rtx 2060
• DeepStream Version
deepstream 7.0
• TensorRT Version
with deepstream 7.0 docker image
535
questions
Unable to set the pipeline to the playing state error when using deepstream service maker.
I refer to What is Deepstream Service Maker — DeepStream documentation 6.4 documentation to try to write a basic program, which is simplified to only need to input a yaml file to run.
My code is as follows:
int main(int argc, char *argv[])
try {
Pipeline pipeline("my-pipeline", "config.yaml");
// pipeline["src"].set("uri", argv[1]);
pipeline.start().wait();
} catch (const std::exception &e) {
std::cerr << e.what() << std::endl;
return -1;
return 0;
and the config.yaml like this:
deepstream:
nodes:
- type: nvurisrcbin
properties:
uri: file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.mp4
- type: nvstreammux
properties:
batch-size: 1
width: 1280
height: 720
- type: nvinferbin
properties:
config-file-path: /opt/nvidia/deepstream/deepstream/samples/configs/deepstream-app/config_infer_primary.yml
- type: nvosdbin
- type: nveglglessink
edges:
src: mux
mux: infer
infer: osd
osd: sink
The only difference from the standard documentation example is the addition of properties:
uri: xxx,
However, I encountered: error, why?
./my-deepstream-app
Initializing GStreamer Backend...!
Node -- deepstream :
Node -- nodes :
Node -- edges :
Element ---- nvurisrcbin RefName src
uri:file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.mp4
Element ---- nvstreammux RefName mux
batch-size:1
width:1280
height:720
Element ---- nvinferbin RefName infer
config-file-path:/opt/nvidia/deepstream/deepstream/samples/configs/deepstream-app/config_infer_primary.yml
Element ---- nvosdbin RefName osd
Element ---- nveglglessink RefName sink
Element: nvurisrcbin, Name: src
set uri: file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.mp4
Add Element ... src
Element: nvstreammux, Name: mux
set batch-size: 1
set width: 1280
set height: 720
Add Element ... mux
Element: nvinferbin, Name: infer
set config-file-path: /opt/nvidia/deepstream/deepstream/samples/configs/deepstream-app/config_infer_primary.yml
Add Element ... infer
Element: nvosdbin, Name: osd
Add Element ... osd
Element: nveglglessink, Name: sink
Add Element ... sink
LINKING: Source: src Target: mux
LINKING: Source: mux Target: infer
LINKING: Source: infer Target: osd
LINKING: Source: osd Target: sink
0:00:07.166738384 3625 0x735af51e2360 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<nvinfer_bin_nvinfer> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:2095> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-7.0/samples/models/Primary_Detector/resnet18_trafficcamnet.etlt_b30_gpu0_int8.engine
uri:INFO: ../nvdsinfer/nvdsinfer_model_builder.cpp:612 [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x544x960
1 OUTPUT kFLOAT output_bbox/BiasAdd 16x34x60
2 OUTPUT kFLOAT output_cov/Sigmoid 4x34x60
0:00:07.309863992 3625 0x735af51e2360 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<nvinfer_bin_nvinfer> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2198> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-7.0/samples/models/Primary_Detector/resnet18_trafficcamnet.etlt_b30_gpu0_int8.engine
0:00:07.317653854 3625 0x735af51e2360 INFO nvinfer gstnvinfer_impl.cpp:343:notifyLoadModelStatus:<nvinfer_bin_nvinfer> [UID 1]: Load new model:/opt/nvidia/deepstream/deepstream/samples/configs/deepstream-app/config_infer_primary.yml sucessfully
Unable to set the pipeline to the playing state.
