I am confused about the usage of the TopK layer;
- As from the documentation "The TopK layer has two outputs of the same dimensions. The first contains data values, the second contains index positions for the values."; https://docs.nvidia.com/deeplearning/sdk/tensorrt-api/topics/classnvinfer1_1_1_i_network_definition.html#a384a409318bf416be3aa4442f2b0ce76 what I experience, though, is that the method getNbOutputs() returns a 1; and in fact calling the method getOuput(index) with index = 1, it results in a segmentation fault;
- I would expect the size of the output - may it be data values or index positions - for input of size [BatchSize, NumChannels, Height, Width], to be something like [BatchSize, NumChannels, Height, K], where K would be the number of elements to keep, and the reduction axis would be the Width one; instead, in my experience the output size is the same as the input size;
- Trying to execute the code attached below, I obtain the error
ERROR: topk: input and output must have the same number of dimensions topkdebug: topKdbg.cpp:139: void APIToModel(unsigned int, nvinfer1::IHostMemory**): Assertion `engine != nullptr' failed.I tried both, defining output size as expected and defining it the same as the input; same problem;
is that the expected behaviour and it is me misunderstanding?
can anyone show me an example of the correct usage of the layer? I know it is used in the sampleCharRNN sample but the code doesn’t execute for me either.
I use TensorRT 4.0.0.3 with CUDA 8.0;
Please find my toy example code below to reproduce the issue;
Thanks,
f
#include "NvInfer.h"
#include "NvCaffeParser.h"
#include "NvUtils.h"
#include "cuda_runtime_api.h"
#include <cassert>
#include <cmath>
#include <cstring>
#include <string>
#include <fstream>
#include <iostream>
#include <sstream>
#include <sys/stat.h>
#include <vector>
#include <algorithm>
#define CHECK(status) \
if (status != 0) \
std::cout << "Cuda failure: " << status; \
abort(); \
// Logger for GIE info/warning/errors
class Logger : public nvinfer1::ILogger
public:
void log(nvinfer1::ILogger::Severity severity, const char* msg) override
// suppress info-level messages
if (severity == Severity::kINFO) return;
switch (severity)
case Severity::kINTERNAL_ERROR: std::cerr << "INTERNAL_ERROR: "; break;
case Severity::kERROR: std::cerr << "ERROR: "; break;
case Severity::kWARNING: std::cerr << "WARNING: "; break;
case Severity::kINFO: std::cerr << "INFO: "; break;
default: std::cerr << "UNKNOWN: "; break;
std::cerr << msg << std::endl;
// def constants
static const int K_TOP = 10; //3;
static const int INPUT_H = 1;
static const int INPUT_W = 10;
static const int INPUT_C = 5;
static const int OUTPUT_H = 1;
//static const int OUTPUT_W = 10;
static const int OUTPUT_W = K_TOP;
static const int OUTPUT_C = 5;
static const int BATCH_SIZE = 4;
static const int MAX_BATCH_SIZE = 4;
const char* INPUT_BLOB_NAME = "data";
const char* OUTPUT_BLOB_NAME = "out";
static void* buffers[2];
static cudaStream_t stream;
static int inputIndex, outputIndex;
using namespace nvinfer1;
static Logger gLogger;
// print tensor dimensions
void printDims(ITensor* data)
Dims dims = data->getDimensions();
int nbDims = dims.nbDims;
for (int d = 0; d < nbDims; d++)
std::cout << dims.d[d] << " ";
std::string sss;
if (data->getType() == DataType::kHALF)
sss = "float16";
if (data->getType() == DataType::kFLOAT)
sss = "float32";
std::cout << sss << " ";
std::cout << std::endl;
void APIToModel(unsigned int maxBatchSize, IHostMemory **modelStream)
// create the builder
IBuilder* builder = createInferBuilder(gLogger);
INetworkDefinition* network = builder->createNetwork();
// define input
auto data = network->addInput(INPUT_BLOB_NAME, DataType::kFLOAT, DimsCHW{INPUT_C, INPUT_H, INPUT_W});
assert(data != nullptr);
std::cout << "input" << std::endl;
printDims(data);
// apply topK
int reduceAxis = 0x4;
auto topk = network->addTopK(*data, TopKOperation::kMAX, K_TOP, reduceAxis);
topk->setName("topk");
std::cout << "topk0" << std::endl;
printDims(topk->getOutput(0));
topk->getOutput(0)->setName(OUTPUT_BLOB_NAME);
network->markOutput(*topk->getOutput(0));
// std::cout << "topk1" << std::endl;
// printDims(topk->getOutput(1));
// std::cout << topk->getNbOutputs() << std::endl;
// Build the engine
builder->setMaxBatchSize(maxBatchSize);
builder->setMaxWorkspaceSize(1e9);
std::cout << "building the engine..." << std::endl;
auto engine = builder->buildCudaEngine(*network);
assert(engine != nullptr);
std::cout << "engine built!" << std::endl;
// serialize the engine, then close everything down
(*modelStream) = engine->serialize();
network->destroy();
engine->destroy();
builder->destroy();
void setUpDevice(IExecutionContext& context, int batchSize)
const ICudaEngine& engine = context.getEngine();
// input and output buffer pointers that we pass to the engine - the engine requires exactly IEngine::getNbBindings(),
// of these, but in this case we know that there is exactly one input and one output.
