If I am not mistaken, the angular velocity of the angular drives in e.g. Revolute Joints in Isaac Sim is given in degree per second. However, from the official documentation, one might assume that the angular velocity is given in radians per second. Is it just me, or is this not clearly defined in the documentation?
rgasoto
3
You are correct - the angle values in Isaac sim are given in Degrees. we will update the documentation to make it more clear.
Related topics
Topic | Replies | Views | Activity | |
Is the angular velocity unit in Isaac Lab measured in deg/s or rad/s? | 0 | 80 | August 27, 2024 | |
Joints revolute speeds | 2 | 379 | December 15, 2023 | |
Robotic arm revolute joints speeds | 0 | 257 | December 11, 2023 | |
The units of Position Command in Articulation Controller | 3 | 446 | October 25, 2023 | |
How to change the angular velocity of the wheels in real-time during rendering in standalone mode? | 1 | 20 | October 25, 2024 | |
Conveyor velocity units | 2 | 738 | March 1, 2023 | |
Is velocityCommand = 1.0 really 1 m/s in Isaac Sim? Unit mismatch? | 0 | 1 | June 13, 2025 | |
Get prim real-time velocities | 3 | 1106 | April 5, 2024 | |
Incorrect angular velocity when simulating differential drive in IsaacGym | 1 | 470 | February 22, 2024 | |
How to set drive acceleration? | 0 | 38 | July 29, 2024 |
