
rect_params->bg_color.red = 0.92;
rect_params->bg_color.green = 0.75;
rect_params->bg_color.blue = 0.56;
if (bbox_params_dump_file) {
int left = (int) (rect_params->left);
int top = (int) (rect_params->top);
int right = left + (int) (rect_params->width);
int bottom = top + (int) (rect_params->height);
int class_index = obj_meta->class_id;
char *text = pgie_classes_str[obj_meta->class_id];
//char *text = "Face";
fprintf (bbox_params_dump_file,
"%s 0.0 0 0.0 %d.00 %d.00 %d.00 %d.00 0.0 0.0 0.0 0.0 0.0 0.0 0.0\n",
text, left, top, right, bottom);
fclose (bbox_params_dump_file);
frame_number++;
#endif // 0
#if 0
gpointer u_data)
guint num_rects = 0;
guint vehicle_count = 0;
guint person_count = 0;
NvDsDisplayMeta *display_meta = NULL;
int offset = 0;
vehicle_count++;
num_rects++;
person_count++;
num_rects++;
display_meta = nvds_acquire_display_meta_from_pool(batch_meta);
NvOSD_TextParams *txt_params = &display_meta->text_params[0];
display_meta->num_labels = 1;
txt_params->display_text = g_malloc0 (MAX_DISPLAY_LEN);
offset = snprintf(txt_params->display_text, MAX_DISPLAY_LEN, "Person = %d ", person_count);
offset = snprintf(txt_params->display_text + offset , MAX_DISPLAY_LEN, "Vehicle = %d ", vehicle_count);
/* Now set the offsets where the string should appear */
txt_params->x_offset = 10;
txt_params->y_offset = 12;
/* Font , font-color and font-size */
txt_params->font_params.font_name = "Serif";
txt_params->font_params.font_size = 10;
txt_params->font_params.font_color.red = 1.0;
txt_params->font_params.font_color.green = 1.0;
txt_params->font_params.font_color.blue = 1.0;
txt_params->font_params.font_color.alpha = 1.0;
/* Text background color */
txt_params->set_bg_clr = 1;
txt_params->text_bg_clr.red = 0.0;
txt_params->text_bg_clr.green = 0.0;
txt_params->text_bg_clr.blue = 0.0;
txt_params->text_bg_clr.alpha = 1.0;
nvds_add_display_meta_to_frame(frame_meta, display_meta);
g_print ("Frame Number = %d Number of objects = %d "
"Vehicle Count = %d Person Count = %d\n",
frame_number, num_rects, vehicle_count, person_count);
frame_number++;
#endif // 1
/* This bus callback function detects the error and state change in the main pipe
* and then export messages, export pipeline images or terminate the pipeline accordingly. */
static gboolean
bus_call (GstBus * bus, GstMessage * msg, gpointer data)
GMainLoop *loop = (GMainLoop *) data;
switch (GST_MESSAGE_TYPE (msg)) {
case GST_MESSAGE_EOS:
g_print ("End of stream\n");
t_end = clock();
clock_t t = t_end - t_start;
double time_taken = ((double)t)/CLOCKS_PER_SEC; // in seconds
double fps = frame_number/time_taken;
g_print("\nThe program took %.2f seconds to redact %d frames, pref = %.2f fps \n\n", time_taken,frame_number,fps);
g_main_loop_quit (loop);
break;
case GST_MESSAGE_ERROR:{
gchar *debug;
GError *error;
gst_message_parse_error (msg, &error, &debug);
g_printerr ("ERROR from element %s: %s\n",
GST_OBJECT_NAME (msg->src), error->message);
g_free (debug);
g_printerr ("Error: %s\n", error->message);
g_error_free (error);
break;
case GST_MESSAGE_STATE_CHANGED:{
GstState oldstate, newstate;
gst_message_parse_state_changed (msg, &oldstate, &newstate, NULL);
if (GST_ELEMENT (GST_MESSAGE_SRC (msg)) == pipeline) {
switch (newstate) {
case GST_STATE_PLAYING:
g_print ("Pipeline running\n");
GST_DEBUG_BIN_TO_DOT_FILE_WITH_TS (GST_BIN (pipeline),
GST_DEBUG_GRAPH_SHOW_ALL, "ds-app-playing");
t_start = clock();
break;
case GST_STATE_PAUSED:
if (oldstate == GST_STATE_PLAYING) {
g_print ("Pipeline paused\n");
break;
case GST_STATE_READY:
// GST_DEBUG_BIN_TO_DOT_FILE_WITH_TS (GST_BIN (pipeline), GST_DEBUG_GRAPH_SHOW_ALL,"ds-app-ready");
if (oldstate == GST_STATE_NULL) {
g_print ("Pipeline ready\n");
} else {
g_print ("Pipeline stopped\n");
break;
default:
break;
break;
default:
break;
return TRUE;
/* The callback function is called when the decoder_bin establishes video source from the input mp4 file,
* then connects the src pad to the following video_full_processing_bin.
