As per the documentation Jetson NX can access upto 30 streams of video with Deepstream object detection. I was able to go only upto 19 streams, after which Jetson hangs and gives a memory error.
I tried enabling all the CPU’s, memory swap … is there something I’m missing ?
• Hardware Platform (Jetson / GPU) • DeepStream Version • JetPack Version (valid for Jetson only) • TensorRT Version • NVIDIA GPU Driver Version (valid for GPU only) • Issue Type( questions, new requirements, bugs) • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
