Nvinfer + nvinfer audio in same pipeline
• DeepStream Version: 6.1.1 - Docker ENV
• NVIDIA GPU Driver Version (valid for GPU only) 525
• Issue Type( questions)
Hi there, I have some questions to ask and need confirmation from your side. Thank in advance.
Firstly, I already read some posts about this topic:
https://forums.developer.nvidia.com/t/how-to-build-a-deepstream-pipeline-using-both-nvinfer-and-nvinferaudio/263196
https://forums.developer.nvidia.com/t/about-running-both-nvinfer-and-nvinferaudio-in-parallel-in-jetson-boards/270095
Secondly, I have 2 questions:
Q1: Can I implement a deepstream pipeline like the image below. If cannot, could you explain why?
Q2: In case, I wanna run both nvinfer and nvinfer-audio, I have to follow deepstream-6.1/sources/apps/sample_apps/deepstream-avsync, right? or do you have any other method to do without external service like riva?
Seems the nvstreamdemux has some issue with audio batch. We will investigate the root cause.
The following pipeline is for your reference.
USE_NEW_NVSTREAMMUX=yes gst-launch-1.0 filesrc location=test.mov ! qtdemux name=m m.audio_0 ! tee name=t1 t1.src_0 ! avdec_aac ! audioconvert ! audioresample ! mux.sink_0 nvstreammux name=mux batch-size=1 ! nvinferaudio config-file-path=/opt/nvidia/deepstream/deepstream/sources/apps/sample_apps/deepstream-audio/configs/config_infer_audio_sonyc.txt batch-size=1 audio-transform="melsdb,fft_length=2560,hop_size=692,dsp_window=hann,num_mels=128,sample_rate=44100,p2db_ref=(float)1.0,p2db_min_power=(float)0.0,p2db_top_db=(float)80.0" audio-framesize=441000 audio-hopsize=110250 ! queue ! fakesink sync=0 enable-last-sample=false async=false m.video_0 ! h264parse ! nvv4l2decoder ! mux2.sink_0 nvstreammux name=mux2 batch-size=1 ! nvinfer config-file-path=/opt/nvidia/deepstream/deepstream/samples/configs/deepstream-app/config_infer_primary.txt ! queue ! nvv4l2h264enc ! h264parse ! qm.video_0  qtmux name=qm ! filesink location=out.mp4 sync=0 enable-last-sample=false async=false t1.src_1 ! queue ! qm.audio_0
Thank you for reference
Because nvstreamdemux has some issue with audio batch, my custom-plugin-2 after nvinfer-audio has to run frame by frame, cannot parallel.
So if I run the pipeline like the image blow, how can I sync frame and audio for further processing? and should I change my pipeline using riva service like example deepstream-avsync?
Thank you so much.
I’ve given you the sample, please investigate the pipeline I gave you. No RIVA service is needed.
Post it again
yup, thank you so much
@Fiona.Chen
I wanna save the raw audio for further processing so
Could you mind showing me the source code or any example to get the raw audio of the pipeline at tiler_sink_pad_buffer_probe (for example)? Thank you so much.
You can save the wav data after “avdec_aac” with “wavenc”. This is basic audio decoding and GStreamer skills. GStreamer: open source multimedia framework. Please google by yourself.
