Unable to stream from TX2 onboard camera
Just starting up with TX2, I have tried to create a minimal working proof of concept for streaming.
The commands I run in TX2:
SERVER:
gst-launch-1.0 nvarguscamerasrc   ! nvvidconv flip-method=6 ! 'video/x-raw(memory:NVMM), width=(int)2592, height=(int)1458, format=(string)I420' ! omxh264enc control-rate=2 bitrate=4000000 ! 'video/x-h264, stream-format=(string)byte-stream' ! h264parse ! rtph264pay mtu=1400 ! udpsink host=192.168.43.233 port=5000 sync=false async=false
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
Framerate set to : 30 at NvxVideoEncoderSetParameterNvMMLiteOpen : Block : BlockType = 4
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
H264: Profile = 66, Level = 40
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 2592 x 1944 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 16.000000; Exposure Range min 34000, max 550385000;
GST_ARGUS: 2592 x 1458 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 16.000000; Exposure Range min 34000, max 550385000;
GST_ARGUS: 1280 x 720 FR = 120.000005 fps Duration = 8333333 ; Analog Gain range min 1.000000, max 16.000000; Exposure Range min 22000, max 358733000;
GST_ARGUS: Running with following settings:
   Camera index = 0
   Camera mode  = 1
   Output Stream W = 2592 H = 1458
   seconds to Run    = 0
   Frame Rate = 29.999999
GST_ARGUS: PowerService: requested_clock_Hz=27216000
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
^Chandling interrupt.
Interrupt: Stopping pipeline ...
Execution ended after 0:00:32.143212552
Setting pipeline to READY ...
Code running in client:
./gst-launch-1.0 -v udpsrc port=5000  ! application/x-rtp,encoding-name=H264,payload=96 ! rtph264depay ! h264parse ! queue ! avdec_h264 ! osxvideosink sync=false async=false -e
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = application/x-rtp, encoding-name=(string)H264, payload=(int)96, media=(string)video, clock-rate=(int)90000
/GstPipeline:pipeline0/GstRtpH264Depay:rtph264depay0.GstPad:sink: caps = application/x-rtp, encoding-name=(string)H264, payload=(int)96, media=(string)video, clock-rate=(int)90000
/GstPipeline:pipeline0/GstRtpH264Depay:rtph264depay0.GstPad:src: caps = video/x-h264, stream-format=(string)avc, alignment=(string)au, codec_data=(buffer)01424032ffe1000b6742403295a00a202e7e2101000468ce3c80, level=(string)5, profile=(string)constrained-baseline
/GstPipeline:pipeline0/GstH264Parse:h264parse0.GstPad:src: caps = video/x-h264, stream-format=(string)avc, alignment=(string)au, codec_data=(buffer)01424032ffe1000b6742403295a00a202e7e2101000468ce3c80, level=(string)5, profile=(string)constrained-baseline, width=(int)2592, height=(int)1458, framerate=(fraction)0/1, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true
/GstPipeline:pipeline0/GstQueue:queue0.GstPad:sink: caps = video/x-h264, stream-format=(string)avc, alignment=(string)au, codec_data=(buffer)01424032ffe1000b6742403295a00a202e7e2101000468ce3c80, level=(string)5, profile=(string)constrained-baseline, width=(int)2592, height=(int)1458, framerate=(fraction)0/1, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true
/GstPipeline:pipeline0/GstH264Parse:h264parse0.GstPad:sink: caps = video/x-h264, stream-format=(string)avc, alignment=(string)au, codec_data=(buffer)01424032ffe1000b6742403295a00a202e7e2101000468ce3c80, level=(string)5, profile=(string)constrained-baseline
/GstPipeline:pipeline0/avdec_h264:avdec_h264-0.GstPad:sink: caps = video/x-h264, stream-format=(string)avc, alignment=(string)au, codec_data=(buffer)01424032ffe1000b6742403295a00a202e7e2101000468ce3c80, level=(string)5, profile=(string)constrained-baseline, width=(int)2592, height=(int)1458, framerate=(fraction)0/1, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true
/GstPipeline:pipeline0/avdec_h264:avdec_h264-0.GstPad:src: caps = video/x-raw, format=(string)I420, width=(int)2592, height=(int)1458, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)bt709, framerate=(fraction)0/1
From the output I see that it recognises the parameters set by the streamer (resolution etc).
But the video window only shows green background and nothing else.
Any hints on how to proceed ?
Regards,
Nevermind, actually got this to work by replacing osxvideosink on client with autovideosink
