I’ve a lot of error “System throttling du to over-current” on my AGX Orin dev kit with the MAXN power mode. But when I look on jtop, the total power consumption is less than 30W.
The same problem here, running a Yolov5 on an AGX Orin dev kit in MAXN power mode (Jetpack 5.1 Version 5.1-b147).
I’ve never seen this before on the same kit with Jetpack 5.0.1 .
The default setting is for Orin developer kit and it is the maximum value. We are not able to increase the limit since it probably damages the board physically.