* The connection is dynamic. */
static void
cb_newpad (GstElement * decodebin, GstPad * pad, gpointer data)
GstCaps *caps;
GstStructure *str;
GstPad *videopad;
/*only link once */
videopad = gst_element_get_static_pad (video_full_processing_bin, "sink");
if (GST_PAD_IS_LINKED (videopad)) {
g_object_unref (videopad);
return;
/* check media type */
caps = gst_pad_query_caps (pad, NULL);
str = gst_caps_get_structure (caps, 0);
if (!g_strrstr (gst_structure_get_name (str), "video")) {
gst_caps_unref (caps);
gst_object_unref (videopad);
return;
/* link’n’play */
gst_pad_link (pad, videopad);
/* Tracker config parsing */
#define CHECK_ERROR(error) \
if (error) { \
g_printerr ("Error while parsing config file: %s\n", error->message); \
goto done; \
#define CONFIG_GROUP_TRACKER "tracker"
#define CONFIG_GROUP_TRACKER_WIDTH "tracker-width"
#define CONFIG_GROUP_TRACKER_HEIGHT "tracker-height"
#define CONFIG_GROUP_TRACKER_LL_CONFIG_FILE "ll-config-file"
#define CONFIG_GROUP_TRACKER_LL_LIB_FILE "ll-lib-file"
#define CONFIG_GROUP_TRACKER_ENABLE_BATCH_PROCESS "enable-batch-process"
#define CONFIG_GPU_ID "gpu-id"
static gchar *
get_absolute_file_path (gchar *cfg_file_path, gchar *file_path)
gchar abs_cfg_path[PATH_MAX + 1];
gchar *abs_file_path;
gchar *delim;
if (file_path && file_path[0] == '/') {
return file_path;
if (!realpath (cfg_file_path, abs_cfg_path)) {
g_free (file_path);
return NULL;
// Return absolute path of config file if file_path is NULL.
if (!file_path) {
abs_file_path = g_strdup (abs_cfg_path);
return abs_file_path;
delim = g_strrstr (abs_cfg_path, "/");
*(delim + 1) = '\0';
abs_file_path = g_strconcat (abs_cfg_path, file_path, NULL);
g_free (file_path);
static gboolean
set_tracker_properties (GstElement *nvtracker)
gboolean ret = FALSE;
GError *error = NULL;
gchar **keys = NULL;
gchar **key = NULL;
GKeyFile *key_file = g_key_file_new ();
if (!g_key_file_load_from_file (key_file, TRACKER_CONFIG_FILE, G_KEY_FILE_NONE,
&error)) {
g_printerr ("Failed to load config file: %s\n", error->message);
return FALSE;
keys = g_key_file_get_keys (key_file, CONFIG_GROUP_TRACKER, NULL, &error);
CHECK_ERROR (error);
for (key = keys; *key; key++) {
if (!g_strcmp0 (*key, CONFIG_GROUP_TRACKER_WIDTH)) {
gint width =
g_key_file_get_integer (key_file, CONFIG_GROUP_TRACKER,
CONFIG_GROUP_TRACKER_WIDTH, &error);
g_object_set (G_OBJECT (nvtracker), "tracker-width", width, NULL);
} else if (!g_strcmp0 (*key, CONFIG_GROUP_TRACKER_HEIGHT)) {
gint height =
CONFIG_GROUP_TRACKER_HEIGHT, &error);
g_object_set (G_OBJECT (nvtracker), "tracker-height", height, NULL);
} else if (!g_strcmp0 (*key, CONFIG_GPU_ID)) {
guint gpu_id =
CONFIG_GPU_ID, &error);
g_object_set (G_OBJECT (nvtracker), "gpu_id", gpu_id, NULL);
} else if (!g_strcmp0 (*key, CONFIG_GROUP_TRACKER_LL_CONFIG_FILE)) {
char* ll_config_file = get_absolute_file_path (TRACKER_CONFIG_FILE,
g_key_file_get_string (key_file,
CONFIG_GROUP_TRACKER_LL_CONFIG_FILE, &error));
g_object_set (G_OBJECT (nvtracker), "ll-config-file", ll_config_file, NULL);
} else if (!g_strcmp0 (*key, CONFIG_GROUP_TRACKER_LL_LIB_FILE)) {
char* ll_lib_file = get_absolute_file_path (TRACKER_CONFIG_FILE,
CONFIG_GROUP_TRACKER_LL_LIB_FILE, &error));
g_object_set (G_OBJECT (nvtracker), "ll-lib-file", ll_lib_file, NULL);
} else if (!g_strcmp0 (*key, CONFIG_GROUP_TRACKER_ENABLE_BATCH_PROCESS)) {
gboolean enable_batch_process =
CONFIG_GROUP_TRACKER_ENABLE_BATCH_PROCESS, &error);
g_object_set (G_OBJECT (nvtracker), "enable_batch_process",
enable_batch_process, NULL);
} else {
g_printerr ("Unknown key '%s' for group [%s]", *key,
CONFIG_GROUP_TRACKER);
ret = TRUE;
done:
if (error) {
if (keys) {
