Unable to run example pipeline with nvaudioinfer component
GPU
• DeepStream Version
7.0
• TensorRT Version
I’m looking at the reference section DeepStream Reference Application - deepstream-audio app — DeepStream documentation
There is a diagram of a pipeline graph with nvstreammux, nvinferaudio, and nvstreamdemux
Following this, there is an example gst-launch-1.0 command “demonstrating the above sample graph without nvinferaudio component:”
USE_NEW_NVSTREAMMUX=yes gst-launch-1.0 \
uridecodebin uri=file:///opt/nvidia/deepstream/deepstream/samples/streams/sonyc_mixed_audio.wav name=source_0 ! queue ! audioconvert ! audioresample ! mux.sink_0 \
uridecodebin uri=file:///opt/nvidia/deepstream/deepstream/samples/streams/sonyc_mixed_audio.wav name=source_1 ! queue ! audioconvert ! audioresample ! mux.sink_1 \
nvstreammux name=mux batch-size=2 ! \
nvstreamdemux name=demux \
demux.src_0 ! audioconvert ! audioresample ! alsasink async=false \
demux.src_1 ! audioconvert ! audioresample ! alsasink async=false
The above example seems to run correctly.
Now, I’m trying to extend the example to include nvinferaudio as follows.
queue ! nvinferaudio config-file-path=/opt/nvidia/deepstream/deepstream/sources/apps/sample_apps/deepstream-audio/configs/config_infer_audio_sonyc.txt ! \
However, I’m unable to get this to run.
I see the follow messages
ERROR: from element /GstPipeline:pipeline0/GstNvInferAudio:nvinferaudio0: Failed to create audio transform
Additional debug info:
gstnvinferaudio.cpp(284): gst_nvinferaudio_start (): /GstPipeline:pipeline0/GstNvInferAudio:nvinferaudio0
Any help is appreciated.
Robert.
nvstreamdemux does not support nvinferaudio output.
Is this a bug? Are there plans to fix or support this?
No. It is not necessary to get audio from the batch. In the samples, the audio data can be sent to sink by tee after decoder.
E.G.
uridecodebin uri=file:///opt/nvidia/deepstream/deepstream/samples/streams/sonyc_mixed_audio.wav name=source_0 ! queue ! audioconvert ! audioresample ! tee name=t1 t1. ! mux.sink_0 \
uridecodebin uri=file:///opt/nvidia/deepstream/deepstream/samples/streams/sonyc_mixed_audio.wav name=source_1 ! queue ! audioconvert ! audioresample ! tee name=t2 t2. ! mux.sink_1 \
queue ! nvinferaudio config-file-path=/opt/nvidia/deepstream/deepstream/sources/apps/sample_apps/deepstream-audio/configs/config_infer_audio_sonyc.txt ! fakesink \
t1. ! audioconvert ! audioresample ! alsasink async=false \
t2. ! audioconvert ! audioresample ! alsasink async=false
