Unmet Dependencies Error While Installing JetPack on Jetson AGX Orin
I’m experiencing an issue while trying to install JetPack on my Jetson AGX Orin. During the installation process, I encounter the following error related to unmet dependencies:
depends: libnvidia-gl-560 (= 560.28.03-0ubuntu1) but it is not going to be installed
depends: libnvidia-compute-560 (= 560.28.03-0ubuntu1) but it is not going to be installed
depends: libnvidia-extra-560 (= 560.28.03-0ubuntu1) but it is not going to be installed
depends: nvidia-utils-560 (= 560.28.03-0ubuntu1) but it is not going to be installed
e: unmet dependencies. try 'apt --fix-broken install' with no packages (or specify a solution).
I have tried the following steps to resolve the issue:
  1. Running sudo apt --fix-broken install to fix broken dependencies.
  2. Updating and upgrading my package lists with sudo apt update and sudo apt upgrade.
Despite these efforts, the problem persists. I am seeking assistance to resolve this issue and successfully install JetPack on my device.
Any help or guidance would be greatly appreciated.
Thank you!
I am not sure what you are doing here. Jetpack does not install these things on Jetson as I know.
What is your command running on your Jetson? and host PC?
i try accidentally install ollama and it start to download it i cannot stop it know when itry to boot it seem that it start the ubntu but then a iget a black screen
Is it okay for you to reflash the board?
there is another option i have a lot of working on this computer?
I have the same problem after upgrading Ollama. Is there another way to fix this short of reflashing?