g_strfreev (keys);
if (!ret) {
g_printerr ("%s failed", __func__);
return ret;
/* In the main function, we create elements, configure the elements, assemble to elements to pipe and run the pipe */
int
main (int argc, char *argv[])
/* initialize the app using GOption */
GOptionContext *ctx;
GError *err = NULL;
GOptionEntry entries[] = {
{"pgie_config", 'c', 0, G_OPTION_ARG_STRING, &pgie_config,
"(required) configuration file for the nvinfer detector (primary gie)",
NULL},
{"input_mp4", 'i', 0, G_OPTION_ARG_STRING, &input_mp4,
"(optional) path to input mp4 file. If this is unset then usb webcam will be used as input", NULL},
{"output_mp4", 'o', 0, G_OPTION_ARG_STRING, &output_mp4,
"(optional) path to output mp4 file. If this is unset then on-screen display will be used",
NULL},
{"output_kitti", 'k', 0, G_OPTION_ARG_STRING, &output_kitti,
"(optional) path to the folder for containing output kitti files. If this is unset or \
the path does not exist then app won't output kitti files",
NULL},
{NULL},
ctx =
g_option_context_new
("\n\n 'Fast Video Redaction App using NVIDIA Deepstream'\n \
contact: Shuo Wang (shuow@nvidia.com)");
g_option_context_add_main_entries (ctx, entries, NULL);
g_option_context_add_group (ctx, gst_init_get_option_group ());
if (!g_option_context_parse (ctx, &argc, &argv, &err)) {
g_print ("Failed to initialize: %s\n", err->message);
g_clear_error (&err);
g_option_context_free (ctx);
return 1;
/* Check input arguments */
if (!pgie_config) {
g_printerr ("missing pgie configuration file\n");
g_printerr ("run: %s --help for usage instruction\n", argv[0]);
return -1;
/* Create gstreamer loop */
loop = g_main_loop_new (NULL, FALSE);
/* Create gstreamer pipeline */
pipeline = gst_pipeline_new ("ds-redaction-pipeline");
/* Create components for the input source */
if (input_mp4) {
source = gst_element_factory_make ("filesrc", "file-source");
g_object_set (G_OBJECT (source), "location", input_mp4, NULL);
decoder = gst_element_factory_make ("decodebin", "decoder");
g_signal_connect (decoder, "pad-added", G_CALLBACK (cb_newpad), NULL);
gst_bin_add_many (GST_BIN (pipeline), source, decoder, NULL);
gst_element_link (source, decoder);
} else {
source = gst_element_factory_make ("v4l2src", "camera-source");
g_object_set (G_OBJECT (source), "device", "/dev/video0", NULL);
vidconv_src = gst_element_factory_make ("videoconvert", "vidconv_src");
nvvidconv_src = gst_element_factory_make ("nvvideoconvert", "nvvidconv_src");
filter_src = gst_element_factory_make ("capsfilter", "filter_src");
g_object_set (G_OBJECT (nvvidconv_src), "nvbuf-memory-type", 0, NULL);
caps_filter_src =
gst_caps_from_string ("video/x-raw(memory:NVMM), format=NV12, width=1280, height=720, framerate=30/1");
g_object_set (G_OBJECT (filter_src), "caps", caps_filter_src, NULL);
gst_caps_unref (caps_filter_src);
gst_bin_add_many (GST_BIN (pipeline), source, vidconv_src, nvvidconv_src, filter_src, NULL);
gst_element_link_many (source, vidconv_src, nvvidconv_src, filter_src, NULL);
/* Create main processing bin */
video_full_processing_bin = gst_bin_new ("video-process-bin");
/* Create nvstreammux instance to form batches from one or more sources. */
streammux = gst_element_factory_make ("nvstreammux", "stream-muxer");
g_object_set (G_OBJECT (streammux), "width", 1280, "height",
720, "batch-size", 1, "batched-push-timeout", 40000, NULL);
g_object_set (G_OBJECT (streammux), "nvbuf-memory-type", 0, NULL);
gchar pad_name_sink[16] = "sink_0";
videopad = gst_element_get_request_pad (streammux, pad_name_sink);
/* Use nvinfer to run inferencing on decoder's output,
* behaviour of inferencing is set through config file.
