Can anyone point me in a direction of any documentation regarding how to interpret the device tree (ideally for the Nvidia Jetson TX1/TX2). I would like to be able to understand exactly what is being set and not relying on examples.
I understand the example below corresponds to setting up this particular SPI interface to a SPI Master. Taking the excerpt of the device tree source below, what do the following correspond to:
- reg - Is this some sort of hardware registry corresponding to spi@7000d400?
- interrupts - what do 0x0, 0x3b and 0x4 relate to?
- iommus - what do 0x0, 0x3b and 0x4 relate to?
- dmas - Direct Memory Access, I get it, but what do 0x5c, 0xf, 0x5c and 0xf relate to?
- nvidia,clk-parents - what is 'pll_p' and 'clk_m'
spi@7000d400 {
compatible = "nvidia,tegra210-spi";
reg = <0x0 0x7000d400 0x0 0x200>;
interrupts = <0x0 0x3b 0x4>;
nvidia,dma-request-selector = <0x5c 0xf>;
iommus = <0x57 0xe>;
#address-cells = <0x1>;
#size-cells = <0x0>;
dmas = <0x5c 0xf 0x5c 0xf>;
dma-names = "rx", "tx";
nvidia,clk-parents = "pll_p", "clk_m";
status = "okay";
prod-settings {
prod {
prod = <0x4 0xfffff000 0x0>;
prod_c_flash {
status = "disabled";
prod = <0x4 0xffffffc0 0x7>;
prod_c_loop {
prod = <0x4 0xfffff000 0x44b>;
As always, thank you very much for your help.
David.