assert(engine.getNbBindings() == 2);
// In order to bind the buffers, we need to know the names of the input and output tensors.
// note that indices are guaranteed to be less than IEngine::getNbBindings()
inputIndex = engine.getBindingIndex(INPUT_BLOB_NAME);
outputIndex = engine.getBindingIndex(OUTPUT_BLOB_NAME);
// create GPU buffers and a stream
CHECK(cudaMalloc(&buffers[inputIndex], batchSize * INPUT_H * INPUT_W * INPUT_C * sizeof(float)));
CHECK(cudaMalloc(&buffers[outputIndex], batchSize * OUTPUT_W * OUTPUT_H * OUTPUT_C * sizeof(float)));
// create cuda stream
CHECK(cudaStreamCreate(&stream));
void cleanUp()
// release the stream and the buffers
cudaStreamDestroy(stream);
CHECK(cudaFree(buffers[inputIndex]));
CHECK(cudaFree(buffers[outputIndex]));
void doInference(IExecutionContext& context, float* input, float* output, int batchSize)
// DMA the input to the GPU, execute the batch asynchronously, and DMA it back:
CHECK(cudaMemcpyAsync(buffers[inputIndex], input, batchSize * INPUT_H * INPUT_W * INPUT_C * sizeof(float), cudaMemcpyHostToDevice, stream));
context.enqueue(batchSize, buffers, stream, nullptr);
CHECK(cudaMemcpyAsync(output, buffers[outputIndex], batchSize * OUTPUT_W * OUTPUT_H * OUTPUT_C * sizeof(float), cudaMemcpyDeviceToHost, stream));
cudaStreamSynchronize(stream);
void printData(float *out, const int batch_size, const int output_c, const int output_h, const int output_w)
int output_size(output_c * output_h * output_w);
std::cout << "================="<< std::endl;
for (int b = 0; b < batch_size; b++)
std::cout << "-----------------"<< std::endl;
for (int c = 0; c < output_c; c++)
for (int h = 0; h < output_h; h++)
for (int w = 0; w < output_w; w++)
std::cout << out[b * output_size + c * output_h * output_w + h * output_w + w] << " ";
return;
int main(int argc, char** argv)
// allocate CPU memory for input and output
int inputSize = sizeof(float) * BATCH_SIZE * INPUT_C * INPUT_H * INPUT_W;
int outputSize = sizeof(float) * BATCH_SIZE * OUTPUT_C * OUTPUT_W * OUTPUT_H;
float *data = (float *)malloc(inputSize);
float *out = (float *)malloc(outputSize);
// init dummy input
srand (time(NULL));
for (int d = 0; d < BATCH_SIZE * INPUT_W * INPUT_H * INPUT_C; d++)
data[d] = rand() % 100 + 1;;
// print input
printData(data, BATCH_SIZE, INPUT_C, INPUT_H, INPUT_W);
// create a model using the API directly and serialize it to a stream
IHostMemory *modelStream{nullptr};
APIToModel(MAX_BATCH_SIZE, &modelStream);
IRuntime* runtime = createInferRuntime(gLogger);
ICudaEngine* engine = runtime->deserializeCudaEngine(modelStream->data(), modelStream->size(), nullptr);
if (modelStream) modelStream->destroy();
IExecutionContext *context = engine->createExecutionContext();
// allocate device memory, do bindings
setUpDevice(*context, BATCH_SIZE);
// run inference
doInference(*context, data, out, BATCH_SIZE);
// destroy the engine
context->destroy();
engine->destroy();
runtime->destroy();
// free device memory
cleanUp();
// print output
printData(out, BATCH_SIZE, OUTPUT_C, OUTPUT_H, OUTPUT_W);
//free host mem
free(data);
free(out);
std::cout << "done!" << std::endl;
return 0;