* Create components for the detection */
queue_pgie = gst_element_factory_make ("queue", "queue_pgie");
pgie = gst_element_factory_make ("nvinfer", "primary-nvinference-engine");
g_object_set (G_OBJECT (pgie), "config-file-path", pgie_config, NULL);
/* Use nvosd to render bbox/text on top of the input video.
* Create components for the rendering */
nvvidconv_osd = gst_element_factory_make ("nvvideoconvert", "nvvidconv_osd");
nvtracker = gst_element_factory_make ("nvtracker", "tracker");
osd = gst_element_factory_make ("nvdsosd", "nv-onscreendisplay");
/* Create components for the output */
if (output_mp4) {
/* If output file is set, then create components for encoding and exporting to mp4 file */
queue_sink = gst_element_factory_make ("queue", "queue_sink");
nvvidconv_sink = gst_element_factory_make ("nvvideoconvert", "nvvidconv_sink");
filter_sink = gst_element_factory_make ("capsfilter", "filter_sink");
caps_filter_sink = gst_caps_from_string ("video/x-raw, format=I420");
g_object_set (G_OBJECT (filter_sink), "caps", caps_filter_sink, NULL);
gst_caps_unref (caps_filter_sink);
videoconvert = gst_element_factory_make ("videoconvert", "videoconverter");
encoder = gst_element_factory_make ("avenc_mpeg4", "mp4-encoder");
g_object_set (G_OBJECT (encoder), "bitrate", 1000000, NULL);
muxer = gst_element_factory_make ("qtmux", "muxer");
sink = gst_element_factory_make ("filesink", "nvvideo-renderer");
g_object_set (G_OBJECT (sink), "location", output_mp4, NULL);
} else {
/* If output file is not set, use on-screen display as output */
transform = gst_element_factory_make ("nvegltransform", "nvegl-transform");
if(!transform) {
g_printerr ("One tegra element could not be created. Exiting.\n");
return -1;
sink = gst_element_factory_make ("nveglglessink", "nvvideo-renderer");
g_object_set (sink, "sync", FALSE, "max-lateness", -1,
"async", FALSE, "qos", TRUE, NULL);
#else
if (input_mp4) {
g_object_set (sink, "sync", TRUE, NULL);
#endif
/* Check all components */
if (!pipeline || !source || !video_full_processing_bin
|| !queue_pgie || !pgie || !nvvidconv_osd
|| !osd || !sink) {
g_printerr ("One element could not be created. Exiting.\n");
return -1;
/* we add a message handler */
bus = gst_pipeline_get_bus (GST_PIPELINE (pipeline));
bus_watch_id = gst_bus_add_watch (bus, bus_call, loop);
gst_object_unref (bus);
/* Set up the pipeline */
gst_bin_add_many (GST_BIN (video_full_processing_bin), streammux, nvtracker,
queue_pgie, pgie, nvvidconv_osd, osd, NULL);
/* link the elements together */
gst_element_link_many (streammux, queue_pgie, pgie, nvvidconv_osd, osd, nvtracker,
NULL);
gst_element_add_pad (video_full_processing_bin, gst_ghost_pad_new ("sink",
videopad));
gst_bin_add (GST_BIN (pipeline), video_full_processing_bin);
/* link soure and video_full_processing_bin */
if (!input_mp4){
GstPad *sinkpad, *srcpad;
sinkpad = gst_element_get_static_pad (video_full_processing_bin, "sink");
if (!sinkpad) {
g_printerr ("video_full_processing_bin request sink pad failed. Exiting.\n");
