Unable to recieve MCU Response via UART
I have the Jetson Nano 4Gb Developer Kit. I am having issues reading an MCU response on /dev/ttyTHS1 using the pyserial API. The UART TX pin on the 40 pin header does output and the MCU responds on the scope. Jetson’s UART port is operating in half-duplex mode. Messages are only received on the RX pin when the /dev/ttyTHS1 port is idle.
Why is the UART port operating this way?
To cover the bases, my user is in the dialout group, and I have disabled the user console following this post:
UPDATE: a USB to UART converter was used, and the pyserial code now operates as expected. Side tangent: is it possible to communicate via the UART DEBUG pins on the automation header? If so, what port is that?
For using ttyTHS1 we would need to do:
Jetson Nano how to use UART on /ttyTHS1
So it still does not work in your set up even though nvgetty is disabled?
Correct, still doesn’t work after disabling nvgetty.
I did this:
sudo usermod -a -G dialout $USER
echo -e 'KERNEL=="ttyTHS0" OWNER="root" GROUP="dialout" MODE="0660"' | sudo tee /etc/udev/rules.d/99-zTHS0.rules
sudo systemctl stop nvgetty.service
sudo systemctl disable nvgetty.service
sudo udevadm trigger
reboot
In other words, the UART port is operating in an exclusive mode and I can’t seem to figure out why. Have seen others resort to a USB adapter after giving up.
UPDATE: below is the code that successfully works with a USB adapter, but not /dev/ttyTHS1
#!/usr/bin/env python
import Jetson.GPIO as GPIO
# Core Dependencies
import serial
import time
print('pyserial version:', serial.VERSION)
channel = 12
GPIO.setmode(GPIO.BOARD)# devboard overlay configuration
GPIO.setup(channel, GPIO.OUT, initial = GPIO.LOW) # Relay Signalwire
time.sleep(5)
try:
	#turn on board
	GPIO.output(channel, GPIO.HIGH)
	time.sleep(5)
	uart_connection =  serial.Serial('/dev/ttyUSB0', 19200, timeout=1, rtscts=False)
	#initialize motorcontroller
	uart_connection.write('TXPIN CH2\r') # Move tx to ch2 pin
	time.sleep(1)
	uart_connection.write('PACE 0\r')
	print(uart_connection.get_settings())
	serial.XOFF
	while True:
		print('is serial open', uart_connection.is_open)
		print('send baud/r')
		uart_connection.write('baud\r')
		uart_connection.flushOutput()
		uart_connection.flushInput()
		time.sleep(1)
		print('response:', uart_connection.read_all())
		print(uart_connection.in_waiting)
		time.sleep(3)
		uart_connection.write('gospd 10 10\r')
hello user139627,
please access Jetson Nano Product Design Guide,
you should check [Figure 11-5. Jetson Nano UART Connections] for reference,
thanks
