I am curious how the Orin NX’s current limits and OC events are setup.
I have an Orin NX running Jetpack 5.1.2, and it’s max “stable” (Non-MAXN) power mode is 20W.
Within it, I have seen OC2 and OC3 throttling events when stressing the system (High CPU + GPU loading).
- 1 question I have is, are those OC2 and OC3 events directly related to any of the curr1/2/3 crit/max limits set in
/sys/bus/i2c/drivers/ina3221/1-0040/hwmon/
With the new jetpack 6.1.2 release “Super Mode” was introduced with 40W mode.
In it, the limits in /sys/bus/i2c/drivers/ina3221/1-0040/hwmon/
seem to have changed to be higher.
- My second question is if this indicates it is possible to push the limits higher in Jetpack 5.1.2 , or if there are some critical changes in the kernel to super mode that allow for these higher limits?
I don’t want to increase clock frequencies yet, just reduce the probability of OC2 and OC3 events.
I understand previous guidance was to not change the ina3221 max/crit values, but I am curious what changes in 6.1.2 allowed them to grow higher.