return -1;
srcpad = gst_element_get_static_pad (filter_src, "src");
if (!srcpad) {
g_printerr ("filter_src request src pad failed. Exiting.\n");
return -1;
if (gst_pad_link (srcpad, sinkpad) != GST_PAD_LINK_OK) {
g_printerr ("Failed to link pads. Exiting.\n");
return -1;
gst_object_unref (sinkpad);
gst_object_unref (srcpad);
if (output_mp4) {
queue_sink, nvvidconv_sink, filter_sink, videoconvert, encoder, muxer,
sink, NULL);
gst_element_link_many (osd, queue_sink, nvvidconv_sink, filter_sink,
videoconvert, encoder, muxer, sink, NULL);
} else {
gst_bin_add_many (GST_BIN (video_full_processing_bin), transform, sink, NULL);
gst_element_link_many (osd, transform , sink, NULL);
#else
gst_bin_add_many (GST_BIN (video_full_processing_bin), sink, NULL);
gst_element_link (osd, sink);
#endif
/* add probe to get informed of the meta data generated, we add probe to
* the sink pad of the osd element, since by that time, the buffer would have
* had got all the metadata. */
//osd_sink_pad = gst_element_get_static_pad (osd, "sink");
osd_sink_pad = gst_element_get_static_pad (nvtracker, "src");
/* Set necessary properties of the tracker element. */
if (!set_tracker_properties(nvtracker)) {
g_printerr ("Failed to set tracker properties. Exiting.\n");
return -1;
if (!osd_sink_pad)
g_print ("Unable to get sink pad\n");
else
osd_probe_id = gst_pad_add_probe (osd_sink_pad, GST_PAD_PROBE_TYPE_BUFFER,
osd_sink_pad_buffer_probe, NULL, NULL);
/* Set the pipeline to "playing" state */
if (input_mp4) {
g_print ("Now playing: %s\n", input_mp4);
} else {
g_print ("Now playing from webcam\n");
gst_element_set_state (pipeline, GST_STATE_PLAYING);
/* Wait till pipeline encounters an error or EOS */
g_main_loop_run (loop);
/* Out of the main loop, clean up nicely */
g_print ("Returned, stopping playback\n");
gst_element_set_state (pipeline, GST_STATE_NULL);
g_print ("Deleting pipeline\n");
gst_object_unref (GST_OBJECT (pipeline));
g_source_remove (bus_watch_id);
g_main_loop_unref (loop);
return 0;
Here is the o/p i get when i run this
Using winsys: x11
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream-4.0/lib/libnvds_mot_klt.so
gstnvtracker: Optional NvMOT_RemoveStreams not implemented
gstnvtracker: Batch processing is OFF
Creating LL OSD context new
Pipeline ready
Pipeline running
KLT Tracker Init
Track_ID 1
Track_ID 1
Track_ID 1
Track_ID 1
Track_ID 1
Track_ID 2
Track_ID 3
Track_ID 4
Track_ID 5
Track_ID 6
Track_ID 5
Track_ID 6
Track_ID 5
Track_ID 6
Track_ID 7
Track_ID 7
Track_ID 7
Track_ID 7
Track_ID 7
Track_ID 7
Track_ID 7
Track_ID 7
Track_ID 7
Track_ID 7
Track_ID 7
Track_ID 7
Track_ID 7
Track_ID 7
Track_ID 7
Track_ID 7
Track_ID 7
Track_ID 7
Track_ID 7
Track_ID 7
Track_ID 7
Track_ID 7
Track_ID 7
Track_ID 7
Track_ID 7
Track_ID 7
Track_ID 7
Track_ID 7
Track_ID 7
Track_ID 8
Track_ID 9
Track_ID 9
Track_ID 9
Track_ID 9
Track_ID 10
Track_ID 10
Track_ID 10
Track_ID 11
Track_ID 11
but I am unable to view the video. The trackIDs I recive are correct.
Can someone help me with this…
Thank you.
