Hi Team,
I’m trying to visualise the video feed via local machine. I followed this tutorial Jetson AI Fundamentals - S3E1 - Hello AI World Setup - YouTube
from 14.00 min
Inside jetson nano device I ran the following command to capture the frame video-viewer --headless csi://0 rtp://<remote-ip>:1234 --input-flip=rotate-180
When I run the above command I can see the following output
from local machine I used the following command to visualize the camera feed gst-launch-1.0 -v udpsrc port=1234 caps = "application/x-rtp, media=(string)video, clock-rate=(int)90000, encoding-name=(string)H264, payload=(int)96" ! rtph264depay ! decodebin ! videoconvert ! autovideosink
when I run the above command in my local machine, it doesn’t run, it just stuck
Could you please help me here to fix the problem? I’m trying this with headless mode.
#jetson
